Question about Arris SURFboard SBG900 Wireless Router (DHSBG900)
Motorola SBG900-SiS191 Ethernet Controller
I have an SiS191 Ethernet Controller and it will not connect using my Motorola SBG900 router. The wireless router works fine but the ethernet just says Acquiring Network Address... Can you help?
  • demodas Feb 16, 2009
    i have sis191 ethernet controller in laptop and i have hub (3com) when i connect with internet the speed off connection 10mbps and i have other pc with other ethernet controller give the speed 100mbps
    please help me
  • 135 Answers
Setup your IP addresses correctly by checking available IP addies in router.
You will have to know your router addie and your available wireless addies (in router). For this you need to enter router configuration (read manual).
Open network properties, tcp/ip properties, check "use following ip addie and enter something like 192.168.1.5 depending on what your router is setup as available.
Enter same subnet as your router.
Enter DNS server addies from you ISP.
Posted on Feb 19, 2009
Motorola Surfboard SBG900 will not connect to Playstation Network
You need to give the PS3 its own IPAddress outside of the firewall. You need to configure the router and the PS3.
Mar 13, 2010 | Arris SURFboard SBG900 (49402201900) Modem
Motorola SBG900 and Netgear print server
Yes you can , just configure the wireless settings of you SBG900 to the print server and once its done you should be able to make everything working again....
Dec 18, 2009 | Arris SURFboard SBG900 Wireless Router...
We just tried to secure our wireless motorola sbg900 and now the wireless portion doesn't work. We have to use an ethernet cable. How do we reverse this and still make it secure?
To change any wireless settings on the router, you will need to make wired connections to the router.
If you change the wireless settings on the wireless laptop it will drop the connection because you are changing a wireless setting.
Click Here for more info about networking
Oct 17, 2009 | Arris SURFboard SBG900 Wireless Router...
Cannot connect 2 computers to Motorola SBG900 wireless cablemodem
mac and pc security keys are not interchangable. I suggest not using a a key for both units. You can reset the router by unplugging it for 1 minute. or you gain access to the router through the web address. 192.168.1.1 Type this into the address bar to gain access to the router.
Jul 10, 2009 | Arris SURFboard SBG900 802.11g/b...
Motorola SBG900 - network cannot see hardwired computer
Try to logon to the configuration page of your router and from there you can able to setup the Local Domain Name on it for your network.
Mar 08, 2009 | Arris SURFboard SBG900 Wireless Router...
Sbg900 wireless connectivety
I had that long time ago. Now I do not broadcast ESSID and changed the channel to 11 (I also use Vonage and when the call was placed the wifi was dropped. No longer).
Changing the MTU to 1452 (on the gateway) helps with the connection. Just to make sure I assigned the first IP address a bit away from the starting point, .10 so that somebody around having the same would not confuse my settings.
Feb 09, 2009 | Arris SURFboard SBG900 Wireless Router...
Can I use my router just as a Wireless router with a DSL .
i doubt it will work. most times the cable companies give you a modem/router all in one box. the problem is there in no inbound connection to recieve an internet signal other than the cable cord connection. with the dsl modem you will need a seperate router. they cost around $40-50 on avg
Feb 05, 2009 | Arris SURFboard SBG900 Wireless Router...
SBG900 Wireless not detected
See the other post. Change the "channel" on the online settings and that should work.
Jan 12, 2009 | Arris SURFboard SBG900 Wireless Router...
Wireless Doesn't Work - No light.
If someone else setup the router for you they may have turned off the wireless. If you can connect via ethernet use the web based configuration utility to turn it back on.
The intial setup is as follows in the manual:
To provide an initial wireless connection to your network and the Internet:
1 Connect the SBG900 to the cable TV system as described in Section A.
2 On each wireless client computer, install the wireless adapter hardware and
driver software according to the manufacturer's instructions.
3 On each wireless client computer, set up a wireless adapter profile to
“connect” the client to the SBG900. The procedure depends on your
wireless adapter and computer operating system.
In your initial profile, use the SBG900 default wireless Network Name
(ESSID) motorola (case-sensitive).
Your computers are connected but not secure.
The default SBG900 settings provide no wireless security. After
your wireless LAN is operational, be sure to enable security as
described in “Setting Up the Wireless LAN” in the SBG900
User Guide
Oct 30, 2008 | Arris SURFboard SBG900 Wireless Router...
Motorola SURFboard SBG900 loss ethernet connection
Please remove the program of your router and re install it again and it will work..
Good luck
Johnson
Jan 03, 2008 | Arris SURFboard SBG900 (49402201900) Modem
Arris SURFboard SBG900 Wireless Router (DHSBG900) Logo
473 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
