Question about ViewSonic A90f+ 19" CRT Monitor
Wavy distortion on bottom of screen
ViewSonic A90f+ 19 in.CRT
Hi
I have a horizontal wavy type of distortion on the bottom of my screen. It started on the very bottom and has been growing ever since to the point where it now is taking over almost a quarter of the screen.
I checked the cable, changed computers and all settings.
Does anyone know what this is? I have experience with Guitar amplifiers so I can probably handle it if its fixable. Anyone know what this is?
thanks
  • 9 more comments
  • donkey22 Feb 02, 2009
    Just to add...
    I know Moire is described as a wavy distortion but this is more like a sea of distortion in which you cant even make out the image underneath.
    Hey thanks
    So this kind of mess on the bottom of the screen that grows each month is usually a capacitor shorted?
    It funny ..this monitor was only 3 years old when this happened
    One more thing
    If I turn the computer off the monitor keeps powering on and off. I didnt mention this because I though its something to do with my computer settings but maybe its related? This started a few months after the initial problem
  • donkey22 Feb 04, 2009
    Hi
    The amps I have restored are point to point wiring. I know amps--this is very different. If I had a schematic that would help
    but anyway there are 2 circuit boards.
    Im assuming most problems are on the small circuit board attached to the tube--is this correct?--and are the capacitors I should check on this small board?--and should I desolder these 2 caps check for a short or will these read infinate resistence while on the board?
    thanks guys
    The monitor model Viewsonic 19" A90f+
    vcdts23307 made in 2003
    Im gonna open her up tomorrow to get the other info. Is that big cap on the little board connected to the tube?
    Thanks so much
  • donkey22 Feb 06, 2009
    Hey Thanks
    I checked a bunch of stuff but the problem Im having is I cant find a layout diagram for this so Im blind. All the caps I checked are good. They were 100uf/250v , 220/400, 1000/16 which was next to the burnt resistor. The was glue inbetween these 2 so I dont know if the glue heated.
    I took some pictures so maybe someone can give a bearing. You will see the circle where the missing caps I tested were from. There was a burn spot on a 5 ohm reisitor at R384. I think its 5 or 6 ohm--it has a green-gold-gold-gold pattern--which I have never seen(I have never used such low resistors) It tested at 7 ohms
    http://mixinthebox.com/DVC00282.JPG
    http://mixinthebox.com/DVC00283.JPG
    http://mixinthebox.com/DVC00284.JPG
    http://mixinthebox.com/DVC00285.JPG
    http://mixinthebox.com/DVC00286.JPG
    http://mixinthebox.com/DVC00287.JPG
    http://mixinthebox.com/DVC00288.JPG
    http://mixinthebox.com/DVC00289.JPG
    Oh Yeah
    There is little cut in the Z809 under the Big cap on the bootm in the picture
    I looked through so many and nothing
    So far I cant find any bad caps
  • donkey22 Feb 08, 2009
    Hey
    someone said this is a symptom of a vertical IC problem. Can anyone look at the picture and tell me where this is so I can see if the burnt resistor was in this location?
  • donkey22 Feb 18, 2009
    To update
    I replaced the caps around the Vertical IC and the pic filled the screen again. But after a week it seems to be starting all over again ever so slightly. Im thinking it might be the chip
  • Anonymous Mar 13, 2009
    I think I have the same problem. It started about a week ago with just a fewhorizontal quivering lines over the task and its been getting worse. tonight i can only faintly see the image through a cloudy looking covering of lines. I have to right click and wait and see whether I have 'hovered' over the correct icon to do anything.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Depending on the length of time the monitor has been used, this would often indicate a power supply problem, more specifically a low main B+. Since you are familiar with electronic components & circuitry, you might want to check the big filter capacitor right after the bridge diode on the hotside, likewise the capacitor after the single diode on the secondary side and or the capacitor along the + rail going to the FBT/HOT.
Good luck and thank you for using FixYa.
Posted on Feb 02, 2009
  • 2 more comments
  • Louie  Role
    Louie Role Feb 04, 2009
    Hi again,
    For some reason, I failed to receive notice of your postback/comments, my apologies for replying rather late then.
    On the monitor, your additional information all points to the big capacitor of the power supply, something like 470uF/160V, that has started to leak and over time lost its ability to filter and store electrical charge. The leak normally takes some time.
    On the amp, it would help if you could postback the brand/model. Capacitors in this type of design (tubes) tend to deteriorate faster because of the heat. Capacitors should always be checked out of circuit and discharged. When using an analog tester, the capacitor should show the needle deflect towards the right and then slowly go back to the left. Reversing the test prods would show the same.
    If the brand/model could not be determined or if no schematics are available, you could get the tube numbers (something 4BA6), the spec sheet could be Googled and the voltages normally applied to each pin could be determined. Thereafter, measuring the voltages on these points while referencing the spec sheet would give you an idea if the bleeder/bias resistor supplying the voltage needs further investigation by the presence or absence of the volts. In some instances, removing the tubes and cleaning the pins would correct some problems.
    Am curious so would appreciate an update.
    Cheers.
  • Louie  Role
    Honestly I got mixed up. I though the first part of your recent post was about the monitor and that the second part was about a vacuum tube amplifier, LOL, gotta layoff the coffee.
    Anyway back to your concern on the monitor. The smaller PCB right at the rear of the tube has nothing to do with the bottom wavy line. That smaller squarish board with shielding is for the color drive transistors/IC. If the display is missing a color, fault would be in this board.
    The bigger bottom board is the main board. If you would follow the AC power cord, it would lead you to a bridge diode then to the big filter capacitor. This would be the primary hot side. From the capacitor, it would go to a power pack IC that does the regulation switch mode, then to a small transformer. This is a high frequency high power transformer. The secondary side of the transformer would lead you to single diodes and slightly smaller capacitors.
    Foremost to check would be the primary capacitor after the bridge diode.
  • Louie  Role
    Louie Role Feb 06, 2009
    This page has about 200+ schematic diagrams of Viewsonic models but none exactly for an A90F+. What could be tried is to download is a schematic for a 17 or 21 inch whose chassis is identical to the A90F. Unfortunately due to limited bandwidth I am unable to do this. Additionally, some other brands like AOC shares the same chassis as the Viewsonic.
  • Louie  Role
    Louie Role Feb 18, 2009
    Appreciate the updates. Might be the vertical IC, one indication is if it heats so much that it could not be touched.
Wavy horizontal lines across the screen
It sounds that the main power supply section to your TV has the fault. The horizontal thik lines that appears crawling down across the screen should be of video 'HUM'. Have you replaced the main filter capacitor at the power supply section? If not, replace it along with the main rectifier. The AC power is rectifed by a bridge and applied ot this main filter capcitor. It will have a capacitance value between 120 to 350MFD 450VDC. Check this section. Measure the rectifed DC voltage acorss this main filter capacitor. It should be around 350VDC, if your home power supply line is 220VAC. If it is 110AC, this DC voltage will be around 165VDC; and it should be. If rectified DC voltage found lower than the input AC voltage, replace the rectifier bridge. In some sets, this bridge section have four diodes. Some other circuits, a bridge rectifier stalk may be used.
May 20, 2012 | JVC AV-27050 TV
Gateway VX 920 Diamatron monitor has wavy lines at bottom
Since this is a CRT (Cathode Ray Tube) It is no longer cost effective to repair them. Your Tube Driver circuit (internal non-serviceable parts) is starting to fail.
Apr 05, 2010 | Computers & Internet
A90f dark dark screen
Use brighten controls on monitor to lighten
Dec 22, 2009 | ViewSonic A90f+ 19" CRT Monitor
Wavy horizontal lines on bottom of RCA 36in Truflat TV
The convergance or y-sus board can become faulty. The capcitors do tend to burn out. It is about a $250 + repair for this. Not all parts can be repaired, but they can be replaced. A capacitor tester and multi-meter are about the best tools for the job. If the price you get is over $250, I simply would replace it instead of repairing it..
Sep 13, 2009 | RCA TruFlat 27F520T 27" TV
Picture is wavy and has black vertical and horizontal band
The following are supposed to be checked on the horizontal and vertical,
the supply of the sawtooth oscillator
eletrolitic capacitors near a line transformer
zener diodes
and driver transistor a round that area.
Apr 08, 2009 | Toshiba 35A44 35" TV
Screen is distorted and has wavy line across.
46" Samsung LCD, screen is distorted and has wavy lines across the screen.
Sep 26, 2008 | Samsung Televison & Video
A black vertical line on my screen
it risky if you always use your monitor that has a factory defect..i suggest to return to the store for some replacement of your monitor...coz your monitor has a warranty.
Jan 28, 2008 | ViewSonic G810 21" CRT Monitor
Wavy or distorted monitor
Wavy or distorted issues only arise if electronics or anything that has magnets in it is near it or on the CRT ( the really huge monitors) so try moving it elsewhere ( In this case you can hire someone with the "magic wand " to zapp the colours back)(general tv repairer.If its an LCD (flat and small screen) it may be dying as the transistors are wearing out ( They usually last for 4 yrs) The only thing you can do is replace the circuit board or the panel . If you have another pc or laptop try to connect it to the monitor and if the pictures are perfect ,its your graphics card .
The best solution to this is to move the screen to another place without electronics or to connect it to a laptop or pc to see if its ok. If the symptoms persist i recommend you to buy another perferably dell screens 19" Lcd as they are cheap and provide good quality.
Sorry for the huge legnth of this Hope it helps :)
Dec 05, 2007 | HP VECTRA VL PC Desktop
Sylvania 6427FF TV displays wavy verticle lines at top of the screen.
I would suspect defective filter capacitors in the sweep circuits as well as the power supply source voltages.
Aug 07, 2007 | Sylvania 6427FF TV
Wavy horizontal picture
the vertical IC outpt needs to be replace
Dec 29, 2006 | Panasonic PT-53WX42 53" Rear Projection...
ViewSonic A90f+ 19" CRT Monitor Logo
670 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
