Question about Evenflo PortAbout 3
Carseat rocks backwards when in rearfacing position
When in the rear facing position my car seat is fastened in properly I think and it doesn't move forward are sidetoside but it doesn't tight as far as rocking backwards
  • dirtmagnets May 11, 2010
    Do you mean that you can pull the top of the carseat towards the seat back of the seat that it's in?
    That's rebounding, and most rearfacing seats are supposed to do so. In a frontal collision (usually the most severe type of crash), the momentum causes everything to move forward until most of the crash energy is absorbed, and then, to a lesser extent, everything is jerked backwards. A rear facing seat that can rebound stays with your baby, cradling his/her body for both motions instead of just the forward motion.
    As long as your seat doesn't move more than 1 inch from side to side at the seat belt path and it is installed at the correct angle, you're in good shape.
    President:
  • 2,976 Answers
Depending on your seatbelts, you have to lean your body weight onto the car seat to make it tight.
Posted on Sep 11, 2009
Seat won't move forward, cant get to the rear bolts to remove seat because seat is back as far as it can go is there any way to move the seat manually
You must remove the seat from the power seat transmission then remove the drive motor from the seat transmission, move the seat to the desired position and reinstall the motor to lock it in place. The seat transmission is bolted to the seat mounting bracket/rails.
Feb 01, 2017 | Seat Cars & Trucks
Seat removal on 2009 harley softail deluxe
To install slide the retention nut over the tapered end of a cable tie strap so
that the larger O.D. of the nut rests on cable tie strap eyelet, then from the bottom of the rear fender feed the cable tie strap up through the fender hole, with the tab on the retention nut seated in the notch in the fender hole pull up on the cable tie strap to locate the nut snug up against the underside of the rear fender and then from the side opposite the tab i.e. from the rear of the fender slide the retention washer onto the nut which will lock it in place.
The FXST/FXSTB seat attaches with a single thumbscrew on the seat bracket. When installing a seat insert the tang at the front of the seat into the channel in the frame and install the single rear thumbscrew which Harley- Davidson has a special tool for which I have never even seen, pn HD-47190.
The FXSTC seat attaches with two fasteners through the sissy bar. When installing the seat the tang at the front of the seat is inserted into the channel in the frame and the two rear fasteners go through the and get tightened to 60-80 in-lbs (6.8-9.0Nm).
The FXCW/FXCWC Solo Seat is attached with 2 locating pins that for removal must be removed from their grommets by lifting the rear of the seat, then the seat is pulled to the rear to disengage the tongue from the frame. To install the seat put it on the frame, slide the seat forward until the tongue locks into the bracket, push the seat forward to align the two locating pins with their grommets and then push the seat down to engage the locating pins.
The FXCWC rider Seat is removed by tipping the seat up and towards the fuel tank, the two fasteners are removed and the seat is then taken off the bike. Do the reverse to install the seat and tighten the fasteners to 90-110 in-lbs (10.2-12.4 Nm).
The FXCWC Passenger Seat Support is removed by tipping the rider seat up and towards thefuel tank removing the two screws and washers from one pillion support, removing the pillion support and the rear seat pillion, then removing the remaining pillion support. To install it install one pillion support but do not tighten its fasteners, install the wave washer and bushing on each pillion support, install the pillion and the second pillion support and tighten all of the fasteners to an initial torque of 30-35 ft-lbs (40.7-47.5 Nm), then loosen the fasteners and then final tighten them to 38-42 ft-lbs(51.5-56.9 Nm), check the rider seat operation and then lower the rider seat into position and engage the locating pins into their
grommets.
To remove the FLSTN/FLSTF/FLST/FLSTC seat remove the passenger seat and seat mounting fasteners. When installing the seat insert the tang at the front of the seat into the channel in the frame and install the seat mounting nuts, then install the passenger seat.
To remove the FLSTSB seat remove the screw from the seat hinge at the front of the seat, raise the rear of the seat only slightly during removal or installation because pivoting the rear of the seat up too high can cause the nose of the seat to damage the leather trim panel on the fuel tank., to disengage the springs from the seat spring mounting pins and remove the seat. To install the FLSTB seat align the seat hinge with the mounting bracket on the frame, insert the screw into the seat hinge from the right side of the motorcycle and tighten it to 14-16 ft-lbs (19.0-21.7Nm), align the bushings on the seat springs with the mounting pins and push the rear of the seat down to engage the seat spring mounting pins. The seat position may be adjusted forward or rearward for rider comfort by removing the seat, removing the nut on the seat hinge, removing the bolts from the seat spring support bracket, (the seat hinge and seat spring support bracket must be installed in the same position in either a forward or a rearward configuration for the seat to fit properly on the motorcycle). To position seat forward install the hinge with the front tab in the slot, install the seat spring support bracket with the springs toward the rear of the seat. AND to position the seat rearward install the hinge with the rear tab in the slot and install the seat spring support bracket with the springs toward the front of the seat., THEN install the nut on the seat hinge and tighten it to 20-25 ft-lbs (27.1-33.9 Nm), install the screws for the seat spring support bracket and tighten them to 15-20 ft-lbs (20.3-27.1 Nm) and then install the seat.
May 18, 2014 | 2005 Harley Davidson XL 1200 R Sportster
I have a new graco cleo car seat. What weight and age does my baby have to be before I shoud face it forward in the car?
Group 0 Until the age of 12 months (13kg/28lbs), your child must always be in a rear-facing position. Group 0+ car seats move from a reclined to a seated position, whilst perfectly supporting your child's back.
Group 0+ Until the age of 12 months (13kg/28lbs), your child must always be in a rear-facing position. Group 0+ car seats move from a reclined to a seated position, while perfectly supporting your child's back.
Group 0+/1 Children are unique and grow at different paces so category 0+/1 seats are highly flexible to reflect this. Babies up to 9kg (19 lbs) can travel safely facing the rear. From 18kg (39lbs) the seat can be adjusted so they face forward, allowing you to spend more time face-to-face with your baby which is an important part of parent-child bonding.
return to top
Group 1/2/3 The car seats in this category grow with your child from 9 months to 12-years old (9-36kg/19-79 lbs) so they can remain comfortable and importantly, develop properly. This flexibility makes it the ideal car seat category for large families and grandparents with grandchildren of different ages.
Group 2/3 A child must have a car seat that is tailored to their weight, height and age until they are 12 years-old, or 36kg (79lbs). The group 2/3 category offers convertible seats for older children aged between 4 and 12 (15-36kg/33-79lbs), this means the car seat grows with your child.
Hope this helps, I have a graco for my 12 week old, this info is from the graco website
Bye for now
Aug 04, 2011 | Graco Baby Gear
I have a 1993 Mercury Topaz that I just bought, and the drivers side seat will not move forward, it will go in all other directions, but won't move forward...any suggestions?
There are 3 electric motors on the seat. One is forward and back, one is front up and down, and one is rear up and down. The switch changes the polarity back and forth to achieve the proper movement. I think the wire color for the forward and back motor is yellow with a white tracer and red with a white tracer. so if the switch gives the motor positive voltage to the yellow with a white tracer and grounds the red with a white tracer the seat moves forward. If the switch gives the red with a white tracer positive and the yellow with a white tracer ground the seat moves back. (or the other way around). So we can safely say it is in the switch.
Good luck and God Bless
Jun 06, 2011 | 1993 Mercury Topaz
How to remove rear seat in 1996 dodge ram 1500
REMOVAL & INSTALLATION
  1. Clamp the seat belts to keep them from retracting.
  2. Locate and disconnect seat wiring at the connector(s).
  3. Move front seats forward or back for access to the hold down hardware.
  4. Put the rear seats in the stowed position.
  5. On Durango 3rd row seats, lift the cushion upward and forward to floor cargo position.
  6. Remove the hardware securing the seat.
  7. On split bench models, lift the center seat upward to clear attachment stud
  8. Remove the seat from the vehicle.
NOTE Do NOT activate the track adjusters once the fastening hardware is removed.
  1. Installation is the reverse of removal.
Fig. Disconnect the wiring from under the seat
Fig. Seat track mounting hardware locations-typical
Fig. Bench seat components: seat (1), nut (2), stud (3), floor pan (4), bolt (5)-Ram
Fig. Split bench seat assembly-Ram
Fig. Bucket seat mounting components-Durango shown
Fig. Rear seat removal/installation
I hope help you with this; good luck (rated this help).
Aug 31, 2009 | 1996 Dodge Ram 1500 Club Cab
SSHOULDER HARNESS SLOT QUESTION FOR REAR FACING IN RADIAN 80
You can use any slots on the Radians for Rear facing so long as there is still at least an inch of shell above the child's head.
Aug 01, 2009 | Sunshine Kids Radian80 Convertible Car...
How do you install the car seat for rear facing?
Hey Just posting this for future reference for other people since I see that you posted over a month ago :) ..
To install the car seat in rear facing I used the latch system. (you can use the latch system if your vehicle has latches..they are tiny metal bars in between the seats)
First of all with this dumb car seat I found out that the latch system was not in the proper place so if you find that yours is not where the diagram shows (in the manual) then you'll have to take off the seat cover and manually put them in their place. Then go ahead and clip onto the latches in the rear facing position. If the car seat is too far forward then inline the seat. If the car seat is still not leaning far enough back to be level with the ground (there should be two level marks on the top/side of the car seat) place a rolled towel (or roll a 2x4 in a rolled towel like i did) then clip onto the latches. Hope this helps someone.
Nov 22, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
Alpha Omega Elite
I haven't seen a video for it, but I'll try to explain it clearly. To install it with the LATCH system, locate the anchors in your car - U shaped metal anchors in the seat, where the back meets the bench part. See your car's owner's manual - many cars don't have LATCH in the middle of the back seat, so you'll have to install it in a side seat or use the seatbelt to install, instead. Recline the carseat all the way - there is a handle under the harness adjuster on the front of the seat. Pull the handle while pushing back on the top of the seat. Tuck the top tether strap under and hook it under the base or the seat - it's only used when forward facing and is dangerous if left flapping. Pull the seat cover off of the front corners of the seat. Thread the black latch belt through the rear facing belt path (the holes on the bottom front of the seat - there should be a sticker identifying the path), making sure that it does not twist and is behind, not over or in front of, the **** strap, but in front of the the slots that the bottom of the harness straps go through. Replace the seat cover. Put the carseat where you want it in the car. Look to see that the level lines on the shoulder belt positioning guide are level with the ground. Double check that the top tether is secured underneath the seat. Fasten one latch hook to the anchor in your seat, going from above the anchor, so that the clip part of the hook is on the bottom and the solid side is on top. Repeat on the other side. Kneel in the car seat to push it firmly into the seat while pulling the strap tight through the adjuster. The seat is installed tight enough when you can grab it at the belt path and can not move it more than 1 inch side to side. It is normal to be able to pull the top of the seat towards your car's seat back some. To install it with a seatbelt - (Please note - you can only install with the LATCH system OR the seatbelt - doing both together increases the stress and force on the seat and can damage it!) Recline the seat and secure the top tether as above. Place the seat in the car and make sure that the level lines are level with the ground, as above. Thread the seat belt through the rear facing belt path (again, the holes on the bottom front of the seat...look for the sticker). Thread it under the seat pad. Like above, it should go between the bottom slots for the harness and the **** strap. Buckle the seat belt. Kneel in the seat, pull the seat belt all the way out from it's feeder, and feed it back in, pulling it as tight as you can. Check for tightness as above. While your child is rear-facing, the harness should be in a slot that is even with or below his shoulders. Pull it snug - when it's tight enough, you shouldn't be able to pinch up any slack lengthwise at the shoulders or hips and it should lay in a straight line without any sagging. Make sure the chest clip is even with the baby's armpits, not over the neck or the belly. Good luck!
We're having trouble installing the Embrace Infant Car Seat 5391732 - Evenflo Eurotrek Travel System into our Audi sedan. Although we double belted it at the foot end, the base seems to just rock back and...
I had the same problem in my 240sx Nissan, I was told that because of the dip in the seat it was impossible to fasten it down properly so I went to one of those help for car seat classes that the police help you with and they told me just to take a towel and tightly roll it up and put in the dip of the seat, then fasten the base down! Hope this helps you!
Aug 02, 2008 | Evenflo Embrace
Evenflo PortAbout 3 Logo
78 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
Vic Fkiaras
Level 1 Expert
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
