Question about Pioneer SD-643HD5 64" Rear Projection Television
Tv will not power on have pioneer sd643hd5 will not power on replaced to relays on main power board did not work what else could i try please e mail me charlichoppy@yahoo.com
  • 10 more comments
  • charliechopp Feb 02, 2009
    no problem with board and to much money i have complet repair manual need help troble shouting please
  • charliechopp Feb 03, 2009
    checked for cracks did not find any thing the flyby transformer is something else i heard what is the part number
    yes i have all 209 pages of service manual all i have is a fluc meter have some basic under standing of electric beter with cars im a machanic so please bare with me thank you and should i put it all back together for testing with power on thanks
    yes i have all 209 pages of service manual all i have is a fluc meter have some basic under standing of electric beter with cars im a machanic so please bare with me thank you and should i put it all back together for testing with power on thanks if you need me to e-mail manual let me know
  • charliechopp Feb 09, 2009
    not power board got it to go in stand by mode led d-111 comes on think it is in the deflection assembly any more ideas
    all fuses are ok
    sent a copy of my email there is a link on it for the manual
    also checked diode 4 on deflection board for high anod signal checked ok led stiil on also only have 5volt refrence on standby nothing else any where
    already checked that no problem on power board on the deflection board goes in standby
    already said the fuses are all ok
    fuses good
    where is the flyback transformer on the circut board if you are the one how got the email with the diagram
    Sergeant:
    Champion:
  • 289 Answers
Hi..There are two reasons which will will lead
to this issue.one is the soldering problem in
the board which you need to check it carefully
and the other one is the power supply loose
connection.This will be one of the reason.
check this out..
thank u..
Posted on Feb 09, 2009
  • Hariharanath V Feb 09, 2009
    hi..the best solution to this problem is by checking
    the circuit board.
    try this out..
    thanks..
  • 744 Answers
Hi sir... it might be  the problem in flyback transformer on the power supply board..try to unplug the cables mark them and be careful.use a jewlers flat head scewdriver to unlock the cables.use a can of compressed air to clean off the dust.
thank u..
  • Prakash Ram
    Prakash Ram Feb 09, 2009
    hi...If you experience the symptom of the TV powering up briefly, then switching to standby mode, leave it in this state! Open the back panel and locate the power module in the middle. There are 2 LED's that will light up to indicate the failure.
    LED D107 - failure in power supply assy
    LED D111 - failure in deflection service assy
    If it's LED D111, there is a subsection to check for fuses. If the fuses are blown it has the following table:Too high loading on the CONVER. AMP
    Check that waveform signals are output from Pin 3 and Pin 1
    of the CN401, CN402 and CN403, and that the DC element is
    not added to the signals.
    IC401, IC402,,
    try this out boss.....
  • 217 Answers
Have you tried replacing the fuse???
  • 1,800 Answers
Check the Whole Power Supply IC.
using the multimeter: check the continuity on the board.
u will find out the defective part.
  • 2,296 Answers
If you send me a copy of the service manual to jah2mil@hotmail.com I will help you troubleshooting it. If the vertical section fails, normally the TV would not power ON.
Posted on Feb 03, 2009
  • 11,896 Answers
COULD BE FLYBACK
Possible power supply capacitors shot.
could be caps on hyperboard
here is a link to your part #'s
http://parts.pioneerelectronics.com/model.asp?modelNum=SD643HD5
  • Nate Stansfield
    Nate Stansfield Feb 03, 2009
    http://www.hometheatershack.com/foru...e...
    The fix is almost always the IC's, possibly a few resistors and/or
    fuses. Once in a while the DCU, but you need to try the IC's first.
  • Nate Stansfield
    Nate Stansfield Feb 26, 2009
    A method of forming a surface mount transformer. The method comprises winding insulated wire around a magnetic core to form at least one secondary transformer coil, winding insulated wire around the magnetic core to form at least one primary transformer coil, attaching wire ends of the at least one primary coil to at least first and second vias of a printed circuit board (PCB), attaching wire ends of the at least one secondary coil to at least third and fourth vias of the PCB, affixing the coils and the magnetic core to the first side of the PCB, and attaching the coil wire ends flush to a surface of the vias on the second side of the PCB.
    Sergeant:
  • 326 Answers
Some Projection TV's has a small round fuse in the back inside by thepower cord. This fuse may be blown out.  Before removing the back cover be safe and unplug the TV. Also if the inside is dusty take a duster and blow some of the dust out.
Posted on Feb 02, 2009
  • Pioneer Master
  • 19,396 Answers
If you have no power at all (not even led on tv), then the fault is on PSU board.
Try first testing the resistors near to where the AC cord hooks up, reading impedance with your multimeter.
If they are fine, inspect the capacitors on power board, and look for bulged or leaking ones, they are frequently cause for this kind of problem.
If still no luck , then replace the power board.
Things are different if you get TV light on but no raster, in that case it is not necessarily the power board. In that case you will need to follow troubleshooting diagrams on s
ervice manual.
In that case start testing deflection circuits, convergence board, and the small AC board powering the lamp, that are delicate parts frequently involved on common faults.
You can find replacement parts here.
  • Ginko
    Ginko Feb 13, 2009
    Hi there ,
    the flyback transformer is normally attached to CRT tubes. However this TV does not have a part properly called flyback transformer.
    CRTs in your TV are powered by small boards called ballast boards, and this is one of the parts you need to check.
    You find the whole part list for your TV here:
    SD-643HD5
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Foremost to consider would be getting access to a service manual or at the very least a schematic diagram, the purpose of which is to have reference when performing voltage checks. This would make the diagnostic more reliable than mere suspect. With this way, it may be determined that the relay was not faulty but rather the driver transistor of the said relay or the filter capacitor of the B+ supplying the relay. Additionally, it may be determined if the transistor activating the relay could also serve as an interlock with the auto-protect system.
Pls post back if you have access the either the service manual and/or schematics.
Good luck and thank you for using FixYa.
  • Louie  Role
    Louie Role Feb 03, 2009
    If you were referring to my post, then appreciate the feedback.
    For starters, think of the flyback as the ignition coil, the HOT (horizontal circuitry) as the CDI, the PSU as the fuse box (a little more complicated) and the protection circuitry as the alarm/immobilizer.
    Likewise appreciate the offer to email the manual. Perhaps to your advantage (to keep your email private), pls email premium.support@fixya.com and inform them that you would want to send the manual to whoever expert you would want to.
    Cheers.
  • 6,784 Answers
Check to see if there has been a solder break on the power supply circuit board. these breaks can be tiny but, if it occurs, your TV will not power up. also, check the solder connections on the back of the switch as well. breakage can occur here as well.
  • Michael Masters
    Michael Masters Feb 09, 2009
    i would look at the actual plug and plug wiring solder point. this is where the power cord actually meets the power board. check for solder breaks there. hope that helps. and, check the power button on the tv for solder breaks as will.
    Genius:
  • 2,035 Answers
You can replace the whole power board assembly ..If you want the power board assembly please use this link:
Good luck...
Have a Pioneer pro elite 730hdi. When you try to turn it on (main power, not standby), the tv cycles from the red (standby) light with the normal click to the green light, then one second later, it cycles...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hoping this will help in solving the problem....
Aug 09, 2011 | Pioneer PRO-730HDi 64 in. Rear Projection...
Screen went black/won't power on
This is a common problem
The first step is to check the fuse on the power supply board. Next, disconnect the inverter board to eliminate the possibility of it shorting down the main and or power boards. Be careful as the inverter board supplies high voltage to the cold cathode tubes (backlights) and it bites HARD. If you disconnect the inverter and the power led comes up then replace the inverter board. (The screen will appear blank because you have no backlighting). If the power indicator still fails to light you need to suspect the main board first before the powwer supply board. The main board tells the power supply board to come on. You need to check the trigger from the main board to the relays on the power supply board. Also check the power connector to the main board because you should see +12V and/or +5V on at least some of the pins. If no power on the relay triggers then replace logic board. Then replace Power supply board last. Or buy a new monitor!!
Oct 26, 2008 | Mag Innovision M572TVs LCD Television
We cannot switch on our Pioneer PDP-507XD. The light at the front of the TV just blinks
First, remove the TV plug from the wall, fix it back in and try again. If that doesn't solve the problem, then it means your TV is having a power problem.
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Apr 01, 2011 | Pioneer PDP-507XD 50 in. Plasma Television
Pioneer plasma 50inch standby red light is on but tv wont turn on
Could be variety of reasons.
Service manuals usually say to check all standby voltages from the power board and then eventually try replacing the main logic board.
Some TVs have more than one standby circuits and there's a chance you have one of them working and the other failed...in that case you won't be needing a main board.
The bad news is I don't have the schematics for your model handy.
Still...hope this helps. If it does, please rate it :-)
Nov 06, 2009 | Pioneer PDP-5070HD 50 in. Plasma...
Pioneer 50 inch projection tv won't turn on
I only fine 5 fuse where is the 6 fuse locate? Please help I found the 5 on the power board... is the 6 fuse somewhere else not with the power board?
Mar 15, 2009 | Pioneer SD-P50A3Q 50" Rear Projection...
I have a Pioneer VSX-4800 receiver. My problem is that one of my relays is bad. I have replaced the power relay in it only to find out it was the other relay was bad. The problem I am having is finding a...
any relay will do just dont go below the ratings of what you found. the only thing is if you try to replace wityh another type then it might fit your board, you have to relocate then and rewire. what is the relay for? the main power switch for the trans or for the speakers? since you mention you replace one then later found out it is the other one, it thought you are talking about speaker relays. are your sure it is your relay?
May 03, 2008 | Audio Players & Recorders
Have a SD643HD5 Pioneer projection monitor... One quarter of the screen has a color convergence problem...Has been operating great for the past 7 years...
One of your convergence IC's have probably gone bad. This is a common problem after 5 years or so on that model (happened to my SD643HD5). You have a few choices:
1) Fix it yourself by replacing the IC's, by soldering new ones in. See this website for details:
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
That website also shows pictures of what the problem looks like.
2) Fix it yourself by buying a whole new convergence board assembly from Pioneer, part number AWV1892, for about $290.
3) Take it to a service/repair shop, and pay $300-$600.
Apr 22, 2008 | Televison & Video
Vizio model #L37
kNOBLE
VIZIO
L32
LCD
DEAD WITH AN AMBER LIGHT
Do Not Order A New Board For This Vizio Model. You Can Fix This Problem For Pennys. Problem: Will Not Power Up Amber Led Only. Hint: No Reset To Operate Micro (Brain Dead) I'Ve Seen (3) Various Fixs Below, One Uses A Diode, Other Uses A 10k Resistor, Try Either. All 3 Will Work, Diode Works Best For Me This Same Reset Ic Goes Bad On Other Visio Lcd & Plasma Tv'S. #1) You Remove Smd U26 On The Video Processing Board And (Add) Put A 10k Resistor Across Pins 2&3. U26 Is Near The The Tact Switch. #2) Remove U26 And Solder A 10k Tru 100k Resistor Across Pin 2&3. Start With A 10 K First. #3) Remove Reset Ic Near Tac Switch Replace With 1n4148 Diode (Nte519). Vizio Tech Support: (Valid - I Tried It) 1-888-849-4623 Opt 4 Technical Support: 888-849-4623 Try Extension 1669 (David). Hugo Carrera Parts Department 877-668-8462 Ext 1814 Vizio Inc. 320a Kalmus Drive Costa Mesa, Ca 92626 E-Mail:Hugo.Carrera@Vinc.Com
Mar 16, 2008 | Vizio L37 Television
No power at all. No amber light or green light. Power cord check out fine?? Work great then 8 hours later went to watch TV. and nothing. Any help out there ??
I've been hearing alot about the main power supply board with this model. Mostly I hear that when the power button is pressed, the relay inside will click but with no other response from the TV. This tells me that either the relay contacts are no good or that there are some serious soldering problems on the board. That would explain why it will operate for a short time then quit unexpectedly. Thermal cycling might be stressing the already weak solder joints causing intermittent contact. Personally, I'd love to get my hands on one of these boards.
If it were me and I had nothing to lose, I'd pull the main PS board and touch up the relay section by resoldering (as I believe it is more likely to have bad solder joints then the bad relay contacts). If anyone tries this with positive results, please let me know and rate accordingly.
Dec 29, 2007 | Vizio L37 Television
Pioneer SD-643HD5 64" Rear Projection Television Logo
42 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
