Question about Sanyo DS24425 24" TV
Sanyo 24" flat DS24425 suddenly turned off, won't turn on. Pressing the power button either results in no response or it turns on for a second, then turns off again. No picture. Already tried playing with cord connections and unplugging cord temporarily. Unplugging results in TV coming on for a second. After a few times of that, there is no response with the power button. What is shot? Thanks.
  • elmerjac Mar 07, 2009
    tv suddenly turned off and will not come back on
    Problem Solver:
  • 8 Answers
Solution to the won't turn on or turns on and turns off in 3 seconds thing...as my Ds24425 did.
First thing is very important...unplug the TV and let it set for 24 hours before you proceed.
The voltages inside a TV are EXTREMELY HIGH and LETHAL....so proceed with caution!
Place the set face down on a towel on a table and remove the back cover....hex screws around the perimeter and 1 phillips screw near the inputs.
The main board will slide up and out. unplug the degausing coil "white plug with two wires" and the speakers connector. This will make it easier to turn the board and take a look.
What I found with mine was a bad electrolytic capacitor. You can identify I bad cap "capacitor" by examining the tops of each one for bulging or signs of overheating "melted or bubbled plastic covering." The cap in question was C626 with a value of 1000uf, 16volt. I replaced with a 1000uf, 35volt and it works perfectly. The cap is located about center of the board. Carefully unsolder the cap and remove, make sure to install the new cap with the proper polarity...the board is marked with a dot indicating the negative lead of the cap.
Be sure to reattach the white plug and speakers connector and slide the board back into the plastic grooves. Then replace the back cover and test. Good luck! ...Daddio
Posted on May 24, 2009
Lightning struck near my house and now my tv is dead. Is there a reset button inside or is it shot? thanks, John C.
Posted on Jun 10, 2009
Will not turn on
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 21, 2014 | Sanyo DS24425 24" TV
Sanyo DS24425 turns on an then shuts roght off
Check plugs going to the lcd panel from the inverter board. Check ribbon cables going to the inverter board.
Nov 15, 2011 | Sanyo DS24425 24" TV
RCA universal remote
I programmed an rca universal remote by:
TURN ONTHE TV
HOLDING DOWN THE TV ANDTHEON/OFF BUTTON ATTHE SAME TIME.UNTILTHEON/OFF BUTTON STAYED ILLUMINATED.
PRESS THE PLAYBUTTON IT WILL BLINK,IF TV DOES NOT GO OFF PRESS PLAY EVERY 5 SECONDS UNTIL TV GOES OFF.
ONCE TV TURNS OFF HIT THE REVERSE BUTTON THE TV WILL COME BACK ON.
HIT THE STOP BUTTON TO SAVE THE CODE.
REPEAT THIS BUT HOLD THE OTHER DESIRED DEVICE INSTEAD OF THE TV.
HOPE IT WORKS
Igotthisinfo from google....then typed in rca universal remote...there was a sight for programming remote.
Jul 26, 2008 | Sanyo DS24425 24" TV
Tv not working .i tried un plugging. does not click or anything. ihad similar problem before they replaced tv . is this common?
It is not common , you must check your sockets where you have plug your tv. there are maybe loose connections!!
May 04, 2008 | Sanyo DS24425 24" TV
Sanyo DS24425 TV Has No Picture and Very Faint Audio
DONT BUY SANYO ELECTRONICS THEY ARE JUNK
Jan 09, 2008 | Sanyo DS24425 24" TV
Tv wont come on
i think it's the built-in power surge/failure sensor.  Plug the TV into the wall and press RESET on the remote twice.
Jul 07, 2007 | Sanyo DS24425 24" TV
Sanyo DS24425 24" TV has great sound and no picture(black screen)
if tv have black screen,increse screen control to see vert ic is defective,and if screen is white with lots of line acrose ,you can find open resister,on pic tube board,or in main board near transformer.
May 20, 2007 | Sanyo DS24425 24" TV
Sanyo DS24425 Intermittent Discoloration
It seems like this problem would have to be with the picture tube itself, although I have never run into this symptom in over 30 years of servicing TV's. If the CRT is still in warranty I would get it checked out. Otherwise it probably not be worth repairing. If you end up replacing the set, check out the Toshiba 24" model. I have had good luck with that model in the past.
Feb 11, 2007 | Sanyo DS24425 24" TV
Sanyo DS24425 24" TV Logo
446 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
