Question about Q-Logic QLT-.3508SS Car Subwoofer
Kicker L7 plastic faceplates
I need the plastic faceplates that holds the rubber around the speaker. I have a 15" speaker..
    Problem Solver:
  • 6 Answers
You will have to buy the whole cone replacment kit for that part or get from bad speaker. Both can be purchased on ebay or other sites.
Posted on Feb 06, 2009
I have a kicker 15 inch L7 solo baric and the rubber piece around the plastic part of the center of the sub has come apart from the outside black ring. how can i fix this?
You can purchase a silicone sealant set, specifically for speakers. Its quite easy to use. Ebay has alot of them and they are relatively cheap.
May 03, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I need the basket gasket for 15'' l7
The only way to get a new one is to contact Kicker directly, and see if they'll sell you one. Otherwise, you'll need to get another woofer. They only sell the replacement parts for the SoloX woofers. Sorry about that.
Apr 28, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
How to run the speaker wires to connect to the subwoofer? and does a sub woofer burn if you do not put the right ammount of watts to it for example having an kicker l7 connected to a three houndred watt...
i'm guessing you are having problems with the dual voice coil's so I will link you to the kicker wiring guide...
http://kicker.com/sites/default/files/SoloBaricL72006.pdf that has the wiring options, you will need a pdf reader **** as adobe or foxit..
Under powering your subs won't hurt them but running a 15 inch l7 at 300 watts is not going to let the sub perform at peak, I would go with a 800 to 1000 watt amp.
15 inch l7 watt's are as follow
rms = 1000
peak = 2000
Mar 16, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I have a 2004 toyota corolla would i have enough air space for for to l7 15in or im i better off getting 12's
you have enough air space for 1 L715 or 2 L7 12s the 12s will move more air and hold more power than 1 L7 15 inch sub
Jan 27, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
SPEAKER BLOWED
IF IT IS COST EFFECTIVE, YOU WILL NEED A RECOIL AS IT SOUND LIKE IT HAS OVERHEATED AND COIL GONE DUFF
Dec 18, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Hi there I have a problem with my kickers. Subwoofer l7 15" is blow,I was wondering if there is a repair kit avaible for it or not?
The only Kicker woofer that has a replacement cone/assembly is the SoloX woofers. All of those have what Kicker calls it's SPARE which is a field replacement assembly. They're designed for SPL competitions.
Nov 05, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I wanna know if a 1500.1 amp good for 2 15'' kicker L7 solobarics
yes but you might get better results from it if you wire it for use on 2ohms
Oct 13, 2009 | Car Audio & Video
How do i rebuild a set of solobaric l7 subs 15s
you have to remove the rubber surround holding the front of the subwoofer to the metal frame.the voice coil is a coil of copper wire.you should be able to get it through kicker.its not the easiest thing to do i recomm seeing if kicker can rebuild it for you or try a local speaker repair shop theres not alot of them but you can find them.first get the rebuild kit if your going to do it.it should show you everything you need to do. if you need more help let me know bertman285@hotmail.com
Oct 08, 2009 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
Kicker zx750.1& two 15"kicker solo L7 2ohm
if the amp could handle 1ohm paralell would work if not they wire in series
Apr 08, 2007 | Kicker (ZX750.1) Car Audio Amplifier
Kicker l7
That is called a suround my freind. depending on the exact size of the foam surround they are available with good instructions at many many places that do speaker repairs on-line. Heres one I have used in the past http://www.simplyspeakers.com/2doityourself.htm?src=overture Like I said there are tons of them available on-line. Simply search for speaker surround repair. Good Luck Please do not forget to rate this thread.
Dec 15, 2006 | Kicker Solo-Baric L7 12'' Car Speaker
Q-Logic QLT-.3508SS Car Subwoofer Logo
235 people viewed this question
Top Q-Logic Car Audio & Video Experts
xxxxxx xxx
Are you a Q-Logic Car Audio and Video Expert? Answer questions, earn points and help others
