Question about Behringer EUROPOWER EP2500 Amplifier
Amp keeps blowing speakers
Will at a job amp seemed liked it spiked and blew both woofers grant you the were technical pros boom 215 rated at1650 watts the amp is behringer 2500 second pair its happend to its costing more money than im making
  • 1,175 Answers
If the amp blew the speakers , it sounds like the amp pumped HIGH levels of DC voltage into the speakers.
Get another amp and not Behringer,not Pyle,not Gemsound and not Numark.
Posted on Feb 02, 2009
I have an technics su-g75 and all of a sudden I lost all sound from the bass speakers I only have treble and mid tones that play out of my speakers
As far as I know, that model doesn't do biamp functions, so it wouldn't be the amp being the problem, although it could have caused the problem with the speakers. I suspect you have blown your woofers. It's odd if both L+R cabinets went at once, which leads me to question weather the amp send a subsonic signal to cause the failure. That assuming you weren't playing more loudly than the cabinets were rated for. I suggest checking the woofers for being b lown, and then taking the amp to the shop for a checkup.taking the amp
Jan 22, 2016 | Technics Audio Players & Recorders
Something blew-up in the speaker cabinet. it turns out it's the protective lamp overload. May I know if you carry that? Thank you
Usually that lamp part ONLY protects the tweeter. If the woofer doesn't generate sound, then you probably blew the speaker as well. This speaker is rated at 250 Watts PROGRAM... that means your amp you drive this with should be no bigger than about 150 Watts RMS or you can blow the speaker. You should be able to get reasonable sound for a 20 foot square room with this unit.
Aug 09, 2011 | Samson RS12 HD PA Enclosure
Hi, we moved the sub woofer from its original position and now it keeps blowing fuses. I would like to repair the sub woofer, as it works well and is quite new. I live on the south coast of NSW...
Where was it sitting before it was moved? Did it have it have more ventilation and keep cooler? This sub has a powerful amplifier in it. If it got moved to an area that restricts air circulation around the sub more it is possibly overheating and causing fuses to blow. Put a fan on it and make sure it is on a hard surface or up off the carpet at least to keep the bottom side cool as well. Also when one moves a speaker it's often to put it into a more convenient area to be able to turn it up louder with less disturbance to others. This will draw more power and create more heat within the amplifier than it's previous location. If this is so keep it as cool as you can and turn it down every so often to give the amp a rest. The key here is to keep it cool as you can. One thing you never want to do is put a higher rated fuse in than the unit is rated for. Always use factory recommend fuse rating.
Mar 22, 2011 | Klipsch Synergy Sub-10 Subwoofer Speaker
Fuse Keeps Blowing
disconnect rca and speaker wires if they still blow you may have a problem with amp
Jan 17, 2010 | Volfenhag ZX-8400 Car Audio Amplifier
Keeps blowing fuse in woofer
Seems like the wires inside the woofers are crossed. Open the sub and make sure that there are no bare wires touching. If everything seems OK then the circuitry inside is blown.
Dec 13, 2009 | Infinity TSS-1100 System
Klh powered subwoofer keeps blowing fuses?
then the circuits took a hit and the fuse didn't do it's job in the 1st place. best is too get new circuit thats inside the sub woofer.
sorry to be the bearer of bad news
Apr 26, 2009 | KLH BB-II Subwoofer
Peavey impulse 1015 horn cuts in and out
If the horn cuts out after some usage ...then its probably the limiter lamp that is gone .... the limiter lamp is switched into circuit once the " polyswitch " gets hot .... so at first the horn works ...then when the limiter lamp is switched in ...nothing !
its just a standard 12volt car tail light lamp ...let me know if this helps
Jul 27, 2008 | Peavey CH1 Speaker
Speaker Hook Up - Non-Technical (single) Female
bought the same amp second hand and had same problem as there are two seperate amp chips inside one for front speakers and one for the centre and rears it could be the actual amp chip that drives the front speakers has died as there is no built in speaker protection so over driving these speakers will result in the amp chip blowing . it may be something simple but it was not on mine had to buy new amp chip and solder in that sorted the problem for me !
Jun 02, 2007 | Technics SA-DX950 Receiver
Behringer EUROPOWER EP2500 Amplifier Logo
176 people viewed this question
Top Behringer Audio Players & Recorders Experts
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
