Question about Roper RT21AKXKQ Top Freezer Refrigerator
Loud compressor what can i do to fix a loud compressor? and If I cant fix it How difficult is it to swap out compressors?
    President:
  • Roper Master
  • 2,651 Answers
Othjer then trying to reposition your compressor( shimming under a grommet) there is no way to "quiet" your compressor, and it is something tha can ONLY be changed out by TRAINED REFRIGERATION TECHNICIAN
Posted on Feb 03, 2009
Frigidaire fac127s1a is really loud - 70db+ - any fix available?
You might be able to find a sound insulating blanket that wraps around compressor. Check with a Carrier or York dealer. Most brands use the same compressors so you might be able to score one.
Jul 02, 2014 | Intertherm P3RC-042K Air Conditioner
Air compressor makes loud knocking nois when running
remove shroud and see if fan is broken but may be piston is shot
Apr 10, 2013 | Craftsman 33 gal Air Compressor 6 hp...
Loud buzzing
What is the model number of your unit? If you look at the compressor (back of unit big black bulb looking thing) do you see a picture of an indian on it?
If your compressor looks like this (techumseh compressor) then you almost certainly need a new compressor.
Mar 13, 2013 | Refrigerators
Constant loud noise when frig turns on/comes from bottom
when the compressor is running unplug the ref. and if you hear the noise coming from the compressor then
a ballance spring may be broken inside the compressor.
The compressor will run normally with a broken spring it will just be annoying when it shuts down.
Jan 16, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Compressor in Honda makes loud noise
I THINK YOU WILL FIND THE CLUTCH BEARING IN THE FRNT OF THE COM PRESSOR HAS HAD IT .800-900 DOLLARS SOUNDS LIKE AREBUILT EX CHANGE UNIT OR POSSIBLY ANEW ONE ,I WOULD LOOK AROUND FOR SOMEONE TO JUST FIT ANEW BEARING. IT CAN BE DONE THE OLDER TOYOTAS AS I HAVE DONE IT BUT THEY ARE RIGHT IN SAYING YOU CANT LEAVE IT "YOUDOIT"
Oct 23, 2009 | 2004 Honda Accord
Kenmore top freezer, Refrierator shuts off with loud clunk.
It sounds like you may have a compressor that is working hard against high pressure due to a dirty condenser or a condenser fan not running or blocked. If all is well otherwise, the mounting springs inside the compressor may have broken or are weak. The only fix then is a new compressor.
Jun 22, 2009 | Kenmore 64802 Top Freezer Refrigerator
Compressor of the Ruud A/C outside unit is making unusal loud continuous noise. I open the case, its not the fan or fan motor, loud noise is coming from the compressor, and it is also heating up a lot....
OK, you will need to replace this compressor. the internal seals have ruptured, causing the loud noises. the heat is from the metal to metal friction. the compressor can be rebuilt but, it will be more costly than just replacing it with a new compressor.
May 27, 2009 | Ruud Handle Air Conditioner
Whirlpool top freezer refrigerator- compressor makes a loud noise
The compressor is that black casing you see at the bottom of your refrigerator - inside this sealed case is the motor assembly which stits on 3 or 4 springs that act like a cushion - you have a little gap at the bottom where the lubricating oil is present. Your springs have likely worn out and when the compressor shuts off the assembly is banging against the rigid casing make that loud "klonk" or bang noise. It IS normal for compressor to make some faint "tick-tick-tick...tick.....tick" when shutting off, but loud banging, bell sounds, etc, means the assembly is banging on the case from the inside - you can indeed live with the noise, your compressor will function normally, probably for months, or even years - it can also keep wearing out and one day the noise might get very loud (like a very high humming noise) - There is NOTHING that can be fixed, you either pay $400+ to change the compressor or buy a new refrigerator - If you DO replace a compressor usually the replacement will be noisier - Keep a thermostat inside your refrigerator at all time to make sure your compressor is still keeping your refrigerator and freezer cool.
Mar 20, 2009 | Refrigerators
Loud fridge compressor stays on loud
HI!!! You sem to have a problem with your compressor .The windings are going out..If the frig has a run capacitor change it and see what happpens.If it is still loud then you have compressor problem..Good luck..
Jan 22, 2009 | Refrigerators
Refridge makes a loud noise
are you sure it is the compressor making the noise and what sort of noise is it. if it is the compressor, there is no cure except replacement which is not diy.
Mar 27, 2007 | Hotpoint HTR16ABSR Top Freezer...
Roper RT21AKXKQ Top Freezer Refrigerator Logo
143 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
