That's correct the is going to be no problem at all to install a new HDD inside of the netbook will be like any other computer so parts are exchangelable, so don't worry just make sure to buy a HDD that matches the space inside of you netbook, and make sure that if you're installing the HDD on your own, to take a look into where's the HDD connected they usually have an adapter to plug them in. Best regards, Luis!
If the hard drive have crashed meaning that the hard drive itself is damaged, then your solution is to replace a new harddrive. If you do have a recovery disc already made, or one is provided then you will have to use that disc once the hard drive is replaced with the new one, and follow the procedure to reinstalled the operating system. If the original hard drive had crash and does no work anymore (where the bios/computer cannot detect it) and you have important data that you would like to retrive, there are places such as office depot, bestbuy, where they can help you send it to a recovery file center to recover files from your damaged hard drive. Do not attemp to fix or open a damaged harddrive, you can forever damage the files on the cyclinder disc. 2) Now if your harddrive crash in term as windows just crashing and you cannot get into your operating system and the bios is still able to detect the hard drive, and it's giving you a error message, then you will only need to reinstall, or do a windows recovery through your recovery disc, If you do not have a recovery or made the disc, then you will need to buy a new operating system software. If you computer does not start meaning no display on the screen at all, then please replay back. That is a different story.
I'm sorry to say this but these are signs of your computer's hard drive crashing. Hard drives (from what I've been told by other experts) typically crash after about 4-6 years of intense use. That's why I always recommend people backing up their important files every year. This has happened to my laptop before, I've had the same symptoms.
Now what about your files?
Well if you're lucky, you can ask a Geek Squad rep. from Best Buy or anyone else with proper experience to try to salvage your hard drive. Anyway you'd have to buy a new hard drive and replace your crashed one.
Solution: Take your computer to an expert to help you recover your hard drive files and replace the hard drive.
you may try to insert your hard drive to an external hard drive casing then plug it to a pc as an external drive then check if it can still be detected. From there you can copy the files to the computer.
Nope, it's just a matter of pulling the old hard drive and putting in the new one. Sometimes there will be an adapter attached to your old drive that you'll have to transfer over to the new one. What you need is a 2.5" mobile PATA (IDE) drive.
if u have new harddrive then simply first remove crash harddrive from computer . Then if u have sat harddisk connect it with sat cable . I fu have ide harddisk tehn connect with ide data cable. simply.
You can do installing new windows on it, Insert your windows bootable disk in CD/DVD ROM and boot in it, and you can do formatting and then installing windows.
Installing windows please refer to this site for more info.
