Question about Lexmark X5150 All-In-One InkJet Printer
Wont print from online screens
My printer wont print when i am online but when i save and print it will print..my printer is set to default and it online too..
  • 65 Answers
Im going to assume you are using Internet Explorer. You might try to update to IE 8 or event changing Browsers to Firefox just to try this out. I have found that MS has identified some issues with IE and some PCs and printing. Here is their document.
http://support.microsoft.com/kb/303360
Posted on Feb 02, 2009
Lexmark 3600-4600 stops at 34% when trying to print a test page. Color ink is low, but I only want black in any event.
If your color ink is already empty or not substantial for printing, then you must replace it with a new cartridge. The Lexmark printer will continue to print when there's substantial ink in the cartridges.
If you prefer to print in black and white as your default print setting, please follow the steps below: (make sure your black and color cartridges ink levels are good)
For Windows OS:
1. Go to Control Panel.
2. Open Printers and Faxes.
3. Right-click on Lexmark 3600-4600 Series print object and click on Properties.
4. In the Lexmark 3600-4600 Series Properties window, go to Advanced tab. Click on Printing Defaults.
5. In the Lexmark 3600-4600 Series Printing Preferences window, under Ink Use, select Print using black ink only. Click OK.
6. Click OK button in the Lexmark 3600-4600 Series Properties window to save the changes.
Your printer will print in black and white draft mode the next time you send a print job to the printer.
For Mac OS:
1. With the file (you wish to print) open, go to Print. A window will pop up.
2. Select the Lexmark printer.
3. Expand the arrow pointing down beside printer name if you're not able to see other options for printing. Look for Quality and Media.
4. Under Paper tab, select Print in Black and White.
5. Save this as your default print setting. Click Presets option and choose Save as. You can personalize the name for this default print setting (e.g. Black and White Draft or My Setting).
Select this Preset name every time you print your files/documents.
Aug 31, 2011 | Lexmark X4690 Wireless InkJet Printer
Can I adjust the darkness of the print?
Make sure that the printer is not in "economode"
Change the density to a higher number. 3 is the default.
Press the ONLINE to take printer offline
press MENU until CONFIG MENU appears
press ITEM until DENSITY appears
Press + or - to select setting
Press ENTER to save setting
An asterisk(*) appears to indicate you setting was saved
Press ONLINE
Print about 20 pages to make sure that your setting stabilized
Jan 04, 2011 | HP LaserJet 4 plus Printer
It wont print even thought it says ready
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Oct 27, 2010 | HP Deskjet F335 All-In-One InkJet Printer
Wont print
  • Connectivity :
Oct 26, 2010 | HP DeskJet 712c InkJet Printer
I've just instal a new ink cartirage but each time i press print, microsoft document appears for me to save the document without the printer printing help please
well theproblem for you is that your printer is not selected as default printer and some other printer is set as the default printer
follow these steps please :
1.go to the printers page
2.right click on the printer icon that has the name ending with series and has the name of your printer .
3.click on set as default printer
after that
again right click (right) on the same printer icon and select the option -USE PRINTER ONLINE
and then try to print it should fix the problem
cause: since you had the fax of your same printer set as the default so it was printing but to the file .
hope this should be the resolution for your issue
Thanks
Regards
Hamid
Feb 23, 2010 | Office Equipment & Supplies
Cannot change/ save two default settings on X6570 Lexmark printer
you can go to printers and faxes (XP) or printers (vista) in control panel Right click on the printer and click on properties. Go to advanced tab and click on printing defaults. It will pop up the printer printing preferences. choose the desired setting. To disable 2-sided printing, go to advanced tab in the preferences window and turn off the feature. Click ok to save all settings. Go back to general tab and click on printing preferences and set desired settings if there is a need. Click ok to save settings. Then, for all changes to take effect, click ok button on the lexmark 6500 series properties window. Try to print again. Hope this helps.
Feb 17, 2010 | Lexmark X6570 InkJet Printer
Printer always says its offline even though its on and connected
If you are Windows XP Operating System, perform the steps below:
1. Click Start --> Printers and Fax.
2. Right click the printer icon and check the following:
a. Check whether the All-in-One is set as default printer.
b. Ensure that the there is a check mark on the "Use printer online". If you have the Use printer offline, make it online by selecting the option.
c. Ensure that there is no check mark on the Pause printing.
Check for the default printer and USe printer Online in the printers and faxes folder.
Click Start -->> Control panel -->> Hardware and sound-->> Printers-->>Change default printer. ---> Please Right Click on the printer icon which has tick mark and Select the options Use printer Online and Set as Default and also Select the option Resume printing.
Sep 30, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
How can I permanently alter the Default Print Settings?
In the control panel, you can select your printer and set defaults. You can also set them in your printer's setup & maintenance program.
Jan 31, 2009 | HP PSC 2210 All-In-One InkJet Printer
Printing issue
In order to proceed with the solution to your problem, we'll need to save the current settings on your Crown printer and then restore the printer to its original factory settings as shipped. Your current settings will be saved, and can be restored after we finish this troubleshooting session. You will need to access the printers front panel in order to perform the following settings.
Procedure to save your current printer settings
Procedure to restore printers original factory settings
Procedure to restore your saved printer settings
1. Make sure the Online light is lit and that the display reads Idle.
2. Press the Online/Offline button to take your printer offline.
3. Press the Menu button once. The display should read Operator Control.
4. Press the Right Arrow button once. The display should read Administration.
5. Press the Select button once. The display should read Communications.
6. Press the Left Arrow button until you see Miscellaneous in the display.
7. Press the Select button once. The display should read Save Defaults.
8. Press the Select button again. The display should read No.
9. Press the Left Arrow button once. The display should read Yes.
10. Press the Select button.
11. A few seconds should pass until the display reads Yes Is Selected.
12. Press the Online button twice to take the printer online while the display reads Idle. Your current printer settings are now saved and you are ready to proceed with returning the printer to its original factory settings.
6. Press the Left Arrow button until you read Miscellaneous in the display.
8. Press the Right Arrow button. The display should read Restore Defaults.
9. Press the Select button once. The display should read Factory Defaults.
10. Press the Select button again. The display should read No.
11. Press the Left Arrow button once. The display should read Yes.
12. Press the Select button. Yes Is Selected will appear in the display.
13. A few seconds will pass and the printers display should read Disk And Flash Sys Loader.
14. Your printer will reboot with the original factory settings and return to Idle.
Try a test print. Does the problem still exist?
10. Press the Right Arrow button. The display should read Custom Defaults.
11. Press the Select button. The display should read NO.
12. Press the Left Arrow button once. The display should read Yes.
13. Press the Select button. Yes Is Selected will appear in the display.
14. A few seconds will pass and the printers display should read Disk And Flash Sys Loader. Your printer settings are now restored to their original saved settings
Try a test print, does the problem still exist?
Sep 24, 2008 | Minolta magicolor 3100 Laser Printer
Lexmark X5150 All-In-One InkJet Printer Logo
54 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
