Question about Brother IntelliFAX 5750e Laser Fax
I want to use my brother 5750e to scan into word in my PC
I want to scan school work into my PC to word. I am new to computers, it runs vista
    Champion:
  • 320 Answers
FIRST OFF . DO YOU KNOW IF YTHE SOFT WARE CD THAT CAMEW WITH THE MACHINE WAS INSTALLED? THE MAQCHINE WILL NOT RUN ON VISTA UNLESS YOU GO TO BROTHER .COM AND DOWN LOAD THE PATCH FOR VISTA, WHILE YOU ARE AT IT DOWN LOAD THE MANUAL AND IT WILL TELL YOU STEP STEP HOW TO USE THE SCANNER GOOD LUCK
Posted on Feb 03, 2009
Can u sed me user manual
Brother IntelliFAX 5750e Laser Fax User Manual
Download and save the above file for future reference.
Also, Click here for Drivers, Installation Instruction and FAQ etc from Brother Official Support.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 31, 2010 | Brother IntelliFAX 5750e Laser Fax
I have the Brother MFC-240C printer connected to by laptop. I have Vista 64. The printer works but I cannot scan, it says connecting to computer but nothing ever happens. What do i do?
First do you have the full software installed? Select your version of Vista (32- or 64- bit) here: http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc240c_all
If you attached the USB cable to the computer and the printer before installing the full software, uninstall the generic driver that you have running and then unplug the USB cable before installing the full software. (Generic OS drivers often only run the printer on an all-in-one.)
Next replace the USB cable (scanning requires bi-directional communication and thus can fail when the printer works). If you have a USB hub or print server, try a direct connection. Try starting your scan from the computer. (Launch the software (PaperPort SE) and hit the scan button, if your installation CD had a Vista compatible version. Otherwise, try to scan in Paint (File > Import from Camera or Scanner) or Windows Fax and Scan (New Scan))
Next make sure that the monitor program is running if you want to launch the scans from the unit. This is the ControlCenter 3 - and you need to set the destination buttons for the scanner in the software. Look for the Device Button tab for each of the scan icons in the software.
I hope this helps.
Aug 01, 2010 | Brother Multi-Function Center MFC-240C...
Received blank pages. Could this happen if the
Make a copy of something to be sure. It will tell you when you are low on toner
Feb 04, 2010 | Brother IntelliFAX 5750e Laser Fax
Brother IntelliFAX 5750e Laser Fax Machine Error 71, anyone know this and know how?
that error points to your laser unit. chances are 99% that its bit the dust. a tech will have to service it and replace laser unit. thats the only option other than just buying a new fax.
hth,
razors
Apr 15, 2009 | Brother IntelliFAX 5750e Laser Fax
How do i get my brother 5750e to print to the front tray
There is a flap (for the lack of a better word) in the back that when pushed down routes the prints to the front tray.
Jan 20, 2009 | Brother IntelliFAX 5750e Laser Fax
Roll over fax
Buy a double RJ-11 adapter, plug it into the LINE port of the main fax machine.
Run the phone cord from the wall jack to one side of the adapter and run a seperate phone cord from the other side of the adapter to the LINE port of the second fax machine.
Dec 19, 2008 | Brother IntelliFAX 5750e Laser Fax
Outgoing faxes are black
Check first all settings, unplug the scanner to reset settings.
Try doing a scan, if the scan is black as well, you need to have the lamp or the array sensor replaced.
If scan is ok, then it is a communication problem probably a fault on the internal main board.
Dec 15, 2008 | Brother IntelliFAX 5750e Laser Fax
Hello, Our Brother 5750e is displaying an error code of 7C. Is this a coomon problem and is there anything I can do here in house to remedy it. I have checked the manual and there is no explanation for...
worst case scenerio is your engine board has gone bad. first though, try a new brother brand DR400. a faulty/binding drum unit can cause this. usually happens with generic brands.
hth,
razors
Dec 10, 2008 | Brother IntelliFAX 5750e Laser Fax
Installation of seperation rubber - Brother Intellifax 5750e
Pull open the document feeder.
Remove one screw on the chrome plate, pinch the legs of the pad holder to remove.
Sep 29, 2008 | Brother IntelliFAX 5750e Laser Fax
Scanning into OCR using a Vista PC
Try using the WindowsXP driver directly, click on 'continue anyway' and see if that works.
Do you have more information or questions?
The more information you provide to us, the better we can help.
Thanks!
Dec 11, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother IntelliFAX 5750e Laser Fax Logo
96 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
