Question about Sony PlayStation 2 Slimline Console
Over Charge! i connected my ps2 to my laptop AC adapter it explode in some little smoke and flames i found the regular charge connected it and now it works fine just that the disk won't spin so now i can't play anything, i would like to know if there is any part i need to replace?
  • 80 Answers
I agree with king. It sounds like you fried the motor. I think that might be the only thing you have to replace outside of your pride for using a completely different charger. While the connector might be the same, the output may have been totally different and allowed to much power to flow to the console.
Posted on Apr 05, 2009
  • 24 Answers
Well i think you may need to replace the cd part of your console the hole part cause when you put the other charger to it you may have blown the motor for the laser
Posted on Mar 05, 2009
BROOKSTONE HDMI PROJECTOR 801143 DOES NOT CHARGE
The Brookstone manual claims it will fully charge after 3-5 hours, but it takes much longer then that. Mine does not indicate green light, but it seems it stops blinking red when its fully charged. After that it run on power directly from the ac-adapter.
If you keep it connected to the AC-adapter after it have stopped blinking red (do not disconnect it at all), it will start to run on the adapter and will not turn off. You will feel the AC-adapter gets hot while its running, something it does not while regular charging.
If it still dont stop blinking red after having it connected to power for 3 days, your AC-adapter is probably faulty. This happened to me, and after allot of research I found this replacement from a US seller on ebay (only five dollars included shipping).
http://www.ebay.com/itm/251623019268?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Good luck with your projector. It a really cool little thing, but it has some design flaws.
Best regards.
Feb 17, 2014 | Brookstone HDMI Pocket Projector
Dell m5110 laptop won't charge new battery and ac adapter is not recognized in bios
Try another AC cord/charger with the EXACT same specs as original. Is the battery a genuine Dell battery, if not return it? Some aftermarket laptop batteries don't play well with your computer, the pin-out connections aren't correct and MAY be a fire hazard.
Apr 06, 2013 | Dell Inspiron Computers & Internet
My hp ac adapter KEEPS FREEKIN BEEPING
Hello, NO it isn't going to explode, you need to replace the battery or the power cord it isnt charging or being charged.
Jan 16, 2013 | HP Original 90w Ppp012d-s 519330-003 Ac...
Is there a software that is associated with my sonny battery that will make it charge again
If you plug in your AC adapter to your laptop to charge the battery and get the "plugged in, not charging" message then try the following solution:
  • Disconnect AC adapter
  • Shutdown laptop
  • Remove laptop battery
  • Connect AC adapter
  • Power on laptop
  • Click the Startup Menu
  • Type Device and select Device Manager
  • Under the Batteries category, right-click Microsoft ACPI Compliant Control Method Battery and select Uninstall.
  • Shutdown laptop
  • Insert laptop battery
  • Power on laptop
    If you follow these steps and find that your laptop still does not charge then consider replacing the laptop battery itself.
    Hope to have been of assistance,
    Thanks.
  • Sep 14, 2011 | Sony VAIO PCG-K23 Notebook
    Cf51 wITH MOTHERBOARD dl3up1448aaa. When connected to the power supply smoke was seen coming form the power socket on the laptop. Disassembled the laptop and found just behind the socket on the motherboard...
    Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
    1. Removed the battery.
    2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
    3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
    4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
    Hope this will help...Thank you for using Fixya...
    Sep 14, 2011 | Panasonic Toughbook CF-51 Notebook
    My AC adapter suddenly can't seems to be able to charge my battery. Please kindly advise
    Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced. Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
    May 08, 2011 | Compaq Presario CQ40 Series Laptop Charger...
    Toshiba Laptop not Taking Charge
    ya the solder connection connecting the ac power input onto the transformer is probably weak. aside from taking the case apart and resoldering the connection, not much else you can do.
    Jun 18, 2009 | Computers & Internet
    Ac adapter does not connect to battery
    You either have a faulty ac adapter; a bad power supply in your laptop; a bad battery; or a blown LED indicator light.
    1. If the connection is not loose when you plug in your ac adapter try letting the laptop charge for a while. (If you are using the correct ac adapter)
    2. Try removing your battery and using the ac adapter. If this works the battery is bad.
    3. Try a new ac adapter.
    4. Power supply is bad
    Jun 05, 2009 | Dell Inspiron E1505 Notebook
    Seems like power source in back of 1150 inspiron is loose
    appears to be a loose connection between the AC adapter and the computer. Inspect the port on the computer where the AC is being connected for any damaged. If available, try using another known-good AC with your computer to isolate if the problem is specific to the AC adapter. If the same thing happens with another AC, the motherboard needs to be replaced. If the warranty of your computer is still active, contact dell and request a replacement for the motherboard
    Feb 02, 2009 | Dell Inspiron 1150 Notebook
    Sony PlayStation 2 Slimline Console Logo
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
