Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
2001 harley xlc1200
No spark,while pushing starter button for several revolutions.no spark to plugs. but,when button is released,spark appears for last few revolutions. can anyone help with troubleshooting causes
  • jamie Feb 12, 2009
    after checking all connections I found a manual at murray"s auto parts for $20.00. I found the resistance specs were out on the ignition coil, I borrowed one from "joe mama" motorcycle mechanic in bensenville shop #630-350-7722. the specs for primary side of coil were 2.5 to3.1 ohms, so the coil was found to be defective. problem solved.
  • 360 Answers
I know this sounds crazy and the only reason I am giving this as a solution is because it happened to me. Even though the electrical system has enough power to turn the engine, it does not have enough power to turn the engine and power to spark. Correct any poor connections at the battery terminals, etc. Try jump starting the bike. If it works, you know the problem is a weak battery and/or a poor connection.
Posted on Feb 02, 2009
Have power to gauges wont start just stopped running starter working acts like no fire
Hi Michel, when checking for spark the CKP needs to measure the compression bump in order to send the correct signal to the ICM/ECM so always check for spark with either a third plug grounded or lift the end of the plug boot 1/2 " off one of spark plugs that are in the head. and the usual suspects are:
1. Fuel tank empty
2. Fuel supply valve turned off.
3. Fouled spark plugs.
4. Engine flooded with gasoline as a result of over use of enrichner.
5. Fuel valve or filter clogged.
6. Vacuum hose to automatic fuel supply valve disconnected, leaking, or pinched.
7. Discharged battery, loose or broken battery connections.
8. Loose wire connection at coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, spark plug cable connections loose,
or cables connected to wrong cylinders.
10. Ignition timing incorrect due to faulty ignition coil, ignition module, or sensors " Manifold Absolute Pressure" "Camshaft Position Sensor" "Crank Position Sensor" "Brake Apply Sensor
11. Engine lubricant to heavy ( winter operation )
12. Sticking or damaged valves or push rod wrong length.
13. Primary cam sproket spline sheared or missing spacer.
14. Security alarm system not disarming.
For a primary suspect please visit the website below: Good luck
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Harley Davidson Wiring Diagrams and Schematics
Sep 13, 2012 | 2001 Harley Davidson FXST Softail Standard
I have a 1987 softail custom that I have been putting alot of money in to try to fix all the problems. I have had starter problems for the past year and finally got sick of it. Harley told me to put...
Did you do anything to change the ignition timing? I know of people that would set their cars ignition timimg by ear. Some of these people must have been deaf because they would have the timing so far off the motor would turn over like it had a weak battery.
And when bikes had distributors they had a lever that worked a cable to turn the distributor so the person could kick start their bike.
Have you removed the spark plugs to see how the starter spins the motor without the plugs? Try it with the plugs out to see how it turns over freely and try it with the plugs in and wires off to see how it spins with no spark but only compression.
Aug 31, 2011 | Harley Davidson Boulevard C109RT...
Hi, my harley doesnt fire until i release the starter button.
Take your battery out and take it somewhere to have it tested. It sounds like your battery voltage is dropping below 10 volts. I'm curious to know how you discovered that the plugs doesn't fire until you release the starter button. On most of the Twin Cam engines, the engine is equipped with a compression sensor and the plugs will not fire unless the engine has compression. In other words, you can't check for the spark plugs firing like you to do by taking the out and laying them on the cylinder heads.
To check for spark, leave you old plugs in the engine. Get another set of spark plugs and put them in the wires and ground them. Turn the ignition switch on and spin the engine. Check to see if the plugs are firing. I made up a set of "test plugs" that have a short "ground strap" on them with alligator clips to ground them with.
Oct 07, 2009 | 2000 Harley Davidson FXSTS Springer...
Starter turning motor over very slowly starter stalls after about half revolution. batt. load test, all connections good.
do a draw test on the starter hook a voltmeter to your batt and hit the starter button if it drops to2or3 volts then comes back up when button is released you need a starter it should only drop to about 6 volts under load
Jul 29, 2009 | Harley Davidson Harley-Davidson Motorcycle...
1998 Harley Davison Evo starter boggs down when trying to starten
do you have commpression releases on your motor if not you may need to in stall this will ease the stress off your starter and your motor will turn over easier if you do have the releases not sure what you may need to do without hearing the drag to determine if gearing is issue
May 15, 2009 | Harley Davidson Harley-Davidson Motorcycle...
2003 Heritage Starter Problems
High compression engine needs compresssion release plugs. Thats why it turns over easy with plugs out. Have compression release put in your heads
Apr 04, 2009 | 2003 Harley Davidson FLSTC Heritage...
TROUBLE STARTING BIKE HELP
If the spark plug is not getting a spark then you will need to replace the starting coil! the bike wikk start then !...Is the engine getting fule?
Dec 17, 2008 | 2001 Yamaha YZ 426 F
No spark
right off hand, i would do an amp draw test on the starter. if the starter draws too many amps, the voltage will pull down and some modules will not produce spark until you release the button. the voltage will surge upward allowing the module to fire. points will fire but will be extremely weak.
Dec 04, 2007 | Harley Davidson Harley-Davidson Motorcycle...
Lands Phones Logo
225 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
