Question about Yahoo Messenger
Not able to download yahoo messenger. says check firewall settings
    Sniper:
  • 54 Answers
Your firewall is blocking the site from being seen. You will have to manually add the domain to the safe list. you can do this in the security settings in the control panel. you will find your options for exeptions to your firewall in there.
good luck
Please remember to rate me.
Posted on Feb 02, 2009
Yahoo messenger can't able to download
Sometimes proxy setting or a firewall or even the antivirus can stop Yahoo Messenger from downloading. If you've turned off the firewall, you may want to have a look into your proxy settings or antivirus.
Alternatively, you can download the application from a different website like Softpedia. Yahoo will only give you an installer which will download the application and cause one of the above problems. Here's a link to download Yahoo Messenger 10: http://www.softpedia.com/progDownload/Yahoo-Messenger-Download-4411.html
Mar 16, 2011 | Yahoo Messenger
I am trying to downloaded yahoo messenger onto my system but shortly after i click install, a message pops up that there is a network problem. When I click cancel, another pop op message says to check...
Yahoo uses a downloader to download and install Yahoo Messenger, which may seem as a threat to the firewall and that's the reason why it may be blocked, so instead of turning the firewall off, you can download the application from a different website like Softpedia. Here's a link to Yahoo Messenger 10.
Jan 06, 2011 | Yahoo Messenger
When i try to run the download for yahoo messenger. i get a error message. To check my firewall setting and retry
When i try to run the download for yahoo messenger. i get a error message. To check my firewall (More) (More) When i try to run the download for yahoo messenger. i get a error message. To check my firewall setting and retry
May 19, 2010 | Yahoo Messenger
Yahoo installation problem because of firewall setting
Try using the Yahoo messenger "web version"...it works when your firewall is blocking the downloaded version
Jul 04, 2009 | Yahoo Messenger
I cant installe yahoo messenger because of a fire wall.
Try use Yahoo Messenger 9, the latest version. Before download yahoo messenger, make sure firewall allows your connection to download it. It shows that your PC protected from any harmful software because of your firewall. One more thing download your yahoo messenger only for trustful sources websites, it much better. i think you should check your firewall settings. Check also your Windows Firewall. I think there are some problems in your firewall settings. It may be blocked your yahoo messenger from downloading it into your PC. If you use Personal Firewall, make sure it allows your connection to receiving incoming connections and allows you to install yahoo messenger,check it out, may be it blocked your yahoo messenger. I think this tips can be help you a little bit.
Good Luck!
Jun 01, 2009 | Yahoo Messenger
I think you should check your firewall settings. If you use Personal Firewall, make sure it allows your connection to receiving incoming connections and allows you to use yahoo messenger, check it out, may be it blocked your yahoo messenger services. Check also your Windows Firewall. I thick this can be help u a little bit
Try to find out this! All the best!!
May 31, 2009 | Yahoo Messenger
Unable to install yahoo msn
Check your internet connection, may be your connection encountered problems...always download from your trustful sources website. i think better you should check your firewall settings. If you use Personal Firewall, make sure it allows your connection to receiving incoming connections and allows you download yahoo messenger,check it out, may be it blocked your yahoo messenger set up from downloading it.
Try these! Good Luck!!
Yahoo messenger error
download a latest copy yahoo messenger, sometime when your yahoo messenger become old it cant log you in download from here... this link is standalone installer of yahoo
Click here to Download
install yahoo messenger then log in again
Apr 09, 2009 | Yahoo Messenger
Installation
have tried to tunr off the firewall and have you tried to install the yahoo..try to turn off the firewall and try it and if its not working means and if you have the firewall cd means you cann uninstall it from add/remove programs and you can reinstall it.
Jan 27, 2009 | Yahoo Messenger
Yahoo Messenger firewall problem
right click with mouse on the right corner of your network adapter and then swich off firewall settings
Dec 09, 2008 | Yahoo Messenger
Yahoo Messenger Logo
43 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
