HP C7280 All in one wont send faxes
Have a brand new HP C7280.I try to send faxes and it just prints out a communication error with the numbers,344,387 or 389.344 has been printed twice and the other numbers once.This is on a fax log.Have tried to send 4 faxes and these are the numbers that have come up .Have done a fax test report and everything is okay.Can receive faxes with no problems
    Genius:
  • 2,035 Answers
First clear the fax memory and then go to go fax menu and then settings
then DRPD set it 9600, and then try to send a fax ...
Good luck...
Posted on Feb 02, 2009
    Sergeant:
    Champion:
  • 271 Answers
Try reinstalling the software
I keep getting "image on fax send report is set to
Hi!!
Press the Setup button on the front panel of your All in One
Go to Print report
Check for Fax report it may be off turn it On
Apr 16, 2011 | HP Photosmart C7280 Printer
HP C7280 doesn't print 2-side from my computer
have you use duplex unit?
you have to change your driver option both side print
Thanks
Oct 27, 2009 | HP Photosmart C7280 Printer
How do i set up the fax to print a confirmation sheet when it sends something?
Try this:
Press the Setup button (it might be the sign of a monkey range)
  1. Press the Down arrow (c00844971.gif ) to highlight Print Report , then press OK .
  2. Press the Down arrow (c00844971.gif ) to highlight Fax Confirmation , then press OK .
  3. Press the Down arrow (c00844971.gif ) to select one of the following options in the table below, then press OK
On Fax Send Prints a fax confirmation report for every fax you send. On Fax Receive Prints a fax confirmation report for every fax you receive. Send and Receive Prints a fax confirmation report for every fax you send and receive. Off Does not print a fax confirmation report when you send and receive faxes successfully. This is the default setting.
Select the one you would like to choose ;
For further help click on the following Link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01083680&cc=us&lc=en&dlc=en&product=3204785
Regards Soumajit
Sep 21, 2009 | HP Photosmart C7280 Laser Printer
C7280 printer wont recognize newly inserted ink cartridge! HELP
Try cleaning the gold contacts on cartridge with DISTILLED water and cotton bud, allow to dry and reinsert. Make
Apr 15, 2009 | HP Photosmart C7280 Printer
Wont print... error
It seems to be an issue with the printer drivers on the computer,You need to check for
any queued documents,if they are there,if yes,delete them,if not go ahead and
unintsall the printer drivers from the control panel>printers and faxes and then
restart your computer and then try a plug and play if its a USB printer or if its a
network printer check for the ip address on the printer as well as the computer,they
shuld be the same on both or it will not work,this should resolve your concern.
Apr 03, 2009 | HP Photosmart C7280 Printer
Unable to add a functioning (second) printer, for greyscale.
Clicked on Start/Control Panel/PrinterI. Clicked Add a printer. Obtained (Copy 1) of my HP Photosmart C7280 all-in-one printer. Right clicked on (Copy 1)/properties. Opened Ports tab. Saw comment "Print to the following Ports. Documents will print to the first free checked port." A listed USB Virtual printer port, showed three printers -- my first printer, my copy 1 (& my fax printer) -- was unchecked. I placed a checkmark in this Port box. Both the original printer, and my copy 1 printer are printing just fine. *I have not checked to verify that my fax is functional.
I did rename the original "color". I renamed Copy 1 as "grayscale", and --under printer preferences, checked, under "color options", to print in greyscale.
Mar 30, 2009 | HP Photosmart C3180 All-In-One InkJet...
"Missing or Damaged" cart message.
You can try a reset on the printer using the # and the number 6,holding them down while plugging in the power cord at the back of the printer.if the problem again comes up try thesame with # and the number 9 buttons
see if it works,else get your printer serviced
Jan 23, 2009 | HP Photosmart C7280 Printer
Wont send fax
Error 350: Under rare conditions incompatibility between the two machines may cause the remote machine to simply abandon the call.
Try these steps...
1. Press setup, then go to TOOLS.
2. press okay on TOOLS, then look for RUN FAX TEST. then press okay.
3. It will print a fax test page. Check if everything passed.
4. If it passed everything, try to press setup again, then go to ADVANCE FAX SETUP.
5. Scroll, down and look for ECM (Error correction mode), then press okay
6. Under ECM you will have to options "ON or OFF" try to choose OFF then press OKAY.
7. Now, try sending a fax.
Please let me know if the steps that i gave resolve your issue or not. So that i can still go ahead and give you another possible solution.
Thank you so much.
adonscott
Jun 29, 2008 | HP Photosmart C7280 Printer
617 people viewed this question
k24674
