Question about Whirlpool LSR7333 Top Load Washer
Whirlpool LSR7300 washer making ticking sound when spinning
Machine barely 5 yrs old is correctly installed and level but occasionally makes a ticking sound while spinning. Started a couple months ago and is becomming more frequent. Thinking it may be a belt, any ideas?
    Sergeant:
  • 249 Answers
Maybe something is up under your agitator
Posted on Jun 19, 2009
I have a whirlpool ultimate care 2 super capacity plus washing machine. We had it for about 7 years, just yesterday it stated to make an unusual noise when it was in spin cycle. As of today the washing...
My LSQ9549L is 7 yrs. old as well with an awful sound when spinning in high speed.
I've changed the agitator assy. as well as removed the drum and cleaned the soap build up on it.
Still makes a terrible sound in high speed spin. All other functions work.
Could it be the springs or coupling? I'm leaning towards it being the counter balance springs with it being rather weak. Could I be correct?
Your help is much appreciated.
Mar 22, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a whirlpool duet washer that is making very
It sounds like basket support failure. How old is the machine? They usually **** at around 5 to 6 years. Unless you are going to fix it yourself or it's under extended warranty, junk it.
The repair requires a complete teardown of the washer. two to six hours labor depending on tech skill level.
Jun 12, 2009 | Whirlpool GHW9200L Front Load Washer
Whirlpool washer will not spin
sounds like the timer is shot.
Apr 30, 2009 | Whirlpool Washing Machines
Washing machine will not spin
Hello,I know that no one likes bad news but it sounds like the transmission has gone faulty.Be sure to check the warranty if it's within 5 or 6 yrs. old.Hope this helps.
Dec 29, 2008 | Kenmore 22622 Top Load Washer
Washing machine
hope this helps, don't forget to rate me thanks
Try leveling the washer. Check for play along the diagonal corners of the washer cabinet by applying downward pressure. If there is any play at all, the washer will shake during spin and the legs must be leveled.
You have br put your heavy washer on a floor that would be condemned for structural weakness if a building inspector saw it. Try placing reinforcing pads or pieces of plywood on the floor under the washer.
On Maytag top loaders: worn damper pads.
On Whirlpool/Kenmore direct-drive machines: worn snubber pad
Dec 28, 2008 | Washing Machines
Rattling noise during high speed spin
sounds as if you might have a bad rear bearing, real obnoxious almost painful to listen too kinda sounds. big job, but might have some part warrentee depending on age of unit
Oct 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool frontload duet washer F 6 problem
hello cjkcp
Welcome to Fixya
You said, your washer (now 4 yrs old) occasionally stops mid cycle flashing F 6 code. Is this something we can fix or do I have to call a repair man?
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
I believe this needs a hands on tech to daignose this. Unless you feel you undrstand the problem your self?
Thank you for using our service for advice.
Please remember to leave a rating!
Huuum
Oct 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool LSR7333 Top Load Washer Logo
222 people viewed this question
Dan Webster
Dan Webster
Sal De
