Question about Apple iPod nano
Ipod nano needs fixed please!!!
Says my ipod is locked and won't let me reset and if i slide it to the unlock postion it still says its locked and its says its connected
    Problem Solver:
  • 9 Answers
Connect to your computer and click on "restore" in the ipod's menu in iTunes
Posted on Feb 15, 2009
Unlock
Unlock an iPod Model A1199
Although the second generation iPod Nano (also known as 2G) uses a four-digit pass code that prevents unauthorized access to your iPod by locking the screen, you can also unlock the device by plugging it into your computer's USB 2.0 port.
When the 2G iPod Nano is connected to the computer it is synchronized, and automatically unlocks the screen according to the official Apple site.
In order to successfully unlock the Nano it must be plugged into the primary computer used for synchronizing content.
Click "Start," "All Programs" and "iTunes" on your PC's desktop, or click "iTunes" on the Macintosh's desktop dock.
Plug the iPod Nano's cable into the docking port on the iPod Nano.
Plug the other end into the USB port on the computer to open iTunes.
Click "Controls" at the top of the iTunes' menu, and select "Eject iPod."
The iPod Nano's screen will be unlocked once it is ejected from your computer.
Manual Guide download
http://manuals.info.apple.com/en_US/iPod_nano_2nd_Gen_Features_Guide.pdf
Unlock an iPod Nano Code
With the latest iPod Nano model, you can set a four-digit code and lock all intruders from accessing your iPod.
In order to use the device's functions again, you need to enter the correct code.
However, if you happen to lose or forget the code, you will need to find another way to unlock your iPod Nano.
Plug the iPod USB cable into the bottom of your iPod Nano.
Plug the other end of the USB cable into a free USB port on your Mac or PC computer.
Open the iTunes program by using the Dock on a Mac or the Start menu on a PC.
Select your iPod Nano from the "Devices" list in the main iTunes window.
Click on the "Sync" button to make a connection between your computer and your iPod Nano.
Click on the "Eject" symbol once the syncing process is complete.
Remove your iPod Nano from the USB cable.
The iPod's lock code will now be reset and you will be able to access all features again.
Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again.
Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code.
iPod Support
http://www.apple.com/support/ipod/
Jul 24, 2013 | Apple iPod nano
Who to un lock
Hi there and welcome to FixYa,
All iPod Nanos have a slider on top which can be slide from 'locked' to 'unlocked'. Look if its 'unlocked'. You can power up your iPod (if it's unlocked) by pressing the 'play' butten. (Lowest button on your touchweel). If this does not help, make sure to charge it first. Kind regards. Please rate this solution.
Dec 22, 2012 | Apple iPod nano
DESBLOQUEAR PANTALLA
How to Unlock an iPod Nano Code
With the latest iPod Nano model, you can set a four-digit code and lock all intruders from accessing your iPod. In order to use the device's functions again, you need to enter the correct code. However, if you happen to lose or forget the code, you will need to find another way to unlock your iPod Nano.
Things You'll Need:
iPod Nano Mac or PC computer iPod USB cable
1 Plug the iPod USB cable into the bottom of your iPod Nano. Plug the other end of the USB cable into a free USB port on your Mac or PC computer. Open the iTunes program by using the Dock on a Mac or the Start menu on a PC.
2 Select your iPod Nano from the "Devices" list in the main iTunes window. Click on the "Sync" button to make a connection between your computer and your iPod Nano.
3 Click on the "Eject" symbol once the syncing process is complete. Remove your iPod Nano from the USB cable. The iPod's lock code will now be reset and you will be able to access all features again.
4 Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again. Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code.
Jan 05, 2012 | Apple iPod nano
Nano ipod will not charge and battery is low and on lock and wont disengage! help please.thanks
Important: If your iPod is frozen or won't turn on, it may be because iPod is paused or the Hold switch is in the locked position. If so, a lock symbol appears on the screen. Slide the Hold switch to the unlocked position and check the screen.
To reset an iPod with a Click Wheel: . Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Jul 11, 2010 | Audio Players & Recorders
Cant unlock my ipod
What generation? What do you mean, the slide to unlock, or the screen lock? If you mean the screen lock, you should connect to iTunes, because some iPods unlock after connecting to iTunes. Otherwise you should reset it with iTunes. But then all your data will be lost. Otherwise you should try try try. You've got 10000 chances ;-) If you have an iPod Touch, you might mean the slide to unlock screen is frozen. I had that one time, after trying out spoken feedback. After that it locked the screen and the touch screen wouldn't work anymore. I couldn't do anything anymore, not unlocking, not turning off spoken feedback, not even turn off the iPod. I was lucky to find there was an update for the iPod so iTunes turned it off. Then it responded also again.
More details next time please!
Jun 22, 2010 | Apple iPod nano
I charged my 4gb nano 3rd gen ipod, but it won,t
slide the hold switch on and off a couple of times...then press and hold menu and center buttons till an apple logo comes on screen...connect to system and restore with itunes.
Sep 10, 2009 | Apple iPod nano
Cant unlock my ipod
have you tried the sliding lock button at the top of the unit? If you can see the red indicator it is locked.
if it is locked by the password you will need to connect it to the computed, start iTunes and on the sync page you shoud see a reset button.
Do a reset and resync.
Hope this is of some help.
Ed
May 09, 2009 | Apple iPod nano MP3 Player
Ipod screen lock
on the top of your ipod, there should be a little slide bar. Slide this over so that no orange is showing on top. This will unlock your ipod for use.
Nathan.
Apr 13, 2009 | Apple iPod nano 3rd Generation
Change language to english
You have to reset your iPod. (Note: This is for the 3rd generation iPod Nano)
To reset iPod nano:
1 Toggle the Hold switch on and off (slide it to HOLD and then back again).
2 Press and hold the Menu and Center buttons for at least 6 seconds, until the Apple logo appears.
If iPod nano won’t turn on or respond
- Make sure the Hold switch isn’t set to HOLD.
- The iPod nano battery might need to be recharged. Connect iPod nano to your computer or to an Apple USB Power Adapter and let the battery recharge. Look for the lightning bolt icon on the iPod nano screen to verify that iPod nano is receiving a charge.
-Logan
Dec 22, 2008 | Apple iPod nano
Apple Ipod Video
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Nov 29, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod nano Logo
29 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
