Question about Whirlpool LER4600 Electric Dryer
Whirlpool LER4600 electric dryer drying slow and making noise
I have a whirlpool electric dryer that is barely 5 yrs old. For some time I have had to run loads two and sometimes three times to dry a full load, even though it is getting hot. I have cleaned all vents and checked for blockages finding nothing. Now, just a couple of days ago it started making a scraping, clinking sound while running...a lot like if a lighter or something was rolling around with the clothes and there is nothing there. My husband thinks it may be a belt or rollers...wondering if he is right.
    Sergeant:
    Champion:
  • 291 Answers
You will need to replace the blower wheel / larry
Posted on Feb 02, 2009
Electric Whirlpool dryer m11036334, dryer will not always heat
Sounds like a limit switch has broken. Doesn't sound too expensive to fix.
Nov 14, 2016 | Whirlpool Dryers
It takes too long to dry
Here is a tip that will help you with how to clean that dishwasher up and get it smelling good again...
Dishwasher Maintenance
heatman101
Sep 05, 2011 | Whirlpool LER4600 Electric Dryer
My Whirlpool Cabrio just started making a clicking noise. It's only a year old. Any ideas?
is it a noise like nails on a chalk board if so your heating element could be hitting the back side of your dryer and making a clicking noise or scratching sound does it heat and dry the same
Jun 27, 2011 | Whirlpool WED9200SQ Electric Dryer
We have a Whirlpool WED5821 electric dryer. The dryer is only 3 years old. When it is drying it is making a high pitch noise. When it first started it would be heavy loads. Now it doesn't matter the...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Sep 08, 2010 | Whirlpool WED5821S Electric Dryer
Dryer will run but does not heat up
Either bad heating element or missing one leg of the 240V circuit. The motor runs on 120V.
Sep 24, 2009 | Whirlpool LER4600 Electric Dryer
Maytag Dryer - funny buzz sound and then nothing
my dryer makes a buzzy sound bt it wnt start just make a buzzy sound
Jul 10, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool GEW9200 dryer makes loud whining noise...
It might be metal on metal. It is possible that something worked it's way from inside the drum it between the drum and the rest of the dryer. There's just a couple of srcews that holds the back and top on to the dryer. Take them out after un-plugging the dryer, and consider plugging it back in and running it to see if you can here where the squeek is coming from.
Feb 16, 2009 | Whirlpool GEW9250 Electric Dryer
ELECTRIC DRYER WON'T TUMBLE
Possibly the belt assembly. if you open the door and try to turn the drum does it turn with a little resistance, noises? this model has rollers, pulley, and a four groove belt 92 1/4" , sometimes the pulley sticks after yrs of use, belts wear, drum misaligns. the humming should be the motor trying to work.
Feb 03, 2009 | Whirlpool LER7646E Dryer
Duet Dryer (GEW9200LW) Control Panel doesn't work (all the time)
WHAT IS WRONG WITH YOUR DRYER?
small_8_19.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
My clothes smell bad!
My clothes are marked or torn
Hope this may help;
DON'T FORGET TO RATE
Aug 25, 2008 | Whirlpool GEW9200L Electric Dryer
Dryer doesn't get hot or turn off.
yes very possible timer but my guess on the times i seen the problem would be the heating element are the thermo fuse on the elemnt canister when the heater does not come on the timer will not move ck the heater and the fuses on the heater canister it will fix your problem
Feb 28, 2008 | Whirlpool LER4600 Electric Dryer
Whirlpool LER4600 Electric Dryer Logo
136 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
