Question about GE 24 in. GSD3400G Built-in Dishwasher
GE Nautilus GSD3400G00BB
The soap door is stuck shut...I have turned the knob and it will not pop open...PLEASE HELP..cannot afford a repairman right now.
  • rachbri Feb 02, 2009
    I already tried that - twice!!!!!
    We have pulled and pulled on the soap door -- it will not unlatch -- we turned the dial while we pulled...still will not unlatch...we tried prying it open -- something will not release it!!!!!
    Sniper:
  • 54 Answers
The easy way to fix it would be to empty it and run a quick wash. hopefully the latch is just stuck and it will open up.
Please remember to rate me.
Posted on Feb 02, 2009
  • fgainer
    fgainer Feb 02, 2009
    short of calling a repair man, have you tried gently prying it open with a screw driver?
My dishwasher is not running when you turn the knob it will open and close the detergent
The soap dispenser is openned mechanically by the movement of the knob by the timer. So even when it is unplugged the soap dispenser will open if you turn the knob. Try a different plug. Otherwise check the cord. Next you would check the power supply inside.
Feb 05, 2011 | GE 25 in. Nautilus GSC3400J Free-standing...
My GE Nautilus dishwasher stopped. Before it
Sounds like your door interlock switch is faulty.
There is a metal tab on the unit that triggers a interlock switch. The switch is located in the door and is part of the door handle. This tells the machine that the door is closed and that it is OK to start.
Most probably the first experience with the machine continuing to work with the door open was that the switch in the door was stuck in the on position. When you closed the door it moved to off and stuck there.
Open the door and use a screwdriver to move the switch to the on position. Move the timer to on. You should hear the unit start. If so it is the switch. Repair or replace it. You could try WD40 and switching it on and off a few times to free it up. Once you can see it is working make sure it is aligning with the tab correctly. You can bend the tab to adjust the alignment.
To repair:
Turn the breaker off.
There are screws on the frame of the door and in the door to hold the control panel in place. Carefully remove the control panel to access the switch. Once you see it you will be able to remove it easily as it just screws in. Replacement is the reverse of removal.
Hope this helps please rate if it does help you.
Mar 14, 2010 | GE Nautilus 24" Built-in Dishwasher
The door for the soap dispenser is stuck half open even after I ran it thru a couple of cycles
This may or may not be the answer you are looking for but I know with mine the soap dispenser will not close unless the outside dial is completely in the "off" position. Trying turning the dial clockwise very slightly. If you hear a click and it resets the soap dispenser position that should work. Otherwise I have no idea. :)
Aug 18, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus detergent cap will not open
Sometimes these get gunked up and need to be coaxed....so take a butter knife...insert it in the edge of the dispenser tray...pry gently...all the while turning the timer control knob...it should pop open at one point if not try a little more pressure...and once open .clean thoroughly..if it persists you may have a timer or control panel issue...also use factory recommended soaps...
I hope this helps...Good Luck and Good day....thank you for rating my effort.....The Fang.
Mar 14, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus
Hi Lisa in AR
I'm Harvey the Master Plumber.
Your question is: Why won't your soap dispense anymore?
Yes, you're correct. This is best looked at by a local pro! You may want to compare the cost of repairing a six year old dishwasher now verses temporarily putting the soap in manually till you can find a good price on a new one. Personally, I loath throwing good money after bad so I go for the latter and we're coming up on the holiday discount season.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 12, 2008 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus Dishwasher - The soap door is stuck partcially open
Advance the timer, with one hand on the dispenser door. The timer should release the door at times during it's cycle, it may need a little help, but not very hard to turn.
Jun 27, 2008 | GE Nautilus 24" Built-in Dishwasher
GE nautilus soap dispenser "frozen" shut.
you might take door apart and check to see if insulation has fallen on dispenser arms. Ive ran into this alot.
Jan 02, 2008 | GE Nautilus 24" Built-in Dishwasher
Soap door latch won't latch close
Make sure the dial that you turn to start the dishwasher is all the way to the beginning. Sometimes my little grandson comes by and plays with it, turning it. I load, add soap and the dispenser won't close. I check the outside dial, and sure enough, set it to the very beginning and the dispenser locks in place!
Nov 04, 2007 | GE Nautilus 24" Built-in Dishwasher
Dishwasher soap dispenser won't open during cycle
I had the same problem with my GE Adora. The dishes were getting cloudy and the soap dispenser would not open. Turns out the hard water deposits were causing the soap dispenser to stick shut. I purchased and used Dishwasher Magic which is a dishwasher cleaner designed to remove limescale, rust and buildup. I used as directed and now my dishes are sparkling and the soap dispenser pops right open.
Oct 26, 2007 | Dishwashers
GE 24 in. GSD3400G Built-in Dishwasher Logo
264 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
