Question about MSI KT3 Ultra Motherboard
Case wiring I recently removed my KT3 Ultra motherboard to switch out the cases and now i can't figure out where the wires go and cant find anything about hooking it back up can anyone send me pics or tell me how
  • Scorpio 69 Feb 03, 2009
    thanks ill try it :)
  • hawkinz Apr 12, 2009
    I tried that link, but it keeps defaulting back tohttp://www.msi.com/language/
    does anyone have copy of manual?
They changed the link. I found the new one. Hope it helps. Cheers.
http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=273
Posted on Apr 16, 2009
  • 565 Answers
Here is the manual, it will have everything you need to know about your mobo:
http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=273
Posted on Feb 02, 2009
  • Bob
    Bob Feb 03, 2009
    Glad to help, post back here if you have any further questions.
  • MSI Master
  • 3,606 Answers
Hello the Manual can be downloaded here:
http://www.msi.com/product/mb/KT3-Ultra2.html#/?div=Manual
Select manual in the download box.
And click on the link.
Any file from the msi site needs to be unziped.
You need adobe reader to read content.
Here are the other models with the same ms number:
http://www.msi.com/service/search/?kw=MS-6380E&type=product
Good luck
Posted on Dec 06, 2012
Keepalive battery failed how do I get BIOS to work again
If the battery on the motherboard dies, the date and time might not be remembered, but the BIOS should at least have default settings.. Have you pressed the "Del" key during Startup to change BIOS settings? This is a copy of the manual for that mb..
Start on page 51 to see how to enter the BIOS and make changes. There are some explanations of different settings.
http://www.manualslib.com/manual/360284/Msi-Kt3-Ultra.html?page=51#manual
Nov 17, 2013 | AMD MicroStar KT3 Ultra Socket A ATX...
I bought a new tower for acer aspire m3802 desktop pc. I want to connect the on/off switch, hdd lights etc into the motherboard front panel. Is there a manual so I can connect all the wires correctly into...
your best beat would be as you remove the original wires from the original case they should be labeled already and you new case should be labeled already or have a manual for it ..... so should be pretty easy at that point.... worst case trail and error is how I used to do it .. cant really mess anything up
Oct 14, 2013 | Computers & Internet
I have a PC that died completely - not reacting to the power switch at all. Over the last few months I've replaced the PSU and, more recently, the MOBO and CPU, but it's still dead. I ordered a new case...
connect the positive lead of a multimeter to one wire from the switch, connect the negative lead to the other wire. Set the meter to ohms. Push the button, does it go to 0 ohms? Let go of the button, does it go to infinite ohms? This should tell you if your switch is working without having to take it out of the case.
Feb 23, 2011 | Cooler Master Ammo 533 No Power Supply...
I am working on a KT3 Ultra CE MS-6380E ver.1 mother board. The original problem was that nothing run after I pushed the power switch. I thought the Power Supply went out so I replaced the power supply but...
Sounds like the board or processor has failed. You will have checked all the power connectors to the board? Usual fix is a new board, rather than trying to find which component on the board has failed.
manual
MSI MS 6380LE User Manual
specs
MSI KT3 Ultra2 Specs
MSI website details on the board
KT3 Ultra Ultra ARU Motherboard The world leader in motherboard design MSI...
Seems to be a problem board
Questions Answers for kt3 ultra ce ms 6380e
Jul 12, 2017 | AMD MicroStar KT3 Ultra Socket A ATX...
Audio problem
http://drivers.softpedia.com/get/SOUND-CARD/OTHER-SOUNDCARDS/Msi-KT3-Ultra-Ultra-ARU-VIA-AC97-PCI-Sound-Driver-614-01-4150D.shtml
follow this link and download ur driver and check it
Mar 07, 2010 | MSI KT3 Ultra Motherboard
Wiring
Click the link listed below that will take you Gigabyte. Download the manual described as, (English-Rev. 1103, format pdf, size 7.47Mb). The case leds placement is on pg. 25. USB's on pg. 27. Everything you need to setup this Ultra motherboard is here.
http://www.giga-byte.com/Support/Motherboard/Manual_Model.aspx?ProductID=1621
The only thing not mentioned for connecting the case led wires to the motherboard is the wire colors. Which is, pos+ & which are neg -. Usually white colored & black colors are negetive -. Other colors like Green, Blue & red are pos+.
This should make it much easyer to install.
please vote...
Feb 13, 2008 | Mercury P4VM800M7 Motherboard
MSI KT3 Ultra2-R Motherboard
http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=497
Sep 26, 2007 | MSI KT3 Ultra2-R Motherboard
MSI KT3 Ultra Motherboard Logo
355 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
