Question about Microsoft Computers & Internet
If i run a game. the executable file is not running.it says there
Please say what i should do..
If a game started its not running solve this
Posted on Feb 02, 2009
First I downloaded IGI 2 from torrentz.after i installed IGI 2 and when i trying to play they ask please insert disk 1 select ok and restart application.this is a downloaded game. therefore i dont have...
This is because the game has not been cracked. Usually in the torrent file there should be a crack for the game. You have to run this crack to enable you play the game. Check the downloaded folder and there should be a folder or an executable file there which can be used to crack it. Take a look at it and run this file. After running this file it should work properly without asking for any disc.
Hope this solution has been helpful?
Jun 20, 2011 | Computers & Internet
I just bought it for my son. We have done the initial set-up and we inserted the game disc but it doesn't play?
Hi..
To play a game on PC, you need to pass few bunch marks.
  1. The Game should be Properly installed and registered.
    If the Game is not installed into Computer yet, Please insert the Game Disc. There will a setup file (Installer) to install the game. Many commercial games requires registration before we could play the game.
  2. Your PC must meet the hardware resource requirements for the Game.
    Many Games are Resource intensive. Many need extra hardware resources like a Good Graphics card, Physical Memory (RAM) etc.
    Many games will specify their minimum hardware configuration required to play the game smoothly, on their Disc Packs.
  3. Your Game and Operating System should be Authentic
    If your game disc is not authentic or legal, Operating System will prevent the game from running. The same will do for the Operating Systems also.
    So if you got the Disc illegally, you may need to crack or patch it run.
  4. Auto running Feature should be turned on.
    Many Operating Systems features Auto Running the Disc. That is, if you put the disc on computer, it will run automatically without any user interactions. If your Current Operating System does not have Auto Running Feature (Many new Operating Systems have this feature and its set to On by default) or its set to disabled mode, you can browse the disc and run it manually.
    You can find the executables in the Disc to run the game. Usual Autorun executables have name one of Installer, Autorun, setup.
  5. Your Anti-virus may interrupt the game.
    If you have an anti-virus software, then it may interact with the game's normal play and stop it from playing. This is due to the fact that, many Anti-virus Software mistakenly think the game as a virus and stop it from running.
    So if you have an anti-virus software, please set it to Game Mode or Disabled Mode
Mar 19, 2011 | Computers & Internet
The game could not be started
Glad to help YOU!
Please check if the game it was properly installed. Sometimes appears an incompatibility between the operating system and the game drivers/executable files.
It means:
1. or your game requirements are not meeting your system capabilities (not enough RAM, too tight space on disk, etc.)
2. or the game is not designed for your system (game runs on 2-bit and you have a system running on 64-bit/or viceversa)
3. or the game was not correctly installed because you had a corrupted installer (this case try to obtain another installer from a different source for the game).
My best wishes!
Mar 13, 2011 | Computers & Internet
When ever i'm playing online Axis and allies (1998 game for pc) and I click begin, It crashes and an error report comes up. It's really annoying, I don't know if anyone could help with this, but if you...
Try finding the executable--the file that actually runs when you double-click the desktop shortcut--and set it to run in compatibility mode. Assuming you have a newer version of Windows than Win98, you'll need to do this, by doing the following:
  1. Right-click on your desktop shortcut, then click 'Open File Location' (in Vista it will probably be the 2nd option from the top of the list)
  2. Windows will find and open the folder containing the actual file that runs when you want to play the game, highlight that file for you as well. Don't click anywhere else, you're focusing in on the actual program, so do the next step.
  3. Right-click on that executable, then click 'Properties' at the bottom of this list.
  4. Another window with the Properties of the game's executable will pop up. Click on the tab labelled 'Compatibility' (it should be the 2nd tab from the left).
  5. Click a check-mark into the very top box, labelled 'Run this program in compatibility mode for:
  6. then select 'Windows 98 / Windows ME' from the pull-down menu just below that.
  7. You should also go ahead and click 'Run this program as Administrator' at the bottom of the same popup window.
  8. Then, click 'OK', and click out of all windows until you're back at your desktop.
  9. Try your program again by double-clicking the same old icon you've always used to get it going before.
See if that helps. If not, it might help you to uninstall your game altogether and then reinstall it in a similar fashion, by finding the 'executable' that actually installs it within its installation CD (instead of letting it auto-start, click out of that and Explore the CD), and doing the exact same thing (setting all installer files to run in 'compatibility mode' for the older Windows 98 OS).
At the end of the installation, you may still have to perform the same procedure in the bullets above to ensure that all files installed are running compatibility mode themselves.
It's sometimes tedious, but there are countless older games, programs, and drivers you can get to run this way.
Feb 24, 2011 | Hasbro Interactive Axis and Allies for...
Error running th game "Casino Inc." in Windows XP SP2
What Causes Windows Error 0xC0000005
A quick scan of the online technical forums and blogs reveal folks asking for help with this windows error. Your question may be the same as this typical request:
I'm running Windows XP and when I click to start one of my software programs I get this error:
"An application error has occurred and an application error log is being generated. Exception: access violation (0xC0000005), Address"
The error 0xC0000005 is generated by an ******* "memory access violation". This can be caused by anything from faulty RAM, an incorrect/corrupt device driver, poorly written/updated software and more commonly under Windows XP Service pack 2, malware/adware installations.
Usually you get this error message when performing a specific task, and if that happens you need to check the corresponding 3rd party's website/support department to see if they are aware of the problem
..a while back Symantec Antivirus caused the 0xC0000005 error with an additional message about a file called SAVRT.SYS . A simple software update to the Symantec Antivirus cured the problem.
So what can you do...? well below are a couple of suggestions:
0xC0000005 - Resolution Suggestion One:
In many cases this error has been generated by faulty RAM memory. So if you have just upgraded your computer with some new memory and you started getting this error then I would remove them and see if the error goes away. If it does then send the memory back and get a refund!
0xC0000005 - Resolution Suggestion Two:
In Windows XP Service Pack 2 Microsoft introduced Data execution prevention (DEP), a set of hardware and software technologies that perform additional checks on memory to help protect against malicious code exploits. In Windows XP SP2, DEP is enforced by both hardware and software.
Some software/application behaviours are incompatible with DEP - data execution prevention. Applications which perform dynamic code generation (such as Just-In-Time code generation) and that do not explicitly mark generated code with Execute permission might have compatibility issues with data execution prevention. Applications which are not built with SafeSEH must have their exception handlers located in executable memory regions.
Applications that attempt to violate DEP will receive an exception with status code STATUS_ACCESS_VIOLATION (0xC0000005).
If an application requires executable memory, it must explicitly set this attribute on the appropriate memory by specifying PAGE_EXECUTE, PAGE_EXECUTE_READ, PAGE_EXECUTE_READWRITE or PAGE_EXECUTE_WRITECOPY in the memory protection argument of the Virtual* memory allocation functions.
If you are having issues with 0xC0000005 errors in DEP and a particular piece of software is causing the offence, contact the vendor for a resolution...
Note: It is possible to "Turn Off" DEP in the boot.ini file but this really would be a last step!
/NOEXECUTE
This option is only available on 32-bit versions of Windows when running on processors supporting no-execute protection. It enables no-execute protection (also known as Data Execution Protection - DEP), which results in the Memory Manager marking pages containing data as no-execute so that they cannot be executed as code. This can be useful for preventing malicious code from exploiting buffer overflow bugs with unexpected program input in order to execute arbitrary code. No-execute protection is always enabled on 64-bit versions of Windows on processors that support no-execute protection.
There are several options you can specify with this switch:
/NOEXECUTE=OPTIN Enables DEP for core system images and those specified in the DEP configuration dialog.
/NOEXECUTE=OPTOUT Enables DEP for all images except those specified in the DEP configuration dialog.
/NOEXECUTE=ALWAYSON Enables DEP on all images.
/NOEXECUTE=ALWAYSOFF Disables DEP. (This setting doesn't provide any DEP coverage for any part of the system, regardless of hardware DEP support. The processor doesn't run in Physical Address Extension (PAE) mode unless the /PAE option is present in the boot.ini file.)
Oct 30, 2017 | Konami Casino Inc. for Windows
HOW TO INSTALL APPLIATION IN SAMSUNG S3310 METRO
In Samsung s3310 mobile,installing games is itself a big task and you did that.
The reason is only games folder can run Java executable files(.jar) files.When we move Java executable files(.jar) to application folder,it cannot execute the .jar file.Therefore the applications like call tracer which runs in background mode could be installed but cannot run in s3310.
only games and applications like dictionary(which does not need background running mode) can run in Samsung s3310 in games folder.
May 12, 2010 | Samsung SGH-L700 Cell Phone
My computer won't let me download any software. It downloads and then asks me to run it, and I do. Then nothing ever comes up and when i look for the download set up file, it is nowhere to be found??...
If you select 'run' when downloading an executable file (a software installation, for example) the download will be written to a temporary file and then the file will be executed. This means that the installation should have taken place, but the downloaded file is not easily identified and found.
If you are having problems installing some downloaded software you should select 'save as' instead of 'run' when doing the download, and save the file to a known location, e.g. create a folder called 'downloads' in your My Documents folder, or simply save the file to Desktop.
Once you have the downloaded file save you can normally execute it (run installation) by double clicking it.
Mar 06, 2010 | Dell Dimension 3000 PC Desktop
I loaded a game into the disc drive but the game won't load
Try to open the disk using the open option, and run the executive file (.exe) if not work, try to connect the internet and then run the cd again.
Jan 06, 2010 | Video Game Consoles & Games
We have loaded Age of Mythology on our computer. But our computer will only let users with admin rights run it. How do we allow other users to run the Program.
From an admin account.
Go to the directory where you installed AOM, find the executable file that starts the game. More than likely a derivative of the name of the game followed by exe (Example: AOM.exe)
Right click on the file and select properties.
This will bring up a dialog box that has many options.
The one we are concerned with is "Run as administrator" put a check mark in this box and close the dialog box.
The game is now set to run in administrator mode NO matter WHAT the user level is that executes it.
Hope this helps,
Dave
Nov 16, 2008 | Computers & Internet
3D mazeman
The game was released in 1998, and was developed for Windows 95/98.
To make the game run on Windows XP, try the compatibility for the installation and after it is installed use the same steps for making the game executable file compatible.
Note: Some game ".exe" file (executable file) would let you make changes in the Compatibility option, whereas older games might not give that option at all.
You can still try to make the game compatible for installing it on the Windows Vista by following the steps below.
1. Insert the game disc in your CD-ROM drive, if the game setup or the autorun starts, exit it.
2. Open "Computer", Right Click the Cd Drive which has the game disk in it and select "Copy".
3. Go to your "Desktop" right click and then select "New" and click on "Folder" this should create a new folder on your desktop.
4. Open the New Folder and then Right Click and select "Paste".
6. After all the files are copied to the "New Folder" without any error messages then locate the file "Setup.exe" or "Setup" and right click and click on "Properties".
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows 98/ Windows Me" and then click on "Apply". (You can also try "Windows 95")
8. After applying changes double click on "Setup.exe" or "Setup" to launch the installation.
You can delete all the files copied from the CD after completing the installation
After the game is successfully installed right click on the game shortcut or the game ".exe" in the root folder of the game and click and click on "Properties".
In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows 98/ Windows Me" and then click on "Apply". (Again, you can also try "Windows 95")
The game files need to be copied to the hard drive because the files on the game disk would not let you make changes while on the disk.
There are lot of files that need to be changed in order to get full functionality and to communicate with operating system and the hardware, hence there is no guarantee that the game might run even in cases where you will successfully install an older version of the game with the above mentioned steps.
Oct 24, 2008 | eGames 3D Mazeman Amazing Adventures for...
Computers & Internet Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
