Question about Dryers
HI, The exhaust vent in the back of the dryer is too short to clamp or tape the venting to. We cannot get it to stay hooked up. Any ideas on how to lengthen this? Do we need to remove the back of the dryer to get the venting hooked up properly? ,
  • 29 Answers
If your using a soft hose, go down and buy a corrugated aluminum hose. While you are there check to see if they have any metal tie wraps. However the heaver hose may do the trick. Also check to ensure that there is not any restrictions where you are discharging the air to. Let me know how it goes. :?) DRRXR
Posted on Feb 02, 2009
I have a W/pool awz135/3. The dryer runs etc, approx 15 mins of drying the lint filter light and buzzer comes on, and in turn shuts the heat off.No lint is in the unit.Any idea what is triggering this
It is possible there is an obstruction in the exhaust vent ducting or vent grill.first disconnect the power then carefully pull dryer away from the wall and look in the back of the dryer towards the bottom and you should see a ribbed 4" hose coming out of the dryer leading to a vent duct in the wall.make sure the hose is not pinched or collapsed if it is remove the pinch plug dryer in and try it and see if it still shuts down.if it does disconnecr the power again but this time get a 5/16 nut driver if the hose is connected with a metal hose clamp and remove both clamps on at the dryer and one at the vent.ic you have Plastic.clamps remove by pushing release tab on clamps and remove. Check inside hose for any obstructions and remove if any are present then. Check the vent duct and do the same. Reattach hose and clamps reconnect power and test and see if problem is solved if so push dryer back to original position taking care not to pinch
the hose.if the problem persist the dryer may have a faulty temperature high limit switch and gets quite a bit more involved.but try this first and see how it goes then if you want I can guide you on how to approach replacing the high limit switch if needed.
Aug 03, 2017 | Dryers
I have an lg 5988 dryer, only will stay heating on delicate cycle. any other cycle I have to reset, by pushing the button on the sensor on the exhaust inside back of dryer. I replaced that sensor 3 ti
Sounds like a airflow problem. Either the House vent is clogged or some major build up in the blower or lint housing.
Remove the vent hose from the dryer and see how well it is blowing, then reconnect the vent and check outside, it should be close to the same.
House vent should be short and strait as possible, and metal venting only.
Dec 27, 2014 | LG DLG5988 Gas Dryer
How do I properly hook up the metal tubing to vent my dryer?
-There are many way to connect it. You can use
big hose clamp about 5" Diameter, or connect together then use 2 screws and then use duck tape over to seal any gap.
Good Luck
Mai Lor
Nov 12, 2014 | Dryers
Kenmore Elite HE3 not heating up when vent connected
check outside of house for any obstructions to the outlet. make sure the vent is clean
Jan 02, 2013 | Dryers
How should the dryer vent be in stalled they have taped it and it falls off the vent is the same size and the housing under the dryer shouldn't they dryer vent piping be a little larger so that is goes...
if its a solid piece you can take a set of sheet metal snips and cut some 3/4 to 1 inch slices down the tube end and continue around the pipe at about 1 inch intervals, this will allow you to ease the pipe over the venting from the dryer and also over the vent cap leading to the outside, then use metal tape ( not screws, they tend to grab lint on its way out ) to cover the splices, I always use a 4" hose clamp on mine to ensure they stay on and in place
Jul 06, 2011 | Dryers
Dryer gets hot, but stays damp inside and clothes don't dry. I removed a birds nest from the outer end of the vent, and there is plenty of hot steamy air coming through, but still having this problem....
The vent is probably still stopped up. You are going to have to pull the dryer out and disconnect the 4" vent hose from the back and inspect the vent all the way through.
May 18, 2011 | Dryers
My dryer hose keeps coming off the back of the dryer....I use the clamp, but it keeps coming off....is there an easier kit or solution to get it to stay on ?
Use a 4" radiator clamp available at any hardware store. They will tighten down so the vent will not come off....or....duct tape! :-)
Jan 13, 2011 | Kenmore 62602 Electric Dryer
Maytag gas dryer ldg7314aae my flame will not stay lit. Heats up flame kicks on then goes for about 20 seconds then shuts off. The dryer runs for about 20 more seconds and then the same thing happens...
you have done a lot . try running the dryer off the vent . when the burner is short cycling it a air flow problem . if off the vent does not solve problem ck the fan for a bad center . very common problem . and clean vent . ck outside for air flow and condition of vent hood .. hop this helps ..
Dec 03, 2009 | Dryers
The vent hose is off the wall how to i put it back on? do i use duct tape?
duct tape will probably work, but you really need to get a vent clamp available at places that sell dryers.
May 04, 2008 | Dryers
Whirlpool Dryer
Your prof. vent cleaner failed to do his job. Ther is a definite restriction in the vent from point A to B, The prof is in the test u performed. You need a straight shot from the dryer to the outside using a class A 4"vent line and a dryer exhaust hood at the termination point,then your problem will be resolved...
Apr 29, 2008 | Dryers
Dryers Logo
76 people viewed this question
Top Dryers Experts
