i removed another user account off my laptop, but imported the documents to my account, onto the desktop. now that i have saved what i needed, i wanted to delete the folder, but it keeps saying "access denied" has someone got any suggestions? thanks
Comments:
Feb 02, 2009
- thanks for your response but...i followed thru the steps, and there was no security tab...so that was as far as i could go..tried a few other things but nothing..
This is happening because you just copied the folder over from the other user. The system thinks that you do not have the right to delete is cause it is registered under that user. (which is gone now). The only think I can think of is to log in as an administrator under safe mode and try deleting it that way then rebooting. Tap the F8 key on boot up to access safe mode options.
Assuming you have admin rights ...
Right click on the folder and select Properties from the menu.
Click on the Security Tab
Click on the Advanced button
A new window opens, click on the Owner Tab
Highlight Administrators
Add a check mark to Replace owner on subcontainers and objects
Click apply.
When it is finished, you should have full control of the folder. You should be able to open it, edit the contents or delete.
Comments:
Feb 02, 2009
- Your system has "Simple File Sharing" turned on.
Open any folder.
In the menu bar at the top select Tools
Select Folder Options
A Folder Options window will open, click on the View tab.
Scroll to the bottom of th Advanced Settings and remove the check mark from Use Simple File Sharing
Click OK
You may need to reboot.
You should now have a Security tab.
Was this helpful?
Yes
No
Popular Solutions for Toshiba Satellite M45-S351 PC
my laptop wont start up it keeps saying there is a camera or something attached and must...
(More)
my laptop wont start up it keeps saying there is a camera or something attached and must disconnected it now but i dont have anything attached to it
I have just bought an Acer ASPIRE 5738pg. It has been charging the battery since 3 pm, for about...
(More)
I have just bought an Acer ASPIRE 5738pg. It has been charging the battery since 3 pm, for about 1&1/2 hr now. It has been showing to be fully charged for at least 1 hr now, so very quickly. It does not say anywhere how long to charge the battery for, I have read all literature, but not mention of it? Can someone help?
last night i was able to connect to my hi-speed service. Today I am not able to. The light on the...
(More)
last night i was able to connect to my hi-speed service. Today I am not able to. The light on the back where I plug in the hi-speed cable no longer comes on when cable is plugged in.
The motherboard was burnt and i changed it. On powerup the screen is blank. Fan is on, everything...
(More)
The motherboard was burnt and i changed it. On powerup the screen is blank. Fan is on, everything seems to be on. First i thought screen was bad, but when i tap the laptop all around the screen pops up with Toshiba message but it stays on that page. It won't boot past it. When i restart again same problem, blank screen, tap couple of times and Toshiba screen is on. I removed the video connector to the screen and it went blank, when i put it back in the slot the screen turns on. So i know the screen is good. Could you please help me?
