Question about Zenith A60M91W 60" Rear Projection Television
Picture jumps and convergence wrong
Zenith 60" model number A60M91W9 top and right sides of picture bowed in and it has seperate r g and b pictures that jump erratically. Any ideas?
  • Zenith Master
  • 3,459 Answers
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence youpicture jumps and convergence wrong - 69189a5.pngix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Posted on Jun 06, 2010
My rear projection television is showing a double picture with the blue out of allignment. It also shows a bow on the top and a bow on the bottom.
The tv have a problems known as a convergence problems,tv convergence board it is dead.Tv have R,G,B colors lines mis alignments,have colors pictures shadows or 3D pictures look alike?Yes.The tv convergence board it is dead.Must require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv picture convergence problems.The tv shop,will cost u like $300-350 for parts and labors.
Apr 24, 2011 | Zenith IQC50H95W 50" Rear Projection...
3D picture with bowing effects
model number is located on bottom rear cover, your convergence circuit has failed but without model nobody can give you further info, re-post and we`ll try to help, video-tek
May 28, 2009 | Televison & Video
Skewed picture
you need ned convergance chips
Mar 22, 2009 | Mitsubishi VS-60621 60" Rear Projection...
Projection T.V. Picture
Replace Both of your STK ICs convergence ICs STK392-110 use 150s Better ICs Call Mats 1-800-628-1118 Also RK42 RK46 RK48 RK50 RK54 RK58 RK60 will have to get back to you on resistor values
Jul 21, 2008 | Hitachi 60SX12B/13K 60" Rear Projection...
Picture is bowed down from top left corner to top right corner and bowed up from bottom left corner to botton right corner. Colors are seperated a little in corners and middle top and middle bottom.
Convergence ICs are faulty what is your model number? I can post which ICs you need and where you can get replacements that come with free instalation instructions so you can do the repair yourself
May 07, 2008 | Televison & Video
Zenith IQ6097DT 60 inch big screen
Convergence circuit repair plus fuse in the power supply,
usually 300.-400.00.....................if you are mechanically
able and can solder well,it is possible to DIY...................T.
Mar 31, 2008 | Zenith IQB50M90W 50" Rear Projection...
Bowing in the middle like an hour glass
about the zenith it seems you have the flyback transformer malfunctioning - try to change it - delfo
Mar 22, 2008 | Televison & Video
Problem with convergence
bad convergence ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
OUCH!!!! Don't kick me...would be my response if I were your TV
Convergence amps problem.
If it works after a kick I'd say poor solder joints on the convergence amp leads
Dec 17, 2006 | Zenith IQB50M90W 50" Rear Projection...
Televison & Video Logo
77 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
