Blueway air conditioner not fully cooling
Hi there
My Blueway split system doesn't cool as it once did. if I set the thermo to 23 it only gets to about 27. Filters are clean so does leave a refrigerant top up? and can any airconditioning guy do this?
Thanks, Dave
  • 909 Answers
Check the radiator for dirt, and check if the radiator fan is functioning. Do you notice any wetness or ice build up on the outside copper pipes. If so, suggest calling a refrig. tech. to add gas. The gas used is R22 on most aircons.
Posted on Feb 02, 2009
I av lost my manual. Pls kindly give me details on each of the samsung split AC 5way. I mean what each symbol means
To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat"
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.Helpful?
Jan 19, 2011 | Heating & Cooling
I have lost the manual for my fujita 2.5 split system and all i want is w what to press on the remote control..... as from Winter to summer Cheers Clare
You decide what temp you need.
Jan 06, 2011 | Heating & Cooling
Blower fan running but compressor not coming in.What could be the problem
To get proper cold air set temp 23 degree and mode"cool". If still no cooling, check power in out door unit. If power on, check compressor is working. If not working call repairman to find out exact problem, as there are many reasons for compressor not operating. Thanks.
Jan 01, 2011 | LG LS-K1830HL Heat Cool Mini Split Air...
I need to reset the hand control as I have changed the batteries. I have lost the manuals.
Keep cool mode and temp setting 23 degree. And more information,
www.retrevo.com/support/LG-LA091CNP-Air...manual/id/.../t/2/
Hope it's helpful.
Dec 30, 2010 | LG Art Cool LA091CNP Split System Air...
LG Art Cool, 2 splits. Error code CH7
Multi Splits and Multi V = indoor unit is set to run in a different mode from the master indoor unit. Set ALL indoor units to cooling or ALL to heating to clear.
Splits = Compressor Over Current (CT2)
Jul 09, 2010 | LG Art Cool LA121CNP wall/window Air...
Broken barrel fan
I am not familiar with the Blueway brand but have never seen an air conditioner on which you could not replace the fan.
Is this a split system or a window unit? If a window unit it may not be worth the trouble.
Jan 29, 2009 | Heating & Cooling
Blueway split system wall air conditioning doesn't work properly.
Hi,I have had problems with my Blueway A/C it was very cheap but NASTY,anyway I might be able to help, I made a website with my manual that includes the error codes that I could not find on the net anywhere ,I have also sourced a company in sydney who has spares and have the contact details listed and started a forum that we can help each other out with
Jan 26, 2009 | Heating & Cooling
My Blueway air con is not cooling , fan works but is not cooling
More than likely the capacitor is bad internally
Jan 21, 2009 | Heating & Cooling
Thank you. there are some other signs i don't know about.
The black triangle means AUTO, means the fan speed adjust by itself from high-mid-low speed depending in room temperature but the unit is cooling for this function the same COOL mode. Plasma is in the remote control but it never mention in the manual.
If the unit dont cool check your temperature setting and mode setting it should be in cool mode and temperature setting should be 18C. But if still don't cool check some error code like blinking light at the indoor panel check how many blink appears to get the correct error code.. If the light is blinking 3 times it means that the room air or coil sensor is defective.
abc4048.jpg.
Apr 28, 2008 | LG LSC121PMA Split System Air Conditioner
Heating & Cooling Logo
323 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
