Question about Welding Tools
Unlock code of LG RD 3500 handset
i forget my lock code of LG RD 3500 mobile, now i want to unlock my mobile please give me solution. or axis code for unlock
  • 2 more comments
  • Anonymous Feb 19, 2009
    canvart to tata+rim
  • Anonymous Mar 22, 2009
    lg rd 3500 key pad locked, lost password
  • vivek_tiwari Apr 30, 2009
    pls provide me unlocking code of lg rd3500 & dr3510
  • Anonymous May 24, 2009
    lg RD 3500 un looking code
I want unlock code no. mobil modal no. lg rd3500
Posted on Apr 19, 2009
  • amitkumar838 Apr 19, 2009
    plz want now code
Lg RD 3500 un looking code
Posted on Mar 06, 2011
  • rk1824835 Sep 10, 2011
    please view code
LG RD3500
804CYUK1910814
Posted on Apr 29, 2010
    Problem Solver:
  • 11 Answers
Posted in the wrong place. This is for welding stuff
Posted on Feb 06, 2009
Charging not store
Posted on Dec 03, 2010
    President:
  • 1,912 Answers
this is just an information for all mobile users which, a company i found last week where unlock guide available..in future anybody really need assistance then reach the company. http://www.mobileunlockguide.com/
Posted on Jul 16, 2009
Has anyone ever welded at part that has been coated with phosphate and the finished is black oxide. I am using tig for the welding process. Clean the area where I am welding, used E702-S and 4130 fillers...
If you got grease or oil inside the metal you can forget about the welding with argon. I did meet some gears in such state, very few of them I manage to weld after heating them red twice or three times until no more oil come out of the metal and the rest of them turn out to be a failure. Good luck
Sep 08, 2014 | Welding Tools
Have a Miller Dynasty 300 that won't tig weld, displays HELP 12 code. Suggestions??
Some welders have a resistor that is obvious and accessible but to give an error code it is likely something else inside. You'll have to look at the circuit board for a component that is burned. If you are lucky you will find a fuse.
Nov 21, 2013 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Lincoln precision tig 225. Makes bad aluminum welds in AC. Welds show signs of contamination. Have tried new argon bottle. No leaks in gas lines. Using pure and 2% thoriated tungsten, 3/32, pure...
Hello; Make sure AC Auto Balancing is Enabled; And when Welding Aluminum Aways use 100% Pure Green Coded Tugsten.Make Sure you dont have 75/25 or possibly if you know for sure your frequency balancing on your machine is working you could possibly have a bad bottle of gas try the bottle of gas on the machine that you say that runs good if it runs good put it back on the 225 if the problems still exist there is something wrong with your machine`s Ac high freqency Auto Balancing.Make sure all connections are good,check tig head for loose connections. Step Up to A 1/8 size tugsten it will carry more heat and gets less contanimated.Every time you stick your tugsten it will run contanimated untill you burn it off or clean it ,if you stick you tugsten go ahead and put a clean piece back in the tig head, Contanimated tugsten wil run dirty for 5 to 20 minutes Untill you BURN it Back Clean !?
Sep 03, 2011 | Lincoln Precision Tig 225 Ready Pak With...
Lg rd 3500 show charging on display but power not save , what i do?
lg rd 3500 show charging on display but not charging.....plz solution
Dec 08, 2010 | Welding Tools
My miller sychrowave tig welder is not blowing sheilding gas when it strikes an arc. The gas is on at the tank. I can hear what sounds like gas or a valve opening when I press the foot control, but my...
Remove the tig torch twist lock from the front of the machine. Step on the pedal as if you were striking an arc and gas should flow out of the twist lock port. If gas comes out of the port, your torch probably has a valve built in (many do) often this is a sleeve on the torch body which you rotate but may not be obvious.
If no gas out of port then its the solenoid or regulator.
You do have the machine in TIG mode and not stick?
May 28, 2010 | Miller Welding Tools
Hello, Where can I get a users/owners manual for Linde UCC 305
Jessie email the owner of this site and see if he can't hook you up. He worked for Linde for 25 years.
http://weldingweb.com
Mar 12, 2010 | Welding Tools
I cannot get any arc current. The rest of the unit is working and the wire is feeding. No overloads are tripped
hello. I thoroughly enjoy welding. here is a link to a great reference sheet for troubleshooting, check item 6 to answer your question. http://www.millerwelds.com/resources/tech_tips/TIG_tips/troubleshooting.html
Aug 21, 2009 | Welding Tools
My kohler driven hobart champ 10000 runs but only provides power
replace your berrings in the drive its probly as the rpms rise the centrifical force pushes the brushes against the wall causing it to short
May 19, 2009 | Hobart Welders 500433 Champion? 10,000...
I have a miller dynasty inverter tig welder   It has a help code that comes on when I turn it on the code is p-2
From the user manual for a generic dynasty model welder:
2 Help 2 Display
Indicates an open in the thermal protection
circuitry located on the left side of the unit.
Contact a Factory Authorized Service
Agent if this display is shown.
So you could have anything from a broken or disconnected wire to a bad thermal switch.
You can get user manuals specific to your welder at www.millerwelds.com
Rank this answer please,
Carl
Nov 26, 2008 | Miller DYNASTY 350 TIG WELDER w/TIG TORCH...
Welding Tools Logo
3,679 people viewed this question
Top Welding Tools Experts
Lawrence Oravetz
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
