Question about HP DeskJet 5150 InkJet Printer
I'm trying to print but it doesn't just the button next to the X button is flashing which looks like a flame what's wrong with it?
I had this problem. I thought it was out of black ink because it was spitting out blank pages. I replaced that cartridge and then the flashing, yellow water drop started and it wouldn't print. I replaced the color cartridge and that fixed the problem.
Posted on Feb 18, 2009
    Scholar:
  • 71 Answers
That indicator just means there is some problem. It's impossible to tell which exact problem it is without the help of an HP representative.
Posted on Feb 02, 2009
NEED TO PRINT SOLUTION
Posted on Mar 11, 2009
My Star TSP600 Thermal Printer is displaying a flashing Error light. Power light on, new roll of paper loaded correctly, self-test was ineffective - nothing printed. What's my next step?
i know you stated you put the paper in correctlyin the printer but if the thermal reactive side of the paper is not facing the print head the thermal paper won't print on the wrong side of the paper. it will load into the printer and seem ok but the heat on the wrong side of the paper will not react and show any writing. Can you try turning the paper over in the printer feed holder so the other side of the paper faces the print head and give it another test .
Jun 21, 2016 | Star Micronics TSP600 Thermal Printer
On the error code list, I'm getting an error code of Open Rollout, How do you fix that?
a 'roll-out' safety switch it a small button looking device with a smaller tab/button sticking out of it, near the gas injection manifold. has 2 wires attached. the reset button is generally between these wires. it's designed to shut the unit off, by breaking the power circuit, if flame ignition causes fire to back flash out of the fire box. Press the little button and try relighting. if the roll-out pops again, and there was no roll out of flame, you made need to replace it.
Oct 19, 2014 | Goodman GDS80904BNA Open Flame Heater
My Maytag gas dryer, Model No, LDG7500AAW will run but not heat. The igniter glows red, but the gas will not flow. What might be wrong?
Replace the 2 burner coils ,if the igniter keeps cycling trying to start the flame. If it doesn't replace the flame sensor mounted on the side of the burner tube.
Nov 06, 2012 | Dryers
Power but not printing
Hi Linda,
Did you check if the printer is able to scan or does it makes photocopy? if the printer doesn't respond to any input follow below steps.
  • Power Drain:
  1. Turn the printer OFF using the power button.
  2. Disconnect the power and USB cable from the back side of the printer.
  3. Press and hold the Power button for 30 seconds and release the button.
  4. Connect the power cable and try printing.
  5. If the above steps didn't work try below.
  • Partial Reset: Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the button. If you still see the issue try next level of reset.
  • Semi Full Reset:- Remove the ink cartridges; Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the button.
Feb 07, 2012 | HP PSC Photosmart 2355 All-in-One Printer
What might be wrong with my OKI C3450 printer? it keeps flashing and it doesn't print.please help me
try uploading the original software and reboot it then it's a new baby...don't have original software...just google free software for...(your model)...join any site that askes for you to join for free and your set...also, make sure you cartridges are in their correct position...try removing and replacing a few times for better connection
Dec 09, 2011 | Office Equipment & Supplies
I have a ruud furnace/airconditioner Model:UGPN-07EAMER, Serial: FU5D302F390401344. When the thermostat calls for heat, a little motor (within the furnace itself) or something kicks on, the burners ignite...
Hi, this motor is the inducer motor, which is the first thing to start on a call for heat. Everything seems to be going through its sequence of operation just fine, but then shutting down on a safety. Look on the panel for a chart that should tell you by the number of flashes and color of the leds what is wrong. It is locking out for some reason, could be several of many. Next to the pilot, you will have a flame sensor. The metal tip sets in the pilot flame. When they get dirty, they will cause the furnace to do just as you say, run and then lock out. You can take a piece of sanding cloth and sand the metal tip on this flame sensor. If this is the problem, it will start and stay running. Also, look for this chart I have told you about, as it is there to help you locate which safety is giving you the problem. My bet is the flame sensor. Please keep me posted, and rate me on my help to you. The flame sensor also has a electrical lead that is attached to it going to the board, so you will see it.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Jan 06, 2011 | Heating & Cooling
Low flames
Try replacing the hose and regulator, easy to do, and not very expensive.
Jul 04, 2010 | Char-Broil 463453005 Grill
Flashing red "check ink" lights and nothing is wrong with ink
Is there a resume button on the printer? If so press this, often printers will allow you to bypass a low ink message and print for a while longer.
Jun 12, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Rinnai heater flashes code 12
Bailey,
Next time you try your stove watch the flame. If the flame goes away and then the error code comes on, you have something wrong with the over temp circuit, gas or gas valve, If the code comes on and then the flame goes away you have a flame sensor problem.
Good luck,
Tom Hawkins
hawkins111@gci.net
Mar 13, 2009 | Rinnai Toyostove Direct Vent Heater:...
Gas flows to long before igniting.
try cleaning the crossovers between the burners. Also look closely at the flame and make sure that the burner is firing all the way to the pilot. Sometimes its just a few little holes that vent a little gas to give the flame a path to follow will be stopped up and cause the condition you describe
Nov 18, 2008 | Williams 2509612 Ceramic Mid-Size Heater
HP DeskJet 5150 InkJet Printer Logo
155 people viewed this question
Ben Johnson
