Question about Hunter Fan Company 5/1/1 Programmable Thermostat
I have a hunter 44150B thermostat and when i replaced the batteries, the temp is in celcius instead of ferenheit...HELP!
Pull the whole thing off the wall there is a switch on the back marked F and C. Make sure the switch is set correctly.
Posted on Feb 14, 2009
How do I can from Celcius to ferenheit
What are you trying to do this with
Oct 12, 2014 | Cars & Trucks
Hunter 44665
You can get the manual at: http://www.manualslib.com/manual/257219/Hunter-44665.html
Normally these thermostats read remote temperatures but do not use them for control. The external remote sensor is normally put outside in our area yeilding an inside out side thermometer.
Nov 22, 2013 | Hunter Fan Company 5/1/1 Programmable...
How to you change ferenheit to celcius?
Tc = (5/9) x (Tf-32); Tc = temperature in degrees Celsius, Tf = temperature in degreesFahrenheit.
Example: 40 deg. F minus 32 = 8, 8 x 5 = 40, 40 divided by 9 = 4.44 deg. Centigrade.
To go the other way:
Tf = [(9/5) x Tc]+32; Tc = temperature in degrees Celsius, Tf = temperature in degrees Fahrenheit
Example: -10 deg. C x 9/5 = -18; -18 + 32 = 14 deg. F
See also: http://www.csgnetwork.com/tempconvjava.html
Jan 29, 2011 | White Rodgers White-Rodgers 1F85RF-275...
How do change the thermostat from celcius to
The switch to change it should be on the upper left corner on the back of the t-stat.
You can see where it is here on page 14-15..
http://www.hunterfan.com/uploadedFiles/Support/Downloads/44550.pdf?n=4754
Heatman101
Feb 28, 2010 | Hunter Fan Company 5/1/1 Programmable...
How do you set the thermostat??
hi
you may get a pdf download of the manual form this site Programmable thermostats at discount prices at hunter-thermostats.com.
they may have the model you require .
riz.
Feb 26, 2008 | Hunter Fan Company 5/1/1 Programmable...
Asap help
if you still ahve the manual it should tell you how to get a reset back to factory defaults. you can go from there. if nothing else, unhook the stat, pull the batterys and let it sit a while. it should forget everything. if you tell us the stat model we might be able to better help
saskcat :)
Jan 20, 2008 | Honeywell Programmable Thermostat Heater
Programmable Hunter Thermostat
hi
this site as the owners manual you can download in pdf . if this helps you out .
riz.
Nov 14, 2007 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
269 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
