Question about Compaq A1500 All-In-One InkJet Printer
Sending faxes do you place the document face up or face down when sending
Head down- Face Down
Posted on Jun 18, 2009
I am trying to fax on the 6170 do the sheets face up or down?
If you are sending fax using the scanner bed, your original document should be placed face down. However, if you are sending faxes using the automatic document feeder, original document should face up.
Jun 15, 2011 | Lexmark X6170 All-In-One InkJet Printer
Using a brother MFC-J415W printer, what are the steps in sending a fax?
How to fax :
1. Entering fax mode To enter fax mode press (Fax), and the key will glow green.
2. Sending a fax from the ADF (Automatic Document Feeder): Using the ADF to send your faxes is the easiest way. To cancel a fax in progress press Stop/Exit.
a. Make sure you are in Fax mode . b. Place your document face up in the ADF. c. Dial the fax number. d. Press Start.
The machine scans the pages into memory and then sends the document.
3. Sending a fax from the scanner glass : You can use the scanner glass to fax the pages of a book, or a single page at a time. The documents can be up to Letter or A4 size. Press Stop/Exit to cancel a fax in progress.
a. Make sure you are in Fax mode . b. Place your document face down on the scanner glass. c. Dial the fax number. d. Press Start.The machine starts scanning the first page.
For more detailed instructions, you can go directly to Section 4 - page 22 of the manual in Brother's site. Hope this helps.
Apr 14, 2011 | Office Equipment & Supplies
How do I fax a sheet of paper?
First step is to connect the phone line to Line 1 Ext at the back of the printer port.
Place the document face down on the Scanner Bed Or place the document face up on the Top feeder if you want to use it.
Use the right arrow key and choose Fax Black and press OK
Dial the # you want to send Fax to and Press OK.
The fax should be sent.
Dec 10, 2010 | HP OfficeJet J4580 All-In-One Laser...
Fax documents face up or face down
Fax documents should be placed as you would any document to be copied or scanned. Face down for manually placed documents. If you have an Automatic Document Feeder, the pages go face up.
I hope this helps.
May 03, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
How to fax (face up or face down)
If you put the document on the glass surface, your document should be face down. If instead you use the automatic feed on top of the machine you should place your document face up and the top of the page inside he feeder.
Hope it helps.
Aug 28, 2009 | Brother MFC 420CN All-In-One InkJet...
When faxing does paper face uup or down
You load the originals print side uo on the document feeder tray or print side down on the glass.
To send a single page fax you can either load the original on document feeder tray or on the glass; to send a multi-page fax you must use the document feeder tray.
The position of the paper is the same either you copy, fax or scan.
All this is clearly explained in the user's manual, that you should read and you can download from HP support pages for you printer:
Aug 09, 2009 | HP Officejet 6310 All-In-One InkJet...
If we send afax than it is coming blank at another
make sure you are placing the document in the feeder correctly. some faxes you have to send it face down others you have to send it face up.
Aug 06, 2009 | Brother Office Equipment & Supplies
if using the feeder probably face up as it will likely pull the document in and invert it to lay face down on the scanning glass.
if you lift up the feeder (like lifting the top of a copy machine), then it would be face down on the glass.
there should be an image on the feeder illustrating how the document should be placed - if it looks like a page with lines on it with a bent corner then it is face up.
Apr 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Cannot send a fax conventionally - can you describe how I should send i.e. not through the glass
Place document in document feeder, dial number, press send or start.
look for an icon on the feed tray to signify face-up or face-down.
Sep 11, 2008 | HP Office Equipment & Supplies
If you are using the Auto-feeder, it needs to be face up. If you are placing the document on the glass, then it needs to be face down.
Jun 25, 2008 | Brother MFC-7820N Laser Printer
Compaq A1500 All-In-One InkJet Printer Logo
42 people viewed this question
Top Compaq Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
