Question about Kenmore Elite HE4 Electric Dryer
Washer door I Do not believe I can switch the swing of the washer door. I switched the dryer door.  It seems they should be interchangeable but am I missing something.
    Problem Solver:
  • 12 Answers
The washer door is not switchable, but you will need a kit to switch the dryer door. talk to your sears rep for the kit number
Posted on Feb 07, 2009
How is the doors reversed on ffp187b
Reversing your washer door - YouTube
? 5:14
www.youtube.com/watch?v=abpAu_5Uhfc
Feb 16, 2011 - Uploaded by Kenmore You can switch the side the door on our new dryers (model #s starting with 417) swings on. This video will tell ...
Jul 30, 2015 | Washing Machines
How to switch door side on dryer
Not that simple like it is on a modern refrigerator. The electrical wiring is set up for a door safety switch. That switch can probably work either door swing. The door would need to be reversed and holes cut in the dryer for the latch. The old latch would need to sealed up. It is uncertain that the metal on both sides is capable of supporting the door hinge. In any case it seems like a difficult and doomed task.
Jan 03, 2014 | Maytag Centennial White Gas Front Load...
How to change doors from right to left on Whirlpool Duet
Duet dryer doors cannot be reversed for the swing. They wil only open one way. Depending on your model of washer the newers ones will allow you to reverse the door swing without a kit. The older units require a kit to reverse the washer door.
Apr 22, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Can you change the door direction on a Maytag
Unfortunately, you can only change front loading dryer door directions on some models. Washing machines do not allow this. If the units are stacked i may be easier to switch loads, otherwise the dryer door may be able to have the door swing direction changed but without the Dryer model # I couldn't say for sure.
Dec 29, 2009 | Maytag EPIC MFW9700S Front Load Washer
Switching the door swing opening?
only if there are capped off screw holes on other side, look for caps mirror image to other side.
Sep 02, 2009 | Kenmore HE2 Plus Front Load Washer
The door on my dryer and washer open the wrong way
On these model you can only reverse the door swing on the dryer but not the washer.
Alternatively, you can switch places with the washer and dryer provided the washer fill and drain hoses are long enough and there is enough room without obstructing the dryer exhaust vent .
If you want to know how to reverse the door swing on the dryer, post your model number and I will try to assist you further.
Apr 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door switch replacement
REMOVE TWO SCREWS UNDER THE LINT FILTER DOOR.
USE A FLAT INSTRUMENT SUCH AS A PUTTY KNIFE TO PUSH AGAINST A SPING CLIP IN EACH OF THE FRONT CORNERS OF THE SPACE BETWEEN THE TOP AND FRONT.
ONCE THE SPRING CLIPS ARE PUSHED TOWARD THE BACK, YOU CAN LIFT THE TOP AND SWING IT BACK UP AND OUT OF THE WAY. IT IS HINGED AT THE BACK. YOU SHOULD BE ABLE TO ACCESS THE DOOR SWITCH FROM THE OPENED TOP. IF NOT, REMOVE TWO SCREWS LOCATED TOWARD THE TOP FROM THE INSIDE OF THE CABINET.THEN YOU WILL BE ABLE TO SWING THE FRONT
TOP TOWARD YOU. THE DRUM WILL FALL SLIGHTLY BECAUSE IT IS SUPPORTED BY THE FRONT. THIS SHOULD
GIVE YOU ENOUGH ROOM TO ACCESS THE SWITCH.
Jul 06, 2008 | Roper RGX4634KQ Gas Dryer
Washing machine doors
Electrolux has a reversible door for both front load washer and dryer. Just found that out at HHGregg because we need to put our washer to the right of the dryer, and none of the other makes will allow the washer door swing to be switched.
Apr 11, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
