Question about Garden
No spark on a 1981 john deere 317 w/kohler 2 cly
I have no spark on my engine. I have 12 volts going to the coil My spec# 8252203(is this the presserized good engine?). I am thinking my points(do I have them or electronic?) or?? It has been sitting outside for about 1 year prior to me buying it. Where can I get schamatic for this unit on line(free?)? Serial # 1601315461 Thanks for any help you can give me Jim
  • 23 Answers
Hey try taking the recoil off and make sure the flywheel isnt all rusted up. This is common when it sits outside. emory is clean and try turning the engine back over. Also make sure there isnt a corrosion break inside the plug wire housing at the head where the plug connects to coil wire. -Jeff Anchorage Small Engine repair.
Posted on Feb 02, 2009
Need Drive Shaft for JD 317 with 17hp Kohler engine, 1981 year bought
The I had I just replaced the U Joints in it. But yours might have been let go to long and tore up the ends . You can buy them new on ebay link attached. Has some good picture JOHN DEERE OEM UNIVERSAL DRIVE SHAFT AM37875 317
Mar 17, 2016 | Garden
first i thought this engine had only one spark plug ?? second it's a kohler engine right ? this model has a coil (thing that makes fire for plug) that sits right on top of engine under cover this allows grass and other stuff to get inside it and cause things to overheat a bit this makes coil go out when things get hot in there but it usually will restart when it cools off after a few hours your gonna need to remove cover replace overheated coil and clean this entire area with compressed air to get things cooling again , ck out youtube for some of my easy dissassembly videos of this motor (kohler coil change)
May 31, 2014 | John Deere L100 Series
I have a 214 kohler engine john deere lawn tractor, what point wires go to hot and the ground
if that is the Kohler 14 hp motor it may have the spark control untit on the motor cover. I recently ran into one like that and switched the coil out from a blown 20 hp kohler engine. I just taped up the excess wires and made sure they were not near any moving parts. The mower ran fine after that. Kohler wants about $160.00 for a spark control unit. There have been no repercussions since making the switch.
Apr 21, 2014 | John Deere Garden
John Deere (Sabre) Kohler Command 25
Are you getting 12V to the coil with the Key in the Run position? if yes,
Possibly a bad coil
Jan 05, 2014 | Garden
No spark to spark plugs on john deere 2510
do you have a bad wire or a bad wire going from the points to the coil
Jul 28, 2012 | John Deere Step 2510 2520 3010 3020 4000...
No spark to the plug Kohler 8hp lawnmower engine
Check ingition switch, check battery voltage 12-12 1/2 volts,check in run position same voltage, check in start position same voltage
We've check switch first. If not problem we've check the points for proper voltage and opening and closing.
Jan 17, 2012 | John Deere Garden
John deere model240 mower will not start. Have replaced coil and still not getting spark at the plug . Engine turns over strong
Only option left.... 12 volts feeding coil is not there. The ignition key applys the 12 volts to the coil in the "Run" and "Start" positions. Verify 12 volts at input to coil and then (if needed) follow wire back to key and confirm voltage there....and (if needed) follow input wire to key from battery. One of those critters is open - since you have already confirmed the coil/spark plug wire is not at fault.
Dec 15, 2011 | John Deere Garden
I have a John Deere 317 tractor that does not start. The engine turns but does not fire. The plugs and points are good. I do not get a spark at the points or plug. What should I check next next.
We will be testing for voltage to the points, coil, engine to tractor wiring harness, ignition switch
Tools needed:
volt meter to read 12 volts, or test light
1) with the points open: is there voltage at the connection wire at the points
If yes; adjust points to .020" and try to crank engine and check for spark
*** you may want to determine if condensor is connected to this wire also
if no
2) check point side (neg or - ) of coil for voltage
if yes, engine should start
if no
3) check for voltage at the + side of coil
If yes, coil is bad
if no
4) check wire connector from engine to frame wiring harness
if yes; engine should start
if no
5) check wiring on the back of ignition switch
if no
6) check that ignition switch RED or BATTERY supply wire has voltage
if yes; switch is bad
if no
7) check supply wire and circuit breaker connected to the battery side of the solenoid
if no; circuit breaker could be at fault or wire connector at battery supply
Nov 08, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Need to order engine parts for a c314h john deere riding mower
If there is no #'s you can call John Deere or go on there web site and should find some info.If you have the model of the tractor john deere can tell you what engine you have. If you have an engine # they can also help you.Good luck. donnyb60.
Mar 24, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
311 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
