Question about RCA HD50LPW42 50" Rear Projection HDTV
Green lines and jumpy
I replaced the bulb about 6 months ago and just now replaced the color wheel. I am still getting green lines to randomly come across screen and it it jumpy. What else could be causing the problem?
  • 6 more comments
  • aerocool Feb 02, 2009
    Tapping the tv does nothing to it. I even moved it violently and it did not cause the jumping or anything to happen. How do i locate the ic or capacitor that would be the problem. that might be slightly above my head but if described well and all I could do the changes as far as that goes.
    I will order that. Should that have all the replacement parts that are needed for my repair or will I need to order some other parts?
  • aerocool Feb 10, 2009
    The kit you had me to order was for a mitsubishi V26. Does that have the same board or something? According to sonny berry with service manuals thats what i ordered and nothing that would fit the RCA i am having trouble with. Please advise.
  • aerocool Feb 14, 2009
    that kit just came with 4 capacitors and the diagrams were for a mitsubishi tv. I'm confused at what needs to be done now. Can you please explain?
  • aerocool Feb 21, 2009
    So if that is not the right kit what am i supposed to do? What kit is needed?
    there is more than just green lines now. I've started to notice them in red and blue as well. Please advise on what to do next.
  • aerocool Feb 22, 2009
    how do i check the green tube
    I already replaced the color wheel as i stated above
    Sergeant:
  • 326 Answers
When replacing the lamp, please wait 15 minutes after powering down to allow the unit to cool down! .... Color Wheel. Open. Red. Blue. Green. Yellow. Orange. Magenta. UV (Purple) ... jerky or jumpy. Possible bad motor driver or sensors ...
and also it can be the problem in the ballast  how to replace the colour wheel with diagram and procedure
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
how to replace the lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
how to replace the ballast with diagram and procedure
http://www.consumermeet.com/entry/samsung-dlp-ballast.html
Posted on Feb 22, 2009
    President:
  • 2,110 Answers
Hi...the flickering and the green is the colorwheel going bad. Very common for this model and an easy fix too.
green lines and jumpy - f3ead30.jpg2da0213.jpgT
    Genius:
  • 2,920 Answers
It sounds like the green tube has a flaw in it. you could have a couple of bad capaciters causing the jumping about on the picture but i would check the green tube
Posted on Feb 21, 2009
  • 350 Answers
Dear aerocool, Sat 02-21-2009 3:55pm EST (USA)
RE: RCA HD50LPW42 50 in Rear Projection HDTV Television - "Green Lines across screen and jumpy"
The following may be helpful to you....
Self Repair @ http://www.electronicrepairguide.com/
Electronic Parts @ http://www.partstore.com
Capacitors @ http://search.digikey.com/scripts/DkSearch/dksus.dll?lang=en&WT.medium=cpc&WT.campaign=1045&site=US&WT.term=capacitors&keywords=capacitors&WT.content=text&WT.source=google&cshift_ck=1200880254cs502597329&WT.srch=1
Thermal Resistors @ http://www.milwaukeeresistor.com/?gclid=CMrojf7KyZgCFQETGgodr0zd0g
jack
  • 11,896 Answers
The ic's or capacitors on the hyperboard will also do this. usually the hyperboard.
Posted on Feb 02, 2009
  • 7 more comments
  • Nate Stansfield
    Nate Stansfield Feb 02, 2009
    If tapping on the TV makes the picture jump, it confirms that a
    defective solder connection is the cause of the jumping picture. I
    would say that most likely the defective connection is on the pins of
    the vertical output amp IC
  • Nate Stansfield
    Some non-technical things you could do are:
    ONE: Smack the unit huskily with hand or fist while set is on. See if
    the picture restores or goes bad when smacking it in a certain
    location. This often will dislodge or wakeup a bad connection of cold
    solder joint.
    TWO: Do a hard reset; just unplug the power cord for at least 2 hours,
    then reboot. This will clear any software related issues.
    THREE: Rotate the big screen unit by 90 degrees in search of
    interferance that may be bouncing down from the power company line or
    such.
    FOUR: Switch to video input and feed signal from vcr or dvd player. Do
    you still get the squiggle lines? IF so it is clearly a problem within
    the set. If it goes away when in video mode you could have an
    intermittent cable connection either at the receiver or within the wall
    plug or along the cable line within the house.
  • Nate Stansfield
    As for manuals? There's not much to that model. The power supply
    board, System board (exchange only), ballast*(exchange) and the
    engine. Only the power board would be considered serviceable,
    everything else, including the ballast is replace only.
    I WILL DO SOME MORE SEARCHING TO FIND YOUR SERVICE MANUAL OR ILLUSTRATED PICS/DIAGRAM TO SHOW YOU.
  • Nate Stansfield
  • Nate Stansfield
    Most of them come with the parts already.
  • Nate Stansfield
    Nate Stansfield Feb 11, 2009
    the ballast is what needs to be replaced
  • Nate Stansfield
    Nate Stansfield Feb 16, 2009
    That is a very strange kit. There should be way more capacitors. The kit is was supposed to be for your
    RCA, not Mitsubishi. I may have given you the wrong part number and I apologize if it was my fault. You will need the kit for the RCA
  • Nate Stansfield
    Nate Stansfield Feb 23, 2009
    you ballast is going out or the color wheel was inserted properly
  • Nate Stansfield
    Nate Stansfield Feb 26, 2009
    In order to identify whether is the tube that cause the dim or from bad components, one can always use a CRT tester/meter to check it. Some call it CRT rejuvenator, CRT restorer and others named it as CRT regenerator. These testers are designed to test and check CRT and fix it if the picture tubes have problems. I personally owned two CRT testers- the BMR 2005 Muter regenerator and a less feature one I bought from Thailand. With the help of CRT tester, I can know if a picture tube is working or not. If you do not have one, don’t worry because by checking the voltage at the CRT socket pin outs, you will have some ideas if the CRT is good or bad.
Also have stars about 5 just did bulb 6 months ago color wheel a month in to owner ship 4 years ago
Issue is most likely with the optical light engine the model listed here uses, no mystery and very common issue.
May 25, 2012 | Mitsubishi WD-65733 65" HDTV
Lamp was replace, color wheel and now ballaster and now the bulb does not turn on.
the only thing I can think of is be sure the safety switch on the back is not your problem.
Mar 12, 2012 | Televison & Video
Picture has a red tint what is causung it replaced the blub 6 months ago
the lcd panel was broken, you need a new one , USD100
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Feb 14, 2011 | Hitachi 42V515 rear projection TV lamp...
My samsung HL-S5086W has a high pitched buzz that is present when muted, and continues for 2 or 3 seconds after you power off. Any ideas? I heard if it continues after power is off, then it is a fan, not...
Samsung BP96-01579A Color Wheelno the fans will not produce a high pitched noise. they will ususally produce a dull noise because they dont spin anywhere near as fast as the color wheel. the color wheel will start up before you see video and stay on for few moments after power down. if the fans were faulty the tv would give you message on screen.
Dec 22, 2010 | Samsung HL-S5086W 50" HDTV
Lots of details: LP120 stays on for a minute, then powers off
either the colorwheel motor is not getting up to speed to sync with the dmd chip, the wheel sensor is going, or the power supply needs replacing. you can try to replace them yourself or send it to an infocus authorized service center. try www.avsolutionsny.com . they're pretty good.
Sep 29, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Color blinkig in and out.
It seems like the color wheel might start to fail.
Do you hear any abnormal sound(s) from the TV when ramdon color appears.
Would you be able to check and make sure all the fans are working properly?
Jul 13, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Samsung hln4365w - no pic. or sound. it whistles a few times when powered on
We have the same DLP set and had the same problem. The Color Wheel, P/N BP96-00250A, a $200 part needs replacement to eliminate your problem.
May 24, 2008 | Samsung HLN4365W 43" Rear Projection...
Samsung TV Model HL-R5067W
go here they are adjusting speed of the color wheel
Feb 12, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Toshiba
possible color wheel is faulty,call a service shop for an estimate of cost.
Dec 07, 2007 | Panasonic PT-47WX42 47" Rear Projection...
RCA HD50LPW42 50" Rear Projection HDTV Logo
158 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
