Question about Janome Memory Craft 9000 Computerized Sewing Machine
Janome model 3022
I don't have a manual for this machine, where can i get one for free? i have the cord but no foot pedal, do i need that too? gina
  • 84 Answers
SOURCE: Janome 3022
ALL machines will require lubrication at some point.It will require covers to be removed however. Apart from the cover over the needle bar / presser foot area, I dont recommend you try taking them off as without knowledge of exactly how, you can break the retaining clips. Cleaning out the lint REGULARLY is very important - you can use a vacuum with a crevice tool.
So, remove the 'lamp' cover and needle plate, vacuum out thoroughly. Apply a drop in total to the length of the needle bar, a small amount on the presser foot shaft.Remove the black plastic shuttle, clean around it, apply a SMIDGE of oill to the 'track' on the underside of it. Thats about all you will have access to. Use proper sewing machine oil - NOTHING ELSE!
If you sew a lot, get it serviced proffessionally - they will do the areas you can't access.
Posted on Oct 22, 2007
  • 619 Answers
SOURCE: machine does not speed up after pressing harder on foot pedal
Hi , one of the transistor parts was open / need to visit with technical men to open the speed up pedal to replace parts , you enter zip code near you then go .
Posted on Mar 18, 2008
mallow1
  • 35 Answers
SOURCE: lost manual to Hello Kitty sewing machine made by Janome
I've always been able to get a free PDF downloadable manual from Janome. They are happy to send you a manual for your specific machine via email, and they've always been very helpful to me. Here's a link tothem:
http://www.janome.com/index.cfm/ContactUs/Machine_Support
Hope this helps!
Posted on Aug 16, 2008
  • 323 Answers
SOURCE: foot pedal assembly for White sewing machine
You only need to replace the cord if it has been damaged. It will cost less if you just take the machine , cord and control to a local technician and have him just replace the foot control. Let him test it first. A generic foot control should cost less than $30.
sewman7
Posted on Dec 29, 2008
lavon82931
  • 17 Answers
SOURCE: owners manual for sewing machine Janome JF1004
Try this web site for sewing machine manuals http://sewing.about.com/od/beginner1/ig/Sewing-Tools/Sewing-Machine-Manuals.htm
Posted on Jan 25, 2009
Janome new home 691 Power cord and foot pedal
try checking a1sewingmachines.com and call them about the parts you need.
Jul 12, 2013 | Janome Sewing Machines
How to set up
  • Remove your Janome sewing machine from the box, placing the main machine on a hard surface appropriate for sewing and the accessories and smaller items to the side. Unwrap all of the wrapped items. Remove the tape used to protect the machine during shipment. Set aside the power cord and foot pedal.
  • 2
    Attach the power cord to the machine. The power cord plug-in area is located on the lower right side of all Janome sewing machines and has a series of metal prongs and a power switch. Fit the female end of the power cord onto the metal prongs and push it gently until it no longer moves.
  • 3
    Attach the foot pedal to the machine. The foot pedal plug-in is also located on the lower right side of all Janome machines, right next to the power cord plug-in. Press the foot pedal plug-in into place gently until it no longer moves.
  • 4
    Turn the power switch on. The power switch is located in the same area as the foot pedal and power cord plug-ins and is a rectangular black switch. Press this button. The sewing machine light will turn on.
  • 5
    Place a spool of thread on the spool pin, located on the upper right top side of the sewing machine. Place the thread so that the thread unwinds in a counterclockwise motion, with the thread coming off the back of the spool.
  • 6
    Insert a needle into your machine. Consult your owner's manual for the appropriate size and type of needle. Turn the needle clamp screw, located above the needle area, toward you to loosen it. Turn the needle so that the flat part of the upper shaft area faces the rear and slide the shaft of the needle up and into the needle area. Turn the needle clamp screw away from you to tighten the needle and lock it into place.
  • 7
    Wind the bobbin and insert the bobbin into the bobbin case. This procedure may vary depending on the model of your Janome machine, so consult your owner's manual for specific instructions.
  • 8
    Thread your machine according to the directions in your owner's manual. Like the bobbin, this procedure can vary widely depending on the model of your Janome machine.
  • 9
    Set your tension, located on the front of the machine, to halfway between three and four. The tension may be a dial or it may be computerized and located on the LCD screen, depending on your model. Consult your owner's manual to find out how to set the tension.
  • 10
    Place a piece of scrap fabric in the machine and sew a test seam before you start to work on a project to make sure all of your settings are correct.
    Things You'll Need
    • Janome sewing machine
    • Owner's manual
    • Needles
    • Thread
    • Bobbin
Jan 11, 2012 | Janome Sewing Machines
Bobbin for janome model 3022
You need Janome bobbins for this machine........@ any dealer
Nov 16, 2011 | Janome Memory Craft 9000 Computerized...
Will cords from janome 8000 fit a janome 8080
some of the cords are interchangeable and the foot petal are also.
Jan 24, 2009 | Janome 8080 Computerized Sewing Machine
Lost Power Supply Cord
HERE is a link to 24 options in Lakewood area
...........any Janome dealer will be able to supply a power cable, do you also need the foot control ?
HERE is Janome Dealer Locator site
Best Wishes
www.bargainbox.com.au
Nov 13, 2008 | Janome 8080 Computerized Sewing Machine
Janome Memory Craft 9000 Computerized Sewing Machine Logo
195 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
