Question about RCA 27F534T TV
I am staying in a rented apartment. I unplugged the RCA TV to plug something else in. Now when I replug in the TV, it remains on Standby. I can't get it to come on.
You have to open the cabinet and inspect main board for bad solder connections or capacitors that not look good, of course be carefull handling it there are extreme voltages around this board. if not sure can handle the job contact a technician, but most problems are related to bad solder connections
Posted on Mar 23, 2009
Proscan LED TV Will power up the red standby light & standby on amber when turned on but does not show picture or sound unless I unplug and replug over
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 14, 2016 | Proscan Televison & Video
My set. Top box wont turn on it stays on stand by mode only
have you unplugged it?
If not unplug it count to 30 and replug it in.
Usually if it's in standby mode a couple things could be going on. One which is the most common is that the box hasn't downloaded all the info it needed.
Every time something reboots it always loads stuff such as color/sound/grain/hz/hd/standard/dish/cable etc. To rectify it you do a reboot.which is unplugging it and plugging it back in. Good luck hope this helps
Jun 20, 2014 | Televison & Video
Why is my RCA STAV-3860 not coming on?
It sounds like the unit is getting power but is going into standby mode due to an internal fault. Sadly, newer receivers these days are not designed to be repaired but replaced!
Jun 13, 2014 | RCA Radioshack 31-5003 Stav-3860 60-watt...
How to get rca tv out of standby mode
Try tv unplug,replug an hour later.The tv should reset it self and work.Not,than the power supply board is the cause,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Aug 27, 2010 | Sylvania LC320SS8 32 in. LCD Television
My Sceptre LCD TV (X32GV-Komodo0 power turns on
1. check power supply
2. check flyback
Ether or you have a ppower fauilure in the unit. and its probably blowing fuses.
Aug 31, 2009 | Sceptre X32GV-Komodo 32 in. LCD Television
My Sceptre LCD TV Power turns on briefly (blue
Power supply is the place to look, look for bulging on top of the capacitors in the secondary side of the main power supply.
Aug 29, 2009 | Sceptre X37sv-Naga 37 in. LCD Television
Disc Tray Won't Open
I have contacted Venturer Electronics Inc. (which have recently purchased RCA); they are in Toronto, Ontario. They suggested to perform a Manufacturer Reset (as follows); and if it works; system should power up [this means there was a glitch in the software]...(this usually happens when system is plugged into a power bar or surge protector) if not, contact them @ 1-800-721-4007. They honor the manufacturer's (RCA) 1 year warranty... with receipt.
To reset Unit:
Unplug Unit from AC power (other wires can stay connected)
Press the On/Standby button in front of Unit 15 times
Wait 30 minutes
Replug Unit to AC power
Press the On/Standby button to power up unit
Wait couple of minutes for unit to do its thing
**If unit works properly, then ensure not to plug unit into power bar or surge protector, keep plugged into wall.
**If unit will not power up properly, contact them for further instructions.
Hope this is helpful....
My Unit powered up wonderfully and is currenlty working like a charm.
Dec 29, 2007 | RCA RTD258 System
Rca tv
guessing the audio output or a capactor
Dec 15, 2007 | RCA F25305 25" TV
RCA 27F534T TV Logo
93 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
