Question about Philips 60PP9753 60" Rear Projection Television
TV Picture is distorted
All of a sudden today the tv picture went kaputz.. it looks like we need 3-d glasses to view correctly.. we see green, white, and blue colors only...
any ideas ?
I checked the dvd & xbox signal.. both the same so i validated that its the tv itself..
Thanks in advance,
Mike
  • Philips Master
  • 3,459 Answers
1) Convergence chips are shorted....One quick test is to desolder and remove both STK392 chips....then power the set on. If the tubes light up the chips were shorted. You can get new ones from www.TvRepairKits.com
2) Another possible problem is a bad HVG - AKA the flyback.
Try the convergence chip test first. Note: On some Philips sets you can just unplug cable "1516" instead of removing the chips.
For instructions on how to find/remove cable 1516 visit the website listed above and click on their tips page. On that page click on the "Magnavox DPTV3xxx Checks" link.
Posted on Feb 13, 2009
  • Edward
    Edward Feb 14, 2009
    Your TV most likely has one or more possible problems.
    Problem #1: Convergence Chip Failure ( common problem )
    Here are some of the most common symptoms and example photos of a convergence problem
    • Screen looks 3D
    • Colors don't line up
    • One or more colors can't be adjusted when using the convergence menu.
    • Screen is bowed or warped.
    Here is a quick test....
    Using your original remote go-to the tv settings then goto the convergence section.
    Try to adjust the red and then the blue convergence.
    You should be able to move them up, down, left, and right.
    If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
    Solution #1
    You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
    Problem #2 CRT Fluid is Cloudy
    Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
    Picture of a set that needs the fluid changed.
    TV set after fluid change
    Solution #2
    What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
    Scholar:
  • 150 Answers
Hi, common issue in your set, the convergence IC`s have failed, if your real proficient at soldering & un-soldering you can replace them, if not you need to call a tv tech, video-tek
Posted on Feb 08, 2009
Triple colored ghosts
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2010 | Sony KP-43T90 43" Rear Projection...
The color went green all of a sudden on my 51F500, and the autofocus won't fix it.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 14, 2010 | Hitachi 51F500 51" Rear Projection...
Picture is wavy and double vision
Projection TV sets have two very common problems listed below.
*Screen Looks 3-D
*Colors wont align
Jan 06, 2010 | Hitachi 46F500 46" Rear Projection...
Seeing red, blue,geen wavy lines across screen which distorts picture while viewing.
*Screen Looks 3-D
*Colors wont align
Jan 02, 2010 | Samsung HL-R4266W 42" HDTV-Ready...
Akai PT5499hd that has suddenly lost color alignment
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 23, 2009 | Akai PTH5498 54" Rear Projection...
Picture all of a sudden went distorted on top and bottom, like a curve shape. Is there a way to fix this or has anyone experienced?
Projection sets have two very common problems.
The first common problem is convergence
*Screen Looks 3-D
*Colors wont align
Nov 09, 2009 | RCA HD61LPW175 61" Rear Projection HDTV
Wavy lines appear across the screen
*Screen Looks 3-D
*Colors wont align
May 01, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Arched pink lines across screen. Now green and pink double stacked wording.
*Screen Looks 3-D
*Colors wont align
Oct 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Sudden discoloration, ghosting, bowed horizontal lines in top and bottom of picture
*Screen Looks 3-D
*Colors wont align
Problem #2
Nov 10, 2007 | Samsung PCL6215R 62" Rear Projection...
Problems with TV
Our 37 inch Sanyo LCD HDTV has a problem with the picture distorted by being too wide. This has beenia problem for the duration since we bought the TV about three months ago. The PIX Shape button on he remote does not adjust this problem. We need help in solving the problem. Thank you.
fred_story@cpmcast.net
Oct 24, 2007 | LG LRSC26980 25.2 cu.ft. TV Refrigerator...
Philips 60PP9753 60" Rear Projection Television Logo
171 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
