Question about APS787 Prestige Remote Start and Security System w/Keyless Entry
Location of prestige remote start
I have a 2004 GMC Truck with a prestige remote start. I am the second owner of the truck. My remote start has quit working but the door lock still works on the same remote so I think it must be a problem with just the remote start. I don't know where the remote start is located on my vehicle to see if it is a problem with a fuse or something. Any info would be appreciated.
  • 27 Answers
If the signal lights blink when you try the remote start take your truck to advance and have them check for codes tell them you want a code check and if there are codes ask what they mean and have them cleared my 2007 silverado did that if the check engine light was on
Posted on Feb 02, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
My GMC Yukon that has an APS997 installed (not by me), and now it won't start.
assuming its an aftermarket voxx alarm your talking about either notify the old owner about problem and see if a remote is available or notify voxx support for assistance the following links are install wiring and owner manual
http://media.datatail.com/docs/installation/184503_en.pdf VOXX Electronics APS997 Home
May 30, 2017 | Prestige Remote Start
My remote is not working
you may go to shop ignore your prob
Feb 14, 2014 | Prestige Remote Start
I have an astro start remote 4204/5204 in a 2004 GMC Sierra, when trying to start the vehicle, its starts then immediately stops then starts to crank over motor but does not start...
I don't have a solution, but I have a variation of this problem... My remote start will start the vehicle (2004 GMC Yukon) then shut it right back off after less than 1 second. But, ONLY when it's cold. Once the truck warms up, the remote start works fine. The "start fail" code says "Engine over revving"... Which is odd, because the engine idles the same cold or warm - around 1100 to 1400 at start, then down to about 800 after just a few seconds. Par for the course for me - no one has ever seen this problem before. I was told by a friend not to install an aftermarket remote start on a GMC Yukon, as they are nothing but trouble, but I didn't listen.
Nov 19, 2013 | Vehicle Parts & Accessories
My 2004 GMC sierra Denali pickup battery drains
After you get the truck started disconect you battery cable and see if the truck continuse to run. if it dies you are having a problem with the charging system. make sure dont have any interior lighs left on.
Mar 05, 2013 | 2004 GMC Sierra Denali
I, i have a GMC envoy 2004 V8 whit two serpentine,i change the small serpentine(tensioner) but,before i desconected the batterie,,,,Why my car no star now????
Hello,,If you have an after market car starter/keyless entry,the car wont start with the hood up also when unhooking/hooking bateries back up with the hood open throws the remote into a lockdown mode,with every thing hooked up and ready for the road,,close hood and lock up your suv and let sit for about ten to fifteen min then unlock and it should start. i sat at a hospital for two hours boosting my truck, it would spin over quite fast but wouldnt start and thats what i did and it fired rite up,,good luck..
Feb 09, 2013 | 2004 GMC Envoy
My preinstalled remote starter on my truck has a combination/sequence that the dealers salesman could not get roght bit twice to start pickup. im looking for fimiliar combination/sequences that my seem to...
If you have to press the vehicle's door lock AND the remote starter button...something is definitely wrong with the installation. If the prestige is a one button unit, try pressing the button twice within two seconds to start vehicle (press...thousand one, release, press...thousand two,release) this is the default setting.
Aug 05, 2012 | Prestige Remote Start
Windshiekd wipper want cut off
The wiper relay is stuck in the open position. This relay location can be found in your owners manual and it will most likely start working if you tap it lightly, regardless to keep it from happening again, replace it. Not positive on it's location on your truck but usually in the under hood fuse box passenger side rear. Hope this helps.
Apr 09, 2012 | 2004 GMC Sierra
AUDISVOX REMOTE START APS-620 WONT START AT TIMES.
i am an mecp first class certified mobile installation technician with over 10 years experience. email me at face2face11@bellsouth.net and i'll see if i can help
Jan 14, 2009 | Prestige Remote Start
Free programming instructions for Prestige remote
YOU can call prestige tech support at 1800 225 5074.. or just put the key in the ignition turn the key all the way to the right without starting the car then flip the vallet switch usually located at the bottom of the dash drivers side, flip the switch on and off three times, you will hear a chirp then you should press the first button on the remote for 2 seconds then flip the swith on and off one more time , then press the second button the remote for 2 seconds then flip the switch again on and off one more time then press the 3rd button on the remote for 2 seconds... After which... remove the key from the ignition and your done... Try the remote to see if it works the way it should if not do it all over again..
MSB....
Oct 13, 2008 | Gmc Dodge Ford Reverse Back-up Sensor...
APS787 Prestige Remote Start and Security System w/Keyless Entry Logo
362 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
