Question about Canon FAXPHONE L80 Laser
Canon faxphone L170 won't copy
My canon faxphone L170 says there is a paper jam & to open front cover....I have opened & opened & opened it & looked everywhere for a paper jam....I see nothing. It does not even look like it picks paper up from the paper bin on the bottom
  • Anonymous Mar 14, 2014
    paper jamms
    Scholar:
  • 75 Answers
If you look at the top piece of paper in the cassette is there a smug mark or wrinkle in the paper. you my just need to clean the feed roller. ( black or gray roller ) . I'm not sher on this model if it is a rear paper feed or a cassette from under if it is a back feed one look in side the paper shoot of any fourn object is in there. Hope for the best.
Posted on Feb 02, 2009
How do I open the machine to change the toner cartridge?
You just pull down the front cover that is just below where the copies come out of the machine. You will see the toner cartridge. It has a small "handle" on it. It just pulls out the front of the machine. Then just unpack the new one making sure to remove the seal tape if it is installed on your new toner. Then re-install the new cartridge and close the door. If you have your users manual for the machine, the instructions are in the manual. If you are using a OEM Canon toner cartridge I believe the instructions are included in the box.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 28, 2010 | Canon FAXPHONE L170 Plain Paper Laser
My canon faxphone L80 keeps saying check cover. I opened and closed the cover. I removed the ink cartridge and don't see any paper jammed. If I unplug and replug the machine the message temporarily goes...
hi, i think that somone was oppened the cover by force, that can damadge the cover switch. open the front cover, look inside is there any foreign body, is the cover switch looks fine, look at this picture from the user guide page 152: mabroukmedal_6.jpg
Nov 03, 2010 | Canon FAXPHONE L80 Laser
Volume on Canon Faxphone L170
By pressing the menu button left of the LCD display,scroll to usersettings press ok.Scroll to volume settings press ok and change volume levels there.
Dec 11, 2009 | Canon FAXPHONE L170 Plain Paper Laser
We have a Canon Faxphone L170. Someone sent a fax
On the controll panel there is a diamond shape picture with a eye in it.press that bottom and clear the fax that you received.There is no other way.You will have to phone the sender and ask them to change the papersize settings on the fax machine.
Dec 08, 2009 | Canon FAXPHONE L170 Plain Paper Laser
Display states paper jam, open cover, reset... paper comes out 90% & then gets stuck... can pull paper out & last 1/2 inch has an imprint like the paper is in a vice grip
in this case I think you not choice the correcte paper if you make print from the computer go to the printer and try to choice a corect size paper ( A4)
Dec 01, 2009 | Canon FAXPHONE L170 Plain Paper Laser
Would like to receive legal faxes through mpf on my canon l170
Starting on page 4-8 and continuing thru step 3 on page 4-9 will allow you to setup the mp feeder for legal size paper on your Faxphone L170.
http://gdlp01.c-wss.com/gds/0900006140/FAXPHONE_L170_Basic_Guide_EN.pdf
Oct 26, 2009 | Canon FAXPHONE L170 Plain Paper Laser
Change the time date and year
This is a link to Canon FaxPhone L170 Basic Settings Guide. Look on page 3-4 in Registering Information section.
Oct 08, 2009 | Canon FAXPHONE L170 Plain Paper Laser
Fax will not grab paper
Ther is a separation pad that developes a divot caused by the feed roller. Simple fix. order a new separation pad. It's located under the top cover. Just move slowly and identify the latches that hold the cover down. Don't force anything.
Another possibilty. If a document was forcably pull out of the document area the "White paper bar above the scanner glass might have been jerked out of it's normal position causing a blockage in the path. Investigate this possibility before ordering parts.
Jun 15, 2009 | Canon FAXPHONE L170 Plain Paper Laser
Canon pc981
either dubree on the rollers or on the corona wires, wires clean with acalohol and q-tip, very carefully or you will brake the fire, look where the line is at and open the machine and locate where the issue is and remove and clean this area very carefully.
rod
ps
type in address bar
canon pc981 l170 a mark down the middle of paper
enter
rod
Feb 06, 2009 | Canon FAXPHONE L170 Plain Paper Laser
Canon FAXPHONE L80 Laser Logo
290 people viewed this question
old marine
old marine
