Question about Toshiba 50HX70 50" Rear Projection Television
Comes on then shuts off power light flashes
Could turn it on.. runs for a few min then it shuts off and the power light flashes on and off. now it wont come on at all
  • Shelly Mahaffey
    Shelly Mahaffey Feb 10, 2009
    After shutting it off.I have to wait 20minutes before it will come back on again.Even if it has only been on for a few minutes and is shut off it will not start back up again and the red light just flashes on and off???
  • whizzard69 Feb 28, 2009
    My set does the same thing. We were watching it, the screen went blank, and no sound. The red "power on" light would come on and then it would go off. If I left the set on this light would cycle, on and off for as long as I left it on.
You need part# stk392-110 and someone to put it in
Posted on Jun 25, 2009
Sony bravia vpl-aw10 lamp come on runs for 2-3 mins then switches of and lam p cover light flashes 3 time repetedly
Here is a link to the manual. It states you need to replace the lamp because it has reached it end of life an over heating.
https://docs.sony.com/release/VPLAW10.pdf
Jan 28, 2015 | Sony Bravia® VPL-AW10 Projector
I have a samsung air conditioner - model AQV24NS and after 10- 15 mins it shuts down both red & green lights start flashing. The only wayi can get it to work again is to shut off the main power suply...
Please check outdoor unit. Compressor or fan motor getting high amps due to overheat. Clean condenser coil. If still problem, replace running capacitor. If out door fan less rpm replace fan capacitor. In some unit 2 in 1 capacitor is there. So replace one capacitor will rectify fan and compressor problem. Thanks. Helpful?
Jan 09, 2011 | Samsung Heating & Cooling
My 2003 dodge ram 1500 5.7 hemi has the engine light come on then the fuel gage went to E next the electronic throttle control light come on flashing. After the etc light came on i had a loss of power. I...
I had the same problem with my, 03, hemi. I did not wait 15 min. turn off and back on was all that was needed to reset, "red flashing light lower right hand ". though another 8 or 9 on off's, Engin Light also goes off, untill next time. All i did was pulled off my Air Intake box and hose, so i could get to butterfly on throttle bodie, sprayed carb cleaner in there. and it was very dirty. after put back togather, give it a few.... mine did not start right up, when it did idle real ruff even died few times...Once the computer re adjusted ran like it did when i bought it....that was 2 weeks ago, still no eng light, no flashing red ones either.
Jul 13, 2010 | 2004 Dodge Ram 1500
32 LCD, Shuts off, power light flashes 7 times. Never stops. Will not turn back on unless I unplug. Works for a few mins and shuts off again.
Power supply board is dead.Replaced the power supply board will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 22, 2010 | Panasonic Viera TX-32LX70 32 in. LCD TV
Power shutdown
Did you update the firmware to 2.43? Many people have been getting bricked ps3s because of it. lets hope you still have warranty.
Sep 20, 2008 | Sony Playstation 3 (PS3) Console
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Toshiba 50HX70 50" Rear Projection Television Logo
316 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
