Question about Dell Dimension 3100 PC Desktop
Dell precision 3100 machine will not boot up
Lights 3 and 4 illuminate on front panel of computer. Machine beeps 6 times Mine does the same, it seems to do 2 long beeps then 2 short, then 2 long.
Lights 3 and 4 are lit, one and two are not visable.
Any advice please
  • Dell Master
  • 4,806 Answers
Hi there
The beep codes indicate that there is a problem with the system memory, it may have to be changed.
Thanks for using fixya!!!
Posted on Feb 02, 2009
Dell Precision T1500 beeping 6 times and will not boot up.
Remove whatever USB cables in the front USB ports below the DVD. Then try starting it should work. If not remove USB from the rear one at a time. Once it restarts replace USB cables into ports.
Mar 11, 2013 | Dell Dimension 3100 PC Desktop
Dell precision 490 led 4 remains on
try to clean the memory slot of your computer as well as the memory module then power up your PC. just do hardware maintenance by means of cleaning all any dust inside the computer. Hope it helps thanks.
Nov 02, 2011 | Dell Precision Workstation 490 - MT -...
I have a Precision 670 that I put two 512MB DDR CL3 ECC REG ram sticks in and it will start up but when it reboots, it beeps two slow, two fast, two slow and stops. lights on front turn: AC are...
The issue seems to be that your PC can not handle the supported memory. After review of your system specs on dell's website, I see that you're computer would require DDR2 Memory. This seems to be what is causing the beeping. Please check to ensure you are using the correct memory stick. I hope this has helped
Jul 05, 2011 | Dell Precision Workstation 670 PC Desktop
Dell precision 490 led 1 & 4 on
As description of Manual of the pc ,
led 4 is means The computer is in a normal
off condition; the computer is
connected to an electrical
1 and 3 illuminate for Memory modules are detected, but a
memory configuration or compatibility
error exists.
• Ensure that no special memory
module/memory connector placement
requirements exist.
• Verify that the memory modules that
you are installing are compatible with
your computer.
• Reinstall the memory modules and
restart the computer.
• If the problem persists, contact Dell. (if have warranty)
But you can install and check one module at a time.
if not compatible each other may not display.
May 15, 2010 | Dell Precision Workstation 490 - MT -...
Machine shutsdown hard shortly after boot
OK, i experience this before, i think your situation is mostly like mine, and this problem may cause by the your laptop power adapter, please replace a new adapter and see how is the result. Hope this help.
YBC (/\)
Oct 07, 2009 | E-Machines 6809 Notebook
When I turn the hard drive on it beeps 6 times intermittently and doesnt boot up as normal. The monitor is switched on but there is no picture. I tried another monitor with my hard drive and that worked...
Unplug power from the machine for a period of 5-10 minutes.
Plug it back in and attempt to boot. Carefully notice if there are any beeps again, and listen for pauses in between. Dell beep codes go in a three pulse pattern I.E. 4-Slight Pause-4-Slight Pause-2-Pause/ and repeat.
After this, you may have to open your machine and assure that everything is well connected.
There is a chance however that a major system component has failed and needs to be replaced.
Hope this helps.
Apr 13, 2009 | Dell Dimension 3100 PC Desktop
If your computer is beeping at you, 9 times out of 10 its going to be an issue with the memory or video. (more often the memory) Try re-seating both. If your still hearing the beep fest, below is a list of the most common beeps and what they refer to. This will help you to find out what needs replacing.
Long beep followed by 3 sequential short beeps. This issue is linked to your Graphic card configurations
Short beep followed by three sequential long beeps You are facing a system memory problem
Beep- PAUSE- Beep- PAUSE- Two sequential beeps This error is linked to your CPU
Three beeps-PAUSE-Three beeps-PAUSE-Four beeps You have an issue with the video memory
Three beeps-PAUSE-Four beeps-PAUSE-Beep This is linked to an error with your Graphic Card
Four beeps-PAUSE-Three beeps-PAUSE-Beep You have a system memory problem
Five short beeps You are facing a problem with your CPU
Long constant beeps It’s a system memory problem
Short constant and high-pitched beeps The temperature of your CPU is too high
Jan 05, 2009 | Dell Dimension 3100 PC Desktop
Boot Problems... Complicated...
The IBM Netfinity 5600 is a complicated beast for sure. You really need to get a copy of the Netfinity Manual from IBM (not on the web site fyi.). It's as big as the machine unfortunately. In section 3, p.124 it lists 3-3-3 beep code as "No memory has been detected in the system" solution is "Reseat mem modules or install mem modules. If prob persists get machine serviced." On the previous page, 3 short beeps (only) on POST indicate "system mem error. combo only occurs when video bios cannot display error msg. replace the failing mem module." You might also want to check the light-path diagnostics inside the machine. A little light will be illuminated right beside the bad DIMM.
Jun 06, 2008 | IBM Netfinity 5600 8664 Server
Dell Dimension 3100 PC Desktop Logo
476 people viewed this question
Alun Cox
