Question about RIM BlackBerry Pearl 8100
Slight water damage
I got the phone wet. As soon as it hit the water i got battery out and left it on the dash of my truck with the windows up for hours to dry. Everything works fine still except when on the phone people cant hear me and i cant hear them. My speakers are fine because i can still listen to music its just when i try and use the phone. I just got this phone please help. and taking it to service provider is out of question cant afford that.
    Problem Solver:
  • 9 Answers
Don't have a soulution if you don't want to go to the provider. Enless the dot that is on the back behide your battery isn't red then you don't have water damage some things just happen. If it isn't i would take it in seeming you just got it.
Posted on Feb 03, 2009
Lg vx6100 won't turn on or charge
There may be liquid damage present. First using a flashlight, inspect the battery contacts and data/charging socket for green mold/water damage. If nothing unusual is discovered you could disassemble and inspect the inner circuit boards for white residue that would be left behind from water calcium, clean the calcium from the circuit board with a slightly wet toothbrush and dry with compressed air or a hair dryer.
Dec 22, 2013 | LG VX8300 Cellular Phone
Bought a new samsung wave 3 weeks ago went to charge it would not switch on again left battery out for 1full day it then powered up used it for another day or 2 went to charge it same problem.went back to...
Check the water damage indicators on the phone and battery. They are white stickers, and they will turn red if they have gotten damp or wet. Be aware that some phones can get water damaged from condensation, or being in a moist environment like a bathroom.
If the damage indicators are clear, they cannot prove that it has damage and you should take it back and talk to someone else.
Mar 02, 2011 | Samsung Cell Phones
Mobile in water not working now
Remove The Phone From The Water
The first step is to remove the phone from the water as soon as possible. The less time the phone spends submerged, the greater chance it has of being saved. The plastic covers that come with cell phones do provide some protection, but it takes a mere twenty seconds or less for water to get through these barriers and start causing damage to your phone.
Once you pull the phone from the water, remove the battery immediately. Cutting power is a crucial step when attempting to save a wet cell phone. There are many circuits inside cell phones that can survive getting wet, but only if they are not attached to a power source.
If your cell phone comes with a SIM card, remove it promptly. Do not heat the card, simply pat it dry with a soft towel, and put it aside until the rest of your phone is dry and back to working order. The good news is that SIM cards recover well from water damage. If for some reason, your phone doesn't survive the accident but the SIM card does, there are plenty of places that sell unlocked cell phones. Simply place your SIM chip into the new phone and go.
Salt Water Accident
Please take note; if your phone was submerged in salt water, you must rinse it in fresh water before the drying process begins. Even after the phone is dry, crystals can form and continue to cause damage and erosion.
Let Your Phone Dry
The next step you must take to save a wet cell phone is to allow the phone to dry. A great method in providing an optimum drying environment is to set the phone on the vent found on the back of a television set or cable box. The low heat emitted will gently dry your cell phone. Another trick to help speed drying is to place the phone in a bowl of dry rice. This will help draw out the moisture. You can also try placing the phone in a plastic baggie with a few silica packs that come in purchases such as shoes and electronics. Silica, like rice, absorbs moisture.
The important part of the drying process is to place the phone uncovered, in a warm, dry place and allow the moisture to evaporate completely. Another alternative is to place the phone on an air conditioner. The cold air will not damage the phone and the air from an air conditioner is very dry allowing the water to evaporate quickly.
Drying should take approximately three days at which time you can check to make sure the phone is clean and dry. It is at this time that you can re attach the battery and check if the phone works. If it doesn't, wait a few more days and try again. If the phone still doesn't work, take it to your local dealer, they may be able to repair it. Be prepared; getting a cell phone wet will void your warranty and most cell phones are equipped with a water damage indicator so the dealer will know the phone has been H2O compromised.
Alternative Drying Methods
There is an alternative way to save a wet cell phone that includes an alcohol soak. Alcohol is hygroscopic which means that it attracts water. Soaking your phone in denatured alcohol, or a 95% alcohol solution (regular rubbing alcohol is about 75%), soaks up all the water in the phone. When the liquid is dumped out, only alcohol, which will evaporate, remains. Make sure that the alcohol you use is denatured with only methanol as the chemicals found in other types can be damaging. This kind of alcohol can be purchased at your local hardware store. The alcohol soak may work best for phones that have been damaged by salt water or other liquids such as coffee.
Battery Caution
When attempting to save a wet cell phone, make sure you do not heat the battery as it could leak or even explode. Lithium-ion batteries are especially sensitive. In addition, many cell phones have plastic parts that can melt. Above all, do not try to save a wet cell phone by placing it in a microwave. You will destroy the electronic components and possibly the microwave in the process.
The above steps will help to save a wet cell phone, but be prepared. Often the phone will survive but the battery will not and the purchase of a new one may be in order. Good Luck!
Dec 05, 2010 | Nokia 2690 Cell Phone
I call have water damaged what should i do ?
Follow these procedure to save or revive your phone, remove Cell Phone from Water: Time is of the essence when it comes to saving a fixing a submerged cell phone, as soon as you see your phone in water, remove it quickly! Every second matters do this step quick.
Saving the Battery: In order to save the battery on your cell phone after it's been wet, quickly take the battery out of the phone as soon as you take it out of the water. Buy doing this you will ensure that minimal damage is done to your battery.
Drying the Phone Out: Quickly shake your cell phone to get all of the water out and reach for the paper towels. Press down on your cell phone to make sure all of the excess water has come out. If you have accessories such as cell phone covers, take them off promptly otherwise water will still be stuck in your phone.
Saving your Info: If your cell phone takes a SIM card, quickly remove it before the phone dries. While you may still loose some of your information, you won't lose it all if you take the SIM card out of your cell phone in time
.Removing Excess Moisture: To remove the unseen moisture in your cell phone you will need to cover it with either Desiccant gel packs or rice. Desiccant gel packs can sometimes be found when purchasing brand new shoes or clothes. Make sure your cell phone is completely covered with either one of these for up to 3 hours.
Vacuuming: Take your vacuum hose and place it up to 4 inches away from your cell phone with it on. While this won't remove all of the water, it will certainly eliminate the big spots of water damage.
Turing the Phone On: After allowing your cell phone to sit a day or two with the power off, turn it on to see if it works. More than likely if you followed these steps as soon as your phone was submerged, it will cut on. If not, you will have to purchase a new cell phone because the one you have can't be saved.
Take care.
Jul 21, 2010 | RIM BlackBerry Storm 9530 Smartphone
Pantech matrix got wet wont charge
your battery is probably bad. take out the battery and plug it up and try to turn it on without the battery in. if it works just replace the battery. if not then your phone is fried.
Jul 14, 2009 | Pantech Matrix Cell Phone
ENV2 got wet and now the verizon logo is all that flashes
i think you may have to get a new phone i had a friend who had an env2 got it wet and now it doesn't work at all. env2's don't like water
Apr 14, 2009 | Verizon Communications enV2 Cellular Phone
Water damage on LG 8800 venus
FILE IT AS STOLE AND YOU CAN GET A NEW ONE B/C THERE IS NO COVERAGE FOR WATER DAMAGE
Dec 14, 2008 | LG VX8300 Cellular Phone
Left colum of buttons wont' work
There may still be some water or moisture under the keypad. The water may leave some conductive residue. The phone should be taken apart and properly cleaned and dried. It is also possible there there may be water damage and parts will have to be changed.
Jerry G.
Jun 11, 2008 | Samsung SCH-u340 Cellular Phone
Navigation keys do not work
dear freand you have to change the flex cable on your phone.this is not an easy job and you haved to take to a technician.
Apr 02, 2007 | Motorola Mobility RAZR V3
Problem
oooh doesnt sound too good! but my phone got a bit wet and stuffed up quite a bit so last night im my room on the shelf, i took out my sim card, battery, back cover and left it open to get some fresh air. and now it works fine:) goodluck you might want to try that but yours was alot wetter than mine!
Nov 23, 2006 | Motorola Mobility V265
RIM BlackBerry  Pearl  8100 Logo
146 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
