Question about Microsoft Xbox 360 Console
NO PICTURE MY XBOX360 HAS SOUND NO PICTURE CHECKED ALL CABLES HOOKED CORRECTLY
    Problem Solver:
  • 15 Answers
Homerunkevin, Right go to the back of the xbox and on the AV cable there is something that looks like a button. Switch is across and try again. I had the same problem with my Xbox 360 then i figured that out.
Good luck,
Ben
Posted on Feb 02, 2009
How do I hook up a 360 the magnavox. T.v
Your picture is small, but it looks like you've got available HDMI jacks on it. if so, connect and HDMI cable between the Xbox360 and you're done! High Def video and audio will be sent to the TV when you select the input that matches the one you've connected the Xbox360 to. More details linked below:
How to hook up your Xbox 360 or Xbox 360 to TV
Mar 23, 2015 | Televison & Video
How connect to BenQ mp620p- xBox360 ? Thanks good luck
If you've got the version with a DVI input, use a HDMI to DVI cable. That'll take care of picture but not sound. You need to hook up an audio cable that finishes in a 3.5mm stereo jack if you want to use the Benq's speaker.
If you have the older version with just a VGA input then buy an Xbox 360 VGA cable. You'll also need an audio adapter; 2x phono/RCA sockets going to 3.5mm stereo jack.
Sep 09, 2014 | BenQ MP620p DLP Projector
No sound coming out of speakers tuner or cat/tv
Please add details of setup so I can help you. For example. My Directv box hooks into my HDTV HDMI. Sound is carried inside that cable. I then get sound on my TV from my Directv RCVR without any other hookup. But I do have more. I use an optical cable to go into my Denon 1312 TV/optical input. Since my Wii, PS3, VCR, and formerly Xbox360 all plug into the HDTV inputs and I use it to switch. The Denon is not HDMI capable so this is best for me.
This is the first thing I would try. hook the HDMI to your HDTV from the CATV/SAT box and turn up the sound on the TV. [Box and TV on and correct input used] If you hear audio, the hook it back up as before. Now, turn on the Denon to radio. and turn it up. Got sound?
NO: check speakers and speaker setting. Let's say you have speakers hooked to A but not B. is the selector on B or AB. That won't work. It has to match the hookup. If speakers are on A only, select A only, etc. Also check with known good speakers. Also check all cables to be plugged into the correct spot and plugged in fully.
Thanks PM me if you need more help.
Aug 07, 2014 | Denon AVR-1601 Receiver
I have sound but no video i have plugged every thing correctly
If there is a switch on your AV cable make sure it's switched over to whatever mode you are using. Sometimes if it's half-way I get no picture.
Jul 22, 2009 | Microsoft Xbox 360 Console
My xbox360 has sound but no picture it was working fine an hour before this
Your graphics encoder chip (For HD & component mode) needs resoldering to the board. These chips get very hot, and with the xbox's poor cooling system, this fails to dissipate the heat correctly.
We repair this and give a 4 month guarantee on all work.
FixMyConsole
Jun 18, 2009 | Microsoft Xbox 360 Console
My x-box 360 has no picture when turned on.
Your XBOX 360 has a video problem. A different cable will not fix this. It needs to be reflowed. Look online on how to reflow an XBOX360 or send it in for repair.
May 28, 2009 | Microsoft Xbox 360 Console
My xbox 360 has no picture or sound
Check your Monitor. if you are not getting the Red lights in front of the Xbox360 then nothing wrong with the wires.
you can try another Xbox360 cable goto you local store buy one, and test it, if the same result you can return the cable abit of a hassle though.
But usually when the cable are bad the red will flash in front of the Xbox, otherwise test the monitor or the TV with something else.
if all that checks out, then perhaps the XBOX360 is just plain dead.
they usually last about 4 years anyways. DVD drive goes bad. Video could be bad. hard to say
Dec 19, 2008 | Microsoft Xbox 360 Console
HDMI XBOX360 Elite -"No Signal"
The connection order can be a key issue as to whether or not the HDMI signals will pass through the system. For best results the receiver should be turned on first, then the source device(s) and then the display. The reason for this has to do with getting the equipment to handshake properly for the HDCP protocol.
If HDMI video will not pass through your receiver, you may with to just connect the xbox using the component cables. Since component will pass through 720p and your TV is 1080i you should expect the same qualtiy and a more crisp picture.
Oct 12, 2008 | Denon AVR-2307Ci Receiver
Connected My Xbox360 To My LCD Getting Picture No Sound (Used Xbox360 VGA Connector)
On your output cable there is a smal switch that says HD or TV. Make sure that is on the correct spot!
Jan 09, 2008 | Video Game Consoles & Games
Help!!!!!!!!
Hook up Xbox360 to what, internet. Just plug the ethernet cable to the RJ-45 plug to your Xbox360 to your cable modem or router. If you mean you want to set it up, follow this link. http://xbox360.ign.com/articles/663/663050p1.html
Aug 25, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
