Question about RCA F36650 36" TV
TV will not power up. Makes a buzzing sound when plugged back in
I turned my tv off before going to bed and the next morning it would not power up using the remote or power button. I unplugged the tv for 1 minute and when plugging back in started making a buzzing sound.
  • dozer430x Feb 06, 2009
    i shut the tv off went to bed, turned it on the next day will not turn on but makes a busing only when you plug it in. what is the problem?
  • Jayne Donner Oct 05, 2013
    Nothing, no light, no sound at all
  • 28 Answers
Replace the Flyback Transformer.
Posted on Feb 03, 2009
Westinghouse tv power box making buzzing sound
Hi I'm Peter, There is a bad connection and most likely the buzzing sound is a relay going bad internally.
Apr 19, 2014 | Westinghouse Televison & Video
My sony trinitron is blinking red and won't turn on
THIS IS NORMALY CAPACITORS IN THE POWER SUPPLY THAT NEED REPLACING
Jun 25, 2013 | Sony FD Trinitron WEGA KV-34HS510 34" TV
I have a JVC model HD-52G886 tv. that loses sound.
Replace or have replaced the Audio board in the set----a lot of them fail.
Mar 12, 2012 | JVC HD-52G786 52" Rear Projection HDTV
My rca 32" flat panel tv model l32wd22 won"t turn on
i have a l32wd22 rca -----went out -- the plug from the power cord to the power supply [ a two prong jack on the side of power supply was loose]
i bent the pins slightly then plug it back in and also taped it in place---now it works fine
Jun 16, 2009 | RCA L32WD22 32 in. LCD HDTV
Older 36 inch rca crt tv broken
Your high Voltage anode button that connects into Picture tube may have came lose Rember Picture Tube if not broken Holds 36,000 volts if not discharged, Have you Look under chassis to see if board it cracked? Sounds like your FBT?
Dec 23, 2008 | RCA D52W23 52" HDTV CRT TV
RCa P52926 52inch
CHECK THE SIMPLE THINGS --MAKE SURE THE PLUG IS STILL PLUGGED IN AC...IF YOU HAD SOME POWER INTERUPTIONS ...MAY HAVE BLOWN THE MAIN FUSE BY THE POWER CORD.DO YOU SEE ANY LED LITES ON THE FRONT OF TV..POWER INDICATOR??? .REMEMBER ,ALWWAY S UNPLUG THE TV IF YOU TAKE THE BACK OFF...TUNICA
Sep 04, 2008 | RCA P52926 52" Rear Projection Television
Plazma TV buzzing noise
I have the same problem I can hear buzzing over the volume of the tv into the 30 range. I've had a tech out 3 times and he's coming out for a fourth. He's changed to power supplies and is bringing the 3rd next visit. From what I've read it has either to do with power supplies or grounding strips.
Jan 18, 2008 | Televison & Video
APEX TV problems
need flyback transformer #030531-5283
Nov 05, 2006 | Apex Digital GB5108 51" Rear Projection...
RCA F36650 36" TV Logo
262 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
