I don't shoot wide angle a lot, so I have a modest ultrawide zoom, the Tokina 193 19-35. It's pretty sharp and contrasty, but it seems to have quite a bit of barrel distortion at the edges. Sometimes that's useful compositionally, but more often it's not. My question is, is this endemic to ultrawide zooms, or just inexpensive ones? If I actually forked out for a better lens, would I see signifigantly less of this distortion? TIA,
I know this is commonly said, Tony, but I have to say it is not in keeping with my experience. If you look at the comments, they are mostly quoting some supposed other person's views. The website that gives visitors' opinions is statistically doubtful, as there is no attempt to standardise the expectations. Clearly the purchaser of a ??1000 lens has a higher expectation than the purchaser of a ??400, and may well therefore make a harsher judgement.
I try to make most of my comments based on actual experience (otherwise I say so), which means it is limited but direct. Having said that, I appreciate there are also sample variations, so there are no certainties.
It also is a very fine lens; I have one, but it is out of the country at the moment and I cannot check it for distortion. I do not recall ever finding it bothersome, and I am fairly fussy about curvilinear distortion as I often photograph buildings. It is certainly much lighter to carry round, and IMO much better value for most purposes than the 17-35 f/2.8L. [snip] -- David Littlewood
Was this helpful?
Yes
No
Solution #2
posted on Aug 01, 2007
Luisa_K - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Sigma has just released a 15-30 f/3.5-4.5 # B&H is listing it for $549.00 (Out of Stock). I don't have any idea how the new Sigma will perform, just mentioning it to add to your confusion :)
Rumour has it that Canon _may_ be announcing a new ultrawide zoom this fall. See "The new season will be hot ? [06/15/2001]" on this page: #
May the Light be with you.??
dan
Was this helpful?
Yes
No
Solution #3
Riddle - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Hi Lisa,
All wide angle zooms have barrel distortion at the wide and pincushion distortion at the tele end. The very best wide angle zooms have much less distortion, but it is still there.
I'm eagerly awaiting the first review of the 17-35mm f/2.8 lens for the Contax N1, because the designers will cut no corners to provide the best optical performance. The lens will probably be as good as, or better than, any wide angle zooms ever made. However, it will probably cost about as much as a sub-compact car or a timeshare in Hawaii. :-(
I'm not sure what options you have in the Canon range, but I do know that the 17-35mm f/2.8 L lens is not especially good for the price. I believe there is a consumer-grade 20-35mm at a price that offers good value but it probably has distortion that's no different from your current Tokina.
It's no use recommending the 17-35mm f/2.8 AF-S Nikkor as it won't fit your Canon mount, but it is a fine lens. It's justly popular despite its high price. For anyone wanting a cheaper Nikkor the 18-35mm f/3.5-4.5 AF-D is good for the price but (IMHO) there is a better option which also fits Canon:-
The Tokina 20-35mm f/2.8 is an excellent lens and has distortion figures that are less than half of the 19-35mm f/3.5-4.5 (the AF 193). It's optically superb with excellent sharpness. Contrast is slightly lower than with the AF193. The focal length of the wide angle end is little different from the AF-193 and the 18-35mm Nikkor; they are all between 19mm and 20mm despite what is says on the box.
The Tokina 20-35mm f/2.8 is a top quality "pro" lens for very little money. It doesn't have a USM motor, so you should try before you buy. But if you are happy with the focusing (and the manual focus action is superb) you will find little fault with this lens. Do try one! --
Best regards,
Tony Polson
Was this helpful?
Yes
No
Solution #4
Melissa - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Wide angle lenses are always prone to curvilinear distortion unless a lot of effort is put into correcting it. This is particularly so if the lens is highly asymmetric, as SLR wides generally have to be to keep clear of the mirror. The position of the diaphragm in relation to the optical elements is important.
With fixed focal length lenses, these problems can be solved reasonably well, at least in high quality lenses, and these are mostly low on distortion. With zooms, there is the additional problem of having several groups of elements moving relative to each other through the zooming range, plus the need to also keep other distortions down (spherical aberration, coma, chromatic aberration etc.).
Thus most wide zooms have some curvilinear distortion, even good ones. The better ones may have little or no distortion at some points in the zoom range but a noticeable amount elsewhere. I checked my Canon 17-35L recently and found it had very little distortion except between 30 and 35 mm, where barrel distortion became noticeable (I haven't measured it precisely, but it looks to be around 1-2%). Reports on other examples of this lens have shown significant pincushion at the wide end, which I did not observe. It thus seems that there is a fair amount of sample variation as well.
I guess you will just have to try to avoid placing any high vertical walls or other straight lines near the edge of the picture if it offends you. For the price of the Tokina, it's hard to expect perfection in every aspect. -- David Littlewood
Was this helpful?
Yes
No
Solution #5
Rank: Apprentice
Rating: 0%, 0 votes
That's a great little lens. I shot with one recently and I think I'm going to buy it. I didn't see too much distortion in my pics. Well, not enought to make me want to not buy the lens.
Was this helpful?
Yes
No
Solution #6
Gary10 - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Lisa, a lot of the cost of a top quality ultrawide lens goes into correcting spherical aberrations like the barrel distortion you mention. Even with a better lens you'll get some elongation at the frame edges with close subjects--this is a matter of perspective--but straight lines won't curve. Here's a link to some test photos I took a couple weeks ago with a 21mm lens I was trying out:
The lens in question performs very well in terms of distortion. Most if not all major lens makers should have ultrawides in their lineups that perform equally as well.
I have a Minolta Dimage 5 camera that I can't get the manual lens to move it is stuck, how can i fix...
(More)
I have a Minolta Dimage 5 camera that I can't get the manual lens to move it is stuck, how can i fix that?
I have a quantaray 70-300mm 4-5.6 macro tech 10 pf af lens. Can you tell me what type camera it...
(More)
I have a quantaray 70-300mm 4-5.6 macro tech 10 pf af lens. Can you tell me what type camera it fits/
I have a muched loved (and used) Cosina 19-35 lens and I am getting a Communications between the...
(More)
I have a muched loved (and used) Cosina 19-35 lens and I am getting a Communications between the camera and lens is faulty. Clean the lens contacts. I have cleaned them with Isopropyl Alcohol but to no avail. It's the same on my EOS10D and EOS5D MK2.Any suggestions?
