Question about Linksys Wireless-G WRT54G Router
Need to get back to factory settings on linksys wireless router
Attempted to install wireless router so we could add another computer; it asked for changes to network name and security password the install was incorrect; I now wish to share old router and new wireless one so that my phone will still work; second attempt failed because I was prompted to revert back to origninal passwords; no way to retrieve these
What can I do?
    Scholar:
  • 50 Answers
Look at the back of the wireless router.  There is a reset button.  Take a ball point pen and push that little button that says reset and hold it (while the unit is on and plugged in).  Hold the button for about 15-20 sec.  Then let go of the button and you should be able to log back in.  Your IP address to access your router should be:   192.168.1.1     Your default password and username will be (Username: admin    Password: admin)
Any questions, just ask!!!
Posted on Feb 02, 2009
Forget my password
To reset the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of therouter with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to beconfigured with the SSID, encryption etc. and also the wireless cards in allthe laptops/computers needs to be configured with these router's wirelesssettings. Then the laptops/desktop computers can communicate with your wirelessrouter.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default PW (write it down and putit in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jul 18, 2011 | Linksys Wireless-G WRT54G Router
Forgot user name and password need to add new
Sorry but this is the only to reset the password
Press the Reset Button for approximately 10 seconds
Resetting the Router will erase all of your settings (WEP Encryption, Wireless and LAN settings, etc.) and replace them with the factory defaults.
Jun 06, 2011 | Linksys Wireless-G WRT54G Router
Change my router password
Click around once you're in the settings. There should be a setup tab with the password change somewhere.
Mar 12, 2011 | Linksys WRT160N Wireless Router
I need the wep
you can find this out by connecting to your linksys router with a cat 5 cable.
in your browser such as internet explorer or firefox type
192.168.1.1
login with your login/pass that you assigned to it.
go to the wireless tab and go to security
it will show the the WEP key that is needed in order for your laptop or wireless devices to connect.
BTW I would recommended using WPA as WEP is not secured.
Mar 06, 2011 | Linksys Wireless-G WRT54G Router
I need to restore the factory defaults for my Linksys Router, but i can't open the Router's web-based utility
You can reset it with RESET/wps button it is in back side of router.Press it for 10 seconds then all settings defaults.
Then You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Apr 27, 2010 | Linksys Wireless-G Broadband Router
How can I locate the PIN number of the router I have on the Linksys tag the model, under that a S/N# under that a MAC#? Is my MAC# the PIN#?
Are you trying to connect to the wireless network on the windows VISTA / 7 computer? Sometimes it willl ask you for PIN number. you don't need to enter the PIN number. On the same page you will get the option, I don't want to configure, i want to enter the key. click on it and it will go to the next step. if you network is secured then it will ask you for the network key. Enter the key and it will connect you to the network. If you are trying to add any other wireless device in the network then try to bypass this step and connect to the network manually.
Click here for step by step instructions
Apr 04, 2010 | Linksys Wireless-G WRT54G Router
Password
Linksys reset
The easiest method of resetting your Linksys router’s password is to reset your router back to the default factory settings. This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Once the router has been reset, it must be reconfigured. Using your web browser go to URL address http://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password “admin”, in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to “admin” on some of the newer Linksys router models).
Nov 04, 2009 | Linksys Wireless-G WRT54G Router
I forgot my password
If you have forgotten your LinkSys router password, the easiest thing to do is to reset your router to the factory default settings.
To restore the router configuration to factory defaults, hold the reset button on the unit for 30 seconds.
Once your router is hard reset, you will need to login and reconfigure it again.
To reconfigure your LinkSys, connect a PC to one of it's Ethernet ports, load a web browser, and go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router.
LinkSys Default Password
On older LinkSys routers, the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin."
Once you are past the login screen, you are able to reconfigure the LinkSys router.
Sep 08, 2009 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
48 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
