Question about Whirlpool GGQ8831L Gas Dryer
Flipper inside Dryer is loose
One of the three flippers inside the dryer is loose how can I thighten it?
  • 547 Answers
Unplug dryer open back find the screws on the out side of drum and tighten them
Posted on Feb 11, 2009
Inside the drum one of the tumblers is loose how do you tighten it up?
You can tighten those baffles by getting to outside of drum to thighten the screws that hold them to drum. to get access to outside of drum;
Remove screws from door hinge
remove screws from other side of inside door as they are exaclty opposite the ones for hinges
pull off from panel by putting putty knife/screwdriver in seam between front panel/cabinet just below the sloped part of the top and pop off front panel
in the upper corners of the top/front panel is a clip that looks likea inverted "7" or if ya will a up side down "L" remove screws from the clips and remove the clip
now ya can raise top to get to outside of drum
rotate drum by hand in CLOCKWISE direction to turn drum so ya can get to each baffle
Thanks for using FixYa.com,
Gene
Aug 22, 2011 | Maytag Neptune MDE5500AY Electric Dryer
I have an MDE7600AYW electric dryer and two of the three fins came loose inside the dryer and one of them is now lost. Who can I contact to purchase a new one with the installation screws???
The fins are called "Baffles" and you can find the parts at the link below:
http://www.partselect.com/PartDetail.aspx?Inventory=2035811&SourceCode=1
Jan 06, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Two of the three internal fins in the dryer came loose and detached from the inside of the dryer. Now the dryer is losing heat where the installation holes are located. Can I purchase new fins and install...
if you open the dryer by removing the top and front panel/door assy you can look at the bottom of the unit and find the old screws, buy the new fins, and re attach them if the holes in the dryer where the screws attach to the fins are too large for the screws use some washers
Jan 06, 2010 | Maytag Dryers
Paddle inside dryer came loose how do we tighten
You have to open up the dryer to expose the clothes drum. Most paddles are fastened by two or three 1/4" sheet metal screws. Look for your lost screw in the dryer or replace it with the same. Use a drop or two of lock-tite to keep screws in place. Good time also to clean out all lint which can become a fire hazard, replace the drum belt and redo all of the screws.
Oct 15, 2009 | Maytag Neptune MDE5500AY Electric Dryer
We have a Maytag Atlantis dryer. Inside the tub
Did you try opening up the back of dryer or the top?
Sep 05, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Rattle inside dryer drum
remove the front cover and then you can access the top cover screws to open top then you can locate and tighten screws
Jul 27, 2009 | Maytag Neptune MDE5500AY Electric Dryer
MDE7600AYW Atlantis Dryer -paddle inside dryer is coming loose
You will need to take the back panel off use a 1/4 in socket driver.Then you should see the drum.
Len
Feb 21, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer making a crazy noise
Hello, shhllc,
The problem is with one of three pulleys. There are two "drum rollers" on which the dryer drum rests, and then there is a third pulley which keeps tension on the belt that connects the motor to the drum. Either of these can get squeaky when the grease dries out, or when they wear from prolonged use.To open this dryer, remove the front panel (either 4 screws inside the hinge mounts on both sides, or 2 screws along the bottom of the front panel) and check with a flashlight to find these three pulleys. With the dryer unplugged, jiggle each one... if it is loose from its axle, it needs replacing, otherwise, just lube all three pulleys by removing the retainer clip and wheel, greasing the steel axle with silicone (never use oil!), then replace the wheel and clip. You should enjoy blissful silence from there.
May 06, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Neptune dryer
sounds like one of your tumbler veins inside the drum is loose. there should be two or three screws holding them in
Nov 20, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Older washer/ dryer with no power
Check to see if power cord is loose at connection inside dryer. ONLY after UNPLUGING! Held on by three screws inside.
Aug 22, 2006 | Maytag PYE2300AY Electric Dryer
Whirlpool GGQ8831L Gas Dryer Logo
53 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
