I have a 1993 Kenmore Gas Furnace. For past few weeks it's been turning on and off with a big flame very often (few minutes). Now there's a loud knock that shakes the room and we're afraid to turn it back on. A plumber who I trust and know a long time doesn't want to put any parts in it and he says we need a new furnace and gave me a reasonable price. He says he doesn't want to be responsible for the family if something should happen if he just replaces parts and says he'd be surprised if it lasts a month after putting parts in. I don't have an extended warranty and it's cold weather adding to the urgency. If I have a Sears man come over and he says he can fix it, I don't know how soon he can do that (time of essence!) and if it'll stay fixed. What should I do?
  • Perry Putnam
    Perry Putnam May 11, 2010
    Get a clarification on what is actually wrong and then get two quotes, one to fix it correctly and one to replace it. If it's more then the 200-300 to fix it like Skeeter said I would definitely take that money and replace it. No one can predict how long the furnace will last but an average is about 20 years. You have to weigh your options and decide for yourself but do so informed.
  • Ken Bledsoe May 11, 2010
    If it were me I would replace the unit. Cost to fix something like what you are talking about could run around 200 to 300 dollars. On a 15 year old unit is pushing the life a bit of the furnace.
    For around 1200 you could get a new furnace installed and be way ahead. 700 for the unit and 500 for installing. If money is a issue then fix the unit and inside of 5 years you will be replacing it anyways. This is a tuff call for you cause if you have a a/c with the unit that will need to be replaced in the future also.
  • 56 Answers
With the age of the equipment it may be cheaper to get it replaced rather than fixing it plus you will have warranty plus peace of mind.
Posted on Feb 12, 2009
  • Pyldrvr Feb 12, 2009
Furnace starts and ignites and fan comes on but when thermostat is turned off the gas shuts off and flame off but furnace continues to run. whu?? any suggestions?
The fan normally runs for a few minutes or so after the gas shuts off.
This removes the heat from the furnace and transfers it into the living space instead of just letting it possibly cause overheating of the furnace until it dissipates. If it is a fan that blows outside, that fan also needs to run for a few minutes to clear exhaust gasses from the furnace - to keep them from dissipating into your home.
Sep 28, 2015 | Heating & Cooling
Ruud 90+ Model UGRA 10EZAJS Trips Out
Check for condensation buildup in the Induction Blower housing. The condensate tubes or canister may be blocked and causing the diaphragm switch to trip the unit out causing the burners to shut down.
Feb 11, 2012 | Ruud Heating & Cooling
Furnace does not turn on normally
Having to reset it tells me that there is probably an error code blinking on the control board. Look for a small viewing port that looks into the cabinet. Count the number of blinks then remove the panels to find the wiring diagram pasted on one of them. On the diagram you will find a diagnostic code to help you narrow down the problem. It could be as simple as a plugged air filter.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Feb 07, 2010 | Goodman Heating & Cooling
Carrier Gas Furnace and Hunter Thermostat not working
Definitely a furnace issue. The gas valve is not opening if you see no flame. I have seen the igniter glow but not send enough voltage to the circuit board to make the gas valve open. If this is the case you should replace the igniter. It is very fragile so please use care when replacing. Check all connections at the circuit board as well as the gas valve. Check your gas supply. Check to see if you get 24 volts AC to the gas valve. If no, replace the circuit board. If yes, replace the gas valve once you confirm that you have gas to it. If you get a pilot flame only, you will need to clean the burners and flame tray that spreads the flame from one burner to the next.
Dec 06, 2009 | Heating & Cooling
My Lennox gas furnace runs for approximately two minutes and shuts off. Normally the blower runs for a few minutes but no longer is this the case. My furnace repair man cleaned the flame sensor and it...
if the unit has a flame (gas valve opening)the problem may be the fan going bad or fan relay -- sounds like unit going off on high limit control
Nov 01, 2009 | Heating & Cooling
Burner flame going out on windy days on Coleman Evcon LP furnace
This sounds like a bad heat exchanger. It is possible that you do not see the crack because the crack is closed when the heat exchanger is cold (or room temp). Allow the furnace to heat up, this will allow the expansion of the crack. Turn the power off and examine the heat exchanger while it is still hot.
Mar 31, 2009 | Coleman Propane Forced Air Heater...
Furnace is blowing but gas is going off and on all the time
Check the heat anticipator on the stat if its a manual one
Mar 16, 2009 | Heating & Cooling
Rheem gas furnace pilot lights, but no burners or fan
If the burners do not fully ignite, the sensor will shut the furnace down. The lack of sufficient burner flame is a gas valve or gas pressure problem within the valve.
Replacing the gas valve with the original one may get you going. I surely suggest a professional service company for safety reasons and a thorough inspection. A 20 year old furnace is past it's normal life span.
Jan 06, 2009 | Heating & Cooling
Lennox Gas Furnace that turns on and shuts off in minutes
After troubleshooting like mad, I found that the flame sensor (rod that sits within the flame) was fouled with carbon on the surface. I believe this shields the rod from proper heat detection and the sensor reports that there is no flame and to shut off the gas valve to avoid explosion. Once I pulled out the rod and cleaned it with a wire brush, I have no problem whatsoever--fixed.
Nov 10, 2008 | Heating & Cooling
Heating & Cooling Logo
101 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
