Question about GE DVLR223 Dryers
Ge dryer not heating
Dryer wont heat up, it was working sometimes but now it wont heat up at all. it is a ge model is dde79055blww
  • 193 Answers
Most likely problem is burnt out heater coils
Posted on Sep 29, 2009
  • 1122 Answers
SOURCE: kenmore heavy duty clothes dryer will not heat
REMOVE THE BACK AND CHECK THE HEATER FUSE AND THE HEATING ELEMENT-MIKE
Posted on Feb 26, 2009
jumptrout51
  • 3361 Answers
SOURCE: KENMORE DRYER MODEL NUMBER 66912690 WONT HEAT
Check the voltage at the terminal block where the cord hooks up for 220 volts.
Remove the rear panel and check the thermal fuse located on the upper portion of the heat canister.
Check the Hi-limit thermostat on the bottom portion of the heat canister.
Check all the wires for a burned or loose wire.
Check continuity of the heating element.
Posted on Mar 08, 2009
hektor1961
  • 70 Answers
SOURCE: GE DRYER HEATING ELEMENT
Yes, the whole drum needs to be removed:
Before you go trough this make sure you know for sure your elements need replacement by checking for continuity at both element terminals.
Make sure you do the same with your high limit thermostat on housing.
How to remove the drum?:
Disconnect the power source to your dryer before you begin to remove the drum. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Pull your dryer out from the wall. Behind it, on the bottom, you will find a lower panel that will give you access to the unit's belt tensioner (also known as an idler pulley arm). Remove the screws holding this panel in place, and then remove the panel itself. Reach inside and release the belt tension by removing the belt from the motor pinion.
Older GE dryer models have a small drum bearing inspection plate in the center of the back of the dryer. This drum bearing inspection plate provides access to the dryer's circlip (also known as an e-ring). This clip holds the rear drum shaft in place. Newer models do not have this circlip or the drum bearing inspection plate.
If yours is an older GE model with an inspection plate, remove the plate now. It will be held in place with a single screw. With the plate removed, you will be able to see the drum support shaft and the e-ring (circlip) holding the shaft in place. Use a small screwdriver to remove the e-ring. You may also want to use a magnet to keep the circlip from falling into the dryer. You will also find several metal and nylon shims between the bearing and the e-ring, inside the bearing, and between the bearing and the drum. Take careful note of how they come off so that you will be able to put them back on again in the right order.
Now remove the front panel of the dryer. There are a couple of different ways this is accomplished. Whichever method you use is dependent upon your model. Some older models have two spring catch clips under the cabinet top, one on the left side, and one on the right side of the front. Use a putty knife, or some other flat and thin object to wedge in under the cabinet top. Release both spring catches and lift the cabinet top off the dryer. In some newer models, there will be screws joining the cabinet front panel to the cabinet top. You will have to open the door in order to find these screws. Once they are found, remove them and then slide the cabinet top forward and lift it off the unit.
Next, there are two screws located in the bottom of the front panel, one in each corner. Loosen these, but do not remove them just yet. Locate and remove the two screws at the top inside of the dryer's front panel. Again, there is one screw in each corner. Proceed to remove the other two screws you have just loosened. Disconnect the door switch wires and then lift the front panel off your dryer. With the front panel removed, lift the drum and slide it out of the dryer.
NOTE: In some models, you will have to remove the dryer drum glides before you can remove the drum. Also, now that the interior of your dryer is completely exposed, it might be a good time to vacuum out all of the dust and lint that has built up in there.
Posted on Aug 17, 2009
hunter19_46m
  • 7482 Answers
SOURCE: ge dryer model DVL223EA0WW service manual to replace heating coil
Try this website, they will have everything you need.
http://www.repairclinic.com/SSPartDetail.aspx?PartID=2512&Acc=1&PPStack=1
Good luck,I hope this helps
Posted on Nov 13, 2009
heatman101
  • 43501 Answers
SOURCE: runs but no heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
Posted on May 29, 2010
My GE dryer only heats up sometimes
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 17, 2010 | GE Profile Harmony DPGT750EC Electric...
My dryer wont heat up, the drum spins but there is not heat! any help?!
heatman101
Sep 04, 2010 | GE Spacemaker Washer and Dryer Electric...
My ge gas dryer works but no heat
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
heatman101
Aug 24, 2010 | GE Dryers
Model #w8w2780wcwww over and under. dryer works but does not heat. ge model
heatman101
Aug 23, 2010 | GE Dryers
RUNS BUT NO HEAT
heatman101
Aug 21, 2010 | GE Profile DPSR473GW Dryer
I have GE dbl33eb4ww dyer that wont get clothes dry till you run them through about trhee or four times
heatman101
Aug 19, 2010 | GE DBL333EA Electric Dryer
Drier does not produce heat m# DPSB620EC2WW s# AG717393A
heatman101
Aug 18, 2010 | GE Dryers
The dryer is not heating up
heatman101
Aug 17, 2010 | GE DBL333GB Gas Dryer
My ge dryer wont heat up
heatman101
Jul 08, 2010 | GE DWSR483GB Gas Dryer
GE GAS DRYER DCLR333ETOWW
Check the vent sometimes if the vent is blocked the thermostat gets false reading.There are some other problems such as thermostat,Igniter,heating element.
Apr 21, 2008 | Bosch Axxis WTA 3510 Electric Dryer
GE DVLR223 Dryers Logo
280 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
