Question about KitchenAid KITCHEN AID 5 Quart Artisan Series Stand Mixer
Control Lock light is on and nothing works on my stovetop
I have a 5 burner Kitchen Aid glass stovetop and the control lock light has come on. Nothing is functioning on the stovetop. How can I reset this?
  • 135 Answers
Hi. Research your stovetop on the kitchenaid website. You should be able to download a user manual for your model. The manual should tell you how to reset the lock. If a manual is not available, try disconnecting the power supply to the stove. This might clear the memory of the stove. Good luck. ricardok45
Posted on Feb 24, 2009
Kitchenaid KSM150 Mixer's speed Off has become High and speeds 1-10 have become Off
The starting position for those top speed control plate screws with the lock nuts it 8 full turns in when you fit the plate. Correct adjustment begins in or out from that point. The bottom screw should have been left where it was to start with as that is for adjusting the start position so that when the lever closes the switch contacts to start the mixer the plate only starts moving when the lever moves to the second click. Try and get the bottom one roughly right and then work on the top ones. Turn it to the first click on the speed lever and then EVENLY adjust the 2 top screws to have the planetary turn 13 to 15 times per 15 seconds. Lock up the lock nuts and then check that the bottom screw is in the correct position with speed increasing a small amount as the lever slips into the second click.
Sep 15, 2017 | KitchenAid Kitchen Aid KSM150 Artisan 5...
My kitchen Aid mixer lever will not move...help
Which lever? Speed control or tilt head lock?
Jun 24, 2017 | Food Mixers
How to replace the speed control plate
Take the back cover off, remove the wires. Unclip the spring from the bottom of the plate, don't let it fly back inside the housing. Unlock the 2 screws at the top and undo them. Fit the new plate, each screw 8 turns in to start with. Hook up the spring, put on the wires where they came from. Start machine on speed one, and adjust the top screws evenly to give the planetary 13 to 15 revolutions in 15 seconds. Lock the screws up with the lock nuts. The screw at the bottom is then adjusted so that it gives a slight speed increase when you enter speed 2 from speed 1.
Jul 29, 2014 | KitchenAid K5SS Mixer Speed Control Plate...
Kitchen aid switch not working
Which switch speed or head lock? What are the problems? Need more info to help.
Sep 07, 2013 | KitchenAid KITCHEN AID 5 Quart Artisan...
Motor head on Kitchen Aid KSM150PSWW is loose when in operation.
Are you engaging the head lock during operation? if not that is why it is loose. If you are it is not uncommon for the head to move around a little under heavy loads, when I make bread the head is always trying to come up so I have to use the head lock switch whenever I use the mixer on bread. It is the only time I lock it down.
Sep 05, 2013 | KitchenAid Kitchen Aid KSM150PSWW -...
Kitchen aid artisan mixer is loose and shaking
This could be the pivot rod between the head and the column being loose and out of place. Or it could be the hook activated by the lock lever not engaging properly. See the following Service Manual:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Mar 30, 2013 | KitchenAid KITCHEN AID 5 Quart Artisan...
Kitchen aid hd professional mixer problems with speed controls
you need a new speed control board, easy fix about $35.00 for the part and an hour of your time, not even messy to do a total of six screws and four wire connections that clip on, several youtube step by step instruction videos available. parts available on ebay. let us know if this helps you
Jan 28, 2013 | KitchenAid Food Mixers
Kitchen Aid stand mixer head doesn't lock down and wobbles
You need to do a couple of strokes with a rat tail file at a 30 degree angle at the top of the slot the head lock engages into. You will need to remove the hinge pin to do this. A Kitchen Aid agent will have done plenty of then so it won't cost an arm and a leg to get it sorted.
Nov 17, 2012 | KitchenAid KITCHEN AID 5 Quart Artisan...
Kitchen Aid Stand Mixer (model 4KSM90OB) won't run.
Sounds like you have solved it already, the phase boards are worth stuff all so buy one and throw it in. It's unlikely to be much else as you have proved the motor runs.
Mar 20, 2017 | KitchenAid KSM103 Professional 5 Series...
KitchenAid KITCHEN AID 5 Quart Artisan Series Stand Mixer Logo
328 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
