Question about Craftsman 8.50 Torque Rating Dual Rotating Tine Tiller
Tines stop turning
Tines stop every few feet. I give them a slight kick and they start again.
  • riser987 Feb 10, 2009
    New belt solved the problem. Thanks mrfixit-jerr. Definately a FixYa!!! I was afraid it was going to be something more involved. Last year the tiny "bicycle chain" that turns the wheels broke and although I only had to buy a 20 cent link it was the nastiest greasiest mechanical job I've ever done. The chain was encased in grease and I had to dismantle the whole darn tiller - every bolt and screw on the thing - to get to it. Design flaw? I think so and wouldn't recommend the craftsman for that reason.
Started electric tiller for 1st time this year. It ran a few inches then stopped. Tried reset button, still won't start. Tested cord and it's good. Any suggestions?
Double check to make sure nothing is binding or blocking tines.
Unplug see if you can turn tines by hand ever so slightly. How old is the tiller? warranty? troubleshooting in owner's manual? Customer service may be helpful.
Mar 04, 2015 | Mantis Electric Tiller
My srtrider will only go for a few feet then comes to an abrupt stop its abit like the back wheels jam..but then it will go for another couple of feet then come to a stop again there are no warning lights...
If your batteries are running very low, this is the most likely source of your problems. 80% of my scooter repairs involve batteries. The fact that your scooter runs is a good thing. The fact that it runs only a few feet and gives you no error code when it stops indicates the electronics have no battery power to indicate a flash code. The back wheels jamming probably relates to a no power condition causing the brake to lock (it takes power to release the brake and turn the motor)
This scooter uses two U-1 batteries that last between 1 and 2 years. From your description, I would replace the batteries first and make any further determination of any problems, if any,after that. These batteries are available locally at a large discount (between $50 and $160 each) and can be installed with basic tools, saving you money on the labor charge.
Shop around for the best price. Charge the new batteries fully before use. Enjoy.
Hope this helps.
Nov 25, 2010 | Electric Strider Midi 4 Wheel Mobility...
Tines turning, mantis 2 cycle tiller
sounds like a piston seizure. are you using correct oil and ratio. carb could be going lean and causing the cylinder to over heat, adjust high speed mixing screw and hope no damage has resulted.
Jun 30, 2010 | Mantis 2-Cycle Tiller
I have a ctm scooter the battries are charged fully when i switch on the scooter will not work switch off and on again it then will travel a few feet before stopping
I would say the throttle pot is slightly out of neutral allowing the scooter to travel slightly when turned on. Try moving the throttle lever slightly in the opposite direction to which the scooter is travelling (i.e. if the scooter moves forward when turned on, press the lever to go backwards, but only a small amount). If the scooter stops and you hear a clicking noise from the back of the scooter (this would be the brake clicking on) then that would be your problem. Would just need a small adjustment but best left to a dealer as it has to be sopt on! Sometimes scooters will not work if the throttle is slightly out but if its only a very small amount out of neutral, it might sometimes work in the manner you have suggested. We have come accross this fault on a few occasions. Hope this helps...
Mar 07, 2010 | Health & Beauty
RV A/C blower not working and keeps kicking out
If blower not working, and yoou hear a slight "Hum" with fan only on, try this. With power off to AC. Go up on roof, and slide a stick through opening on side near rear, and try to get to fan blades at rear of unit. try to spin the blades a few times, even if it only goes a little at a time. Unless you want to take all those screws out & remove cover to get at it better, but watch for wasps under there. Give fan a couple of full rotations, then have someone turn it on to fan only & see what happens. If fan finally works, let it run for a few minutes on fan, then try cool & see if it all comes together again. Let me know.
Jul 17, 2009 | Dometic Rooftop RV Air Conditioner
03 chevy suburban z71 abs kicks in whiling almost stopped
I would say that your vss is out on that hub replace that and see what happens .
Mar 23, 2009 | 2003 Chevrolet Suburban 1500
New fuel pump
Sounds like a after market pump? I did the same thing.Go Ac/Delco for the best case.Note no sound no fuel.Try the old turn the key on and give the tank a kick.This kinda kick starts the pump.Idone this a few times.If you are stuck and your pump stops and it did start by kick don't stop the engine till you are home or a shop.
Oct 19, 2008 | 1999 Chevrolet K1500
Craftsman 8.50 Torque Rating  Dual Rotating Tine Tiller Logo
284 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
