Question about Dryers
Disabling the signal end of cycle on ge dryer
I have a dwxr483ebww GE dryer, that comes with no switch to disable end of cycle buzzing. I was wondering if there is any way to take the wire and disable it...
  • 29 Answers
The buzzer is inside the control switch area. Its about the size of 4 stacked 50 cent coins. Kill the power to the drier and then open the control panel and locate the buzzer. Remove the two wires; using electrical tape, you can tape up each wire end and then secure it out of the way. :?) DRRXR
Posted on Feb 02, 2009
On our GE WSM2420 the buzzer is also just beneath the control panel, but it's rectangular, slightly larger than a 9V battery.
Posted on May 04, 2010
YES! I finally did it! I am just going to give a more detailed answer than DRRXR above to hopefully make it fool proof. First UNPLUG the unit of course. Then remove all the knobs except the last one to the left (facing you). I left the last one on bc it didn't want to come off so I did not force it off. Then remove the four screws on the right and left side of the control panel. The silver panels will come off. Then take a wrench and pull the black screw on the right. This will allow you to pull down on the black panel behind the control panel just enough to get to the buzzer. Then just remove the wires. PRESTO.
Posted on Mar 30, 2013
Want to disable buzzer
Hello Craig McDaniel - The buzzer signal will sound when the cycle ends and briefly every 5 minutes as it is a reminder to remove the load. For this purpose, unfortunately the buzzer signal cannot be disable. Most of this brands laundry centers and microwaves are preset to do this.
Feb 15, 2013 | Frigidaire FEQ1442ES Electric Dryer
The noisy alarm on my washer/dryer combo is driving me crazy, is there any way to disable it?
Hello Heather Holley - The signal will sound when the cycle ends and briefly every five minutes as it is a reminder to remove the load. For this purpose, unfortunately the buzzer signal cannot be disable. Most of this brands laundry centers and microwaves are preset to do this.
Dec 29, 2012 | Frigidaire FEX831CS Top Load Stacked...
When I press the start button on my GE DPSR610EG4WT profile dryer it only makes an electrical buzzing sound and will not turn on or start. What causes this?
The buzz is probably coming from the control switch drive motor. If it is not turning the switch, the dryer wont run.
murf427
Aug 02, 2012 | GE DPSR610EGWT Electric Dryer
Problems with GE DWXR483EBWW Electric Dryer. Dryer will not start (no spin,no heat, no attempt to start). Has Power because interior light works. About 6 mo ago start switch was replaced...does not appear...
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a broken door latch, a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
Nov 11, 2009 | GE DWXR483EBCC Electric Dryer
Machine buzzes and then stops .....does not normally buzz,I don't think there is even a buzz setting for a finished cycle....
Our GE front loader has a three position switch to control the buzzer as do many others. Check yours for 'end of cycle' alarm switch.
Aug 23, 2009 | Kenmore 27032
GE Six Cycle Automatic Dryer just buzzes when I push start
most of the time when the syary button just busses it means the motor is gone,you can take it apart and clean and lube itmake sure nothing stuck in it,let me know if you need more help-mike
Mar 19, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
GE gss20iembww wont end defrost cycle
yes replace heater tstat and back board
Mar 17, 2009 | Refrigerators
Dryer end of cycle buzzer
disconnect the BUZZER wire from the Timer
Sep 16, 2008 | Crosley CDG6000 Gas Dryer
Dryers Logo
565 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
